Gas tank overfilling?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by missioncruiser, Apr 6, 2014.
  1. Apr 6, 2014 at 1:46 PM
    missioncruiser
    missioncruiser [OP] Member
    Mission BC
    2013 SR5 DBL Cab 4WD
    I have a 2013 SR5 and it seems to always overfill and puke out gas when the pump clicks off. I am not trying to overfill it, in fact lately I have been slowing the pump down when I know I am getting close to full and hoping it doesn't spill out. My wife has a 2013 Rav4 and it does it as well. Not cool having gas puke out on your paint once a week.
    Anyone else experience this? I am going to ask the dealership about it at my first oil change.
  2. Apr 6, 2014 at 1:54 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Did you try other gas stations?
    Alexely999 likes this.
  3. Apr 6, 2014 at 1:55 PM
    ARtaco
    ARtaco Active Member
    North East Arkansas
    '11 DC BLK SR5 4x4 3" lift ARB bull bar
    ARB bull bar, camper shell, warn winch, Allpro sliders, allpro pack rack
    x2 usually it's the station's pump that causes this. Not always, but usually in my expirience.
    Alexely999 and PackCon like this.
  4. Apr 6, 2014 at 1:57 PM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    I've only had this happen once. Avoided that pump since and been fine.
  5. Apr 6, 2014 at 2:00 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Mine doesn't do this. Have you tried other stations to see if their pumps do it as well?
  6. Apr 6, 2014 at 2:08 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Its either the pump or the pumper but not the vehicles.
  7. Apr 6, 2014 at 2:15 PM
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    Happened to me twice on two different pumps at the same gas station. Haven't been back and has never done it again. Just crappy maintenance of the stations equipment. You might report the station to your Provence's version of a Corporation Commission (that's what it is called here in Oklahoma). Basically the entity that monitors stations, to make sure they are compliant with laws, a gal is actually a gal, etc.
  8. Apr 6, 2014 at 2:27 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I had the exact opposite happen in a little Kia I had years ago. At every gas station it wouldn't allow me to fill up because the gas pump would shut off after filling up a quarter of the way. This happened ALL the time and at every different gas station I went to. I would even try to very slowly pump the gas and even that didn't work. Even tried holding the pump at different angles, still would shut off. Never figured out what it was, sold it at auction.
    But to answer the OP question, it's probably the gas station, not the vehicle, as it was in my case.
  9. Apr 6, 2014 at 3:37 PM
    Grumpy514
    Grumpy514 Well-Known Member
    Emil
    NOVA
    14' Magnetic Gray T4R
    The car has nothing to do with that, I would let the pump attendant know to get their shit fixed.
    Overflowing your gas tank can REALLY cause nightmares with your EVAP system. I always find it funny for the people who keep dumping away after the pump clicked it off. Not knowing they can cause thousands of dollars in damage from a few cents extra of gas.
  10. Apr 6, 2014 at 4:06 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1 to all of the above.
    There are two Chevron stations near me that I can't use because there is a problem with the evap system at the station... gas goes in, I can feel the boot expanding, and the pump clicks off every gallon or two. Break the seal between the boot and fill pipe and I head and feel a "whoosh"
    I have to keep a finger jammed between the boot and fill pipe to get gas at those stations.
    Never had a problem at any other station.... but neither station was a problem for my '08 4-Runner company car.
  11. Apr 6, 2014 at 4:09 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Thousands? No a couple hundreds maybe lol
    My charcoal canister is bad on my 08 from me over filling eventhough I have been doing it since I bought the truck but it finally got me
    Gotta buy a new one
  12. Apr 6, 2014 at 4:13 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ya... about $350 in parts. Probably $600 if you have the dealer do the work.
    I just did my water pump. Dealer quoted $513.
    I spent $200 at Camelback, plus another $80 at the dealership for coolant (bought 3 gallons, didn't need more than 2).... AND I've now got new hoses and belt. That likely would have been an extra $200 had I wanted the dealer to do it (serp belt alone is $74 from Camelback!)
  13. Apr 6, 2014 at 4:15 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Yea it's $350 from dealer
    Install is super simple as long as the tank is low with fuel. Going to buy used for $80 online Idc so long as it works and no check engine light
  14. Apr 6, 2014 at 4:19 PM
    HawaiiTRD
    HawaiiTRD "Some people feel the rain, others just get wet"
    Hawaii
    2022 MGM DCSB TRDOR
    Diamondback SE, FITCAMX
    Tell the gas station you're going to to fix their crap. This happened to me once and it ticked me off. I just happened to be leaning on the truck while filling up that day.
    The pumps have a sensor at the bottom of the nozzle that shuts off the pump when the gas fills.
    Your vehicles are fine :thumbsup:
  15. Apr 6, 2014 at 4:22 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    OP needs to chime in on whether this is happening at the same station, and what exactly is meant by ' seems to always overfill'. From day 1, always, mostly always, every time, some of the time...? There's a lot of detail missing here.
  16. Apr 6, 2014 at 5:03 PM
    Grumpy514
    Emil
    NOVA
    I was talking people doing this to their cars in general, not just tacomas. Few hundred won't get you anything but laughed at with a new BMW or Mercedes.
  17. Apr 6, 2014 at 6:11 PM
    missioncruiser
    Mission BC
    I have a company gas card so limited to stations I can fill up at but it has happened at 2 different stations. Seemed strange our RAV4 is doing it too as she fills up at different station as well. I will try different pumps as per suggestions and advise.
  18. Apr 6, 2014 at 6:37 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    One more suggestion if that does not work. Based on the gage and mileage you should be able to estimate about how much it will hold. Turn it off well before that amount. You won't be full but your paint will not suffer either.
  19. Apr 7, 2014 at 6:50 AM
    ARtaco
    North East Arkansas
    Just FYI for anyone that this happens to, most of the time I've found that it is your fuel tank vent hose that is clogged. Have had to clean out a few of these for friends over the years. Damn Dirt Daubers build nest in them. lol
  20. Apr 8, 2014 at 9:00 PM
    missioncruiser
    Mission BC
    Any tips on cleaning the vent hose? This is a new one for me.
