gas pedal hard to push
Discussion in '1st Gen. Tacomas (1995-2004)' started by da0023, Mar 13, 2010.
  1. Mar 13, 2010 at 8:06 PM
    da0023
    da0023 [OP] The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    i started noticing last week that at times my gas pedal is really hard to push. it happens alot when in stop and go traffic from the constant accelerating then deccelerating. it is like that something is lodged behind it, then all of a sudden it will it release and it almost causing you to spin the tires. anyone else having this isssue? and if so, what can be done? wd-40, cable adjustment?
  2. Mar 13, 2010 at 8:08 PM
    toy02ota
    toy02ota Local TW dissenter
    Brownsville, TN
    2005 Chevy Silverado
    Recall!!!! Make sure you know how to stop a runaway taco!! :p
    Toyota: Moving Forward...just not always how you expect it.
  3. Mar 14, 2010 at 6:44 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Check the throttle cable and then the gas pedal itself. My guess is that it's more likely the cable is binding somewhere.
  4. Mar 14, 2010 at 8:14 AM
    biggdog747
    biggdog747 Well-Known Member
    MI
    taco
    clean the throttle body. that is the most come problem with cable operated throttle. there is no electrical on your throttle.
  5. Mar 15, 2010 at 9:24 AM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    any special instructions on cleaning it?
  6. Mar 15, 2010 at 9:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would do what Enola suggested first. Check to see if something is causing it to bind.
  7. Mar 15, 2010 at 9:26 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    when i did mine, i just used carb and choke cleaner with a soft cotten cloth. the carb cleaner evaporates and its not bad for engines
  8. Jan 15, 2011 at 4:00 PM
    moulin6801
    moulin6801 Well-Known Member
    My gas pedal is hard to press!!
    Did you fix yours?? I am not sure how to clean the throttle body!
    any help please??
  9. Jan 18, 2011 at 12:27 PM
    1996toyota
    1996toyota New Member
    northern VA
    96 tacoma
    I had the same problem with my 96 when I got it, the idle screw wasnt even touching the stop. I turned the idle screw in just until it was touching it and it fixed it right away. It probably needs cleaned also.
  10. Jan 22, 2011 at 9:33 PM
    moulin6801
    I got my oil changed yesterday and complained to the dealer about it. They told me that they have gotten a couple of complains like my after doing the pedal recall, and that will order a new pedal for me, to see if it will fix it.
    So , I will wait for that before i try anthing else. Thanks for the ideas and I will let you know what happens...
    Cheers
  11. Jan 23, 2011 at 2:16 PM
    killzone90
    killzone90 Well-Known Member
    Ethan
    Fairdale,ky
    96 tacoma
    mine did the same thing until yesterday.I work at a toyota dealership and took my tube off and sprayed carb cleaner in it and it feels amazing now
  12. Jan 24, 2011 at 1:25 PM
    moulin6801
    Hey Killzone! What tube are you talking about? Can you gives a little more detail on the procedure ??
    Thank you!!
  13. Jan 24, 2011 at 1:54 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Or maybe a burr or fray spot on cable....
  14. Jan 24, 2011 at 4:40 PM
    killzone90
    Ethan
    Fairdale,ky
    96 tacoma
    the tube goin into ur throttle body.I took it off,sprayed carb cleaner down it and works perfect now.Now if i had more money i would do it the way my shop recominds and thats do a intake cleaning with are machine but im to broke for that.If u do it my way it will be hard to start the first time after u do it but will clean itself out.
  15. Jan 24, 2011 at 7:56 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    2003 Tacoma SR5
    I will keep a watch on this post. My throttle seems to be VERY stiff also. I put it on the list of things to do when I had time but haven't gotten there yet.
