Gas tank completely empty when at the E line?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, Jul 28, 2010.
  1. Jul 9, 2014 at 5:40 AM
    #181
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    epic thread revival. This is from my 2011 .. only took 18.5 gallons from this point. I had driven about 50 miles with the light on.
  2. Jul 9, 2014 at 6:35 AM
    #182
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    when my low gas light goes on, I have 60 miles left
    tested using 'distance to empty' on scangauge and how much I can fill it up,
    pretty accurate
    just under 2 gallons then reserve light comes on
  3. Jul 9, 2014 at 6:36 AM
    #183
    wgreenlee1021
    wgreenlee1021 Off the Meds Again...
    X2
  4. Jul 9, 2014 at 7:13 AM
    #184
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    2014 4wd sc 50 miles to Full, 120 to 3/4, 210 to Half, 300 to 1/4......e-light on between 365 and 385. Consistant as clockwork. Fill up as soon as a Chevron station appears and takes a little over 17 gals. on avg.
  5. Jul 9, 2014 at 7:37 AM
    #185
    puckstopper55
    Long Island
    My Ultra Gauge said I had 38 miles until empty. I was averaging ~14mpg for that tank due to towing, so it was pretty accurate.
  6. Jul 9, 2014 at 7:41 AM
    #186
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    I've driven about 20 miles with the light on, get about 18 gallons on that fill up. Supposed to be what, 20-21 gallon tank? I've never filled more than about 18.5 gallons
  7. Jul 9, 2014 at 8:57 AM
    #187
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Please see all the research posts I made (over 3 years ago) on the previous page (9) of this thread.
    My truck has 64,000 miles on it now and the gas gauge still reads the same as it did when new. Gallons at various points on the gauge is more accurate than posting how many miles you drove to those points since all of us can have different mileage based on how and what we drive.
  8. Jul 9, 2014 at 10:39 AM
    #188
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    The tank is actually 80 litres
  9. Jul 9, 2014 at 4:03 PM
    #189
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    More like 2 gallons
  10. Jul 9, 2014 at 4:16 PM
    #190
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Now if all the stuff is on the bottom all ready how does it suck it up empty and not when it's full the pick is on the bottom the crap is heaver then gasoline. If you run the pump dry the truck stops it has to maintain around 35 psi just to run. The pump is cooled by gasoline if it's running it's being cooled if the truck stops so does the pump. It just stupid to run out of gas but your truck will make it through just fine once you push it to the gas station.
  11. Jul 9, 2014 at 4:18 PM
    #191
    ToolFan66
    ToolFan66 Well-Known Member
    Littleton CO
    14 TRD Off Road DCSB 4x4
    I fill my tank when I hit 1/4 of a tank, I hate it getting any lower..
    jdg likes this.
  12. Jul 9, 2014 at 4:31 PM
    #192
    XSB41
    XSB41 If I had a hammer...
    Rik
    Va.
    2010 SR5 4X4
    hitch haul, bed extender, bed mat, behind seat gun rack, roof rack
    Lol...only let mine hit empty once when the light came on (2010), usually fill mine up at 1/2 tank...not sure why, perhaps from coming from a family of 4 & only 3 pork chops on the table for Sunday dinner...almost like a bargain spending less...who knows...I can remember when a Milky Way candy bar cost a dime, wish I had one now...
  13. Jul 9, 2014 at 5:40 PM
    #193
    David K
    I have filled my tank many times within a mile of the light coming one... 17 gallons (+/- 0.5 gal) goes in each time. Since we have a 21.1 gallon tank, that means 4 gallons is still in there (+/- 0.5 gal).
    When the gas gauge needle is over the E LINE, I have also found that I can fill it with 18-18.5 gallons (2.5-3.0 gallons still in there).
  14. Jul 9, 2014 at 6:05 PM
    #194
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    I fill at a half tank normally. Unless I'm on a long trip.
    jdg likes this.
  15. Jul 9, 2014 at 6:32 PM
    #195
    Earle
    Earle Well-Known Member
    Earle
    Huntville, AL
    11 double cab
    I believe my manual actually advises to fill up at 1/4...
  16. Jul 10, 2014 at 6:06 AM
    #196
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    if you are filling up in any sort of gas station that follows regulations, there is about zero chance of pumping dirt into the tank, and with plastic tanks, there are no particles forming in there
    If you gas up in some sh**ty town with a sh**ty gas station perhaps, but really there is nothing gonna happen if you run it dry, except some OBDII codes will fire, and the fuel pump will get a little warm. if you run it dry you may need to reset ecu with power cycle or truck might run crappy after fillup, while the system tries to figure out mapping again. anytime the injectors run dry the ecu goes a bit nutty trying to compensate and set parameters, and it might take a bit of drive time for it to normalize
    I am east coast and fill up exclusively at Shell or Mobil, and in 15 years tossing gas into my 4runner, the fuel filter flows 100% normal and never needs replacement. some long cross USA trips, only filled up at new stations and Mobil or Shell. places where you know they have failry new underground tanks and systems which dirt just doesn't happen. again, filters are there for a reason and you can get dirt, but nowadays it is very rare. Now I have seen a tanker at some stations and I pass by if I can make it to the next station, or don't need gas right then...just in case dirt is getting stirred up by the tanker
    I've used the 4runner to burn old snowblower and lawnmower gas, and also burn off about a gallon at a time of 50:1 2stroke when I used to race minibikes and I only used super fresh gas for those, so I had to get rid of all my weekend leftover mix. in the 4runner it went with a full tank of normal gas.
    [you wanna see something sensitive to quality gas, try a ~19,000rpm, 14.2HP, 50cc 2stroke race motor 15,2:1 compression...little friggin monster of a motor]
  17. Jan 7, 2016 at 9:08 AM
    #197
    jdg
    jdg Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    If I'm in town running around mine will seldom go below 1/2, out on the road usually 1/4 and I'm looking for a place to fill her up.
  18. Jan 7, 2016 at 2:28 PM
    #198
    David K
    THIS continues to be true the past 6 years.
  19. Feb 12, 2020 at 5:09 PM
    #199
    NavyDiver72
    NavyDiver72 I DO ALL MY OWN STUNTS
    Rick
    Millington, TN
    2006 DCLB TRD Sport PreRunner
    Any Mods? One. Maybe two, tops...
    Well, I don’t know how much further I could have gone...
    Rick
    Twinmold likes this.
  20. Feb 12, 2020 at 5:44 PM
    #200
    4wheelslacker
    4wheelslacker Slacker by trade
    East Tenn
    2010 Taco crew shortbed
    2017 Trd struts,2018 Trd wheels,bakflip2 bed cover,ungraded sound system
    Mine still had 2 gals in it at that point showing almost empty.Gauges just vary,l guess,but holy crap you ran yours to nothing!4EB5A0C5-99D5-4611-966E-FE87424C1E22.jpg
