Gas Cap Holder Aluminum
Discussion in '3rd Gen. Tacomas (2016-2023)' started by John3976, Aug 15, 2023.
  1. Aug 15, 2023 at 10:35 AM
    John3976
    John3976 [OP] Well-Known Member
    Bill
    2023 Tacoma SR 2.7 4x4
    Just installed an aluminum gas cap holder, you can find them in ABS Plastic and this one in Aluminum. The aluminum one was only $2.00 dollars more than the ABS Plastic ones so I went with the aluminum one.
    Install was fast and easy took about 30 seconds to install it. You have to remove the screw that secures the clip that holds the fuel door closed, the kit comes with a new screw but you can reuse the original if it is in good shape. Mine is a 2023 Tacoma that was manufactured in 05/2023 so the screw was in great shape. Mine was not overly tight and unscrewed without any issues.
    The aluminum piece you slide into the open space of the inside frame of the fuel door, the aluminum gas cap holder has a slot cut into the right side of if that the edge of the inside frame slides into, it is a firm fit. I put blue loctite on the screw and reinstalled the original screw and tightened it. Job done. See photos. IMG_9615.jpgIMG_9616.jpg
    D.A.S. Taco likes this.
  2. Aug 15, 2023 at 10:52 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    It's literally that easy and to hang the gas cap by the tether lol. Whatever works for you!
    BRFab, batmanis243 and hiPSI like this.
  3. Aug 15, 2023 at 10:59 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Like wearing a belt and suspenders at the same time. Toyota gave you one that is easy. You spent money on one that is easy.
  4. Aug 15, 2023 at 11:18 AM
    John3976
    Bill
    The problem with hanging the fuel cap is you have to have the plastic line stretched to do it, I did not like hanging it like that, the fuel cap holder is a better solution, besides Toyota has used a similar design on other vehicles and from my understanding even the Tacoma in the past. The plastic line with the little zig zag on one end was likely a cost saving decision by some bean counter that only saved 2 cents per truck. For $15.00 I would rather have the aluminum fuel cap holder.
  5. Aug 15, 2023 at 11:29 AM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    I couldn't get the screw off, and I wasn't going to force it. Whichever one I bought, the left part goes behind the screw, and it still works. I do prefer it then hanging the cap. Don't know why my (older) 4Runner has that built in but not the Tacoma?! :rolleyes:
  6. Aug 15, 2023 at 11:30 AM
    unclewede
    unclewede Well-Known Member
    'Nard
    23 TRD Sport 4x4 Lunar
    To COMFORTABLY hang it from the tether on my 23, I had to move it over. Doing so, the door would not fully open until I removed the gas cap.
    Added a (plastic?) holder to my DS-18 order, took about 1 minute because I moved the tether back to original location.
    Wife's 19 Highlander has a holder from the factory . . . Son's 17 Yaris has a holder from the factory
  7. Aug 15, 2023 at 12:00 PM
    nds0000
    nds0000 Well-Known Member
    I use the same gas cap holder - but I also use a lockable gas cap. Unfortunately, that gas cap does not have a plastic tether.
  8. Aug 15, 2023 at 12:27 PM
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    Are you sure that black piece on the left of the holder doesn’t go behind the gray painted area that the screw goes into? Never knew they made aluminum ones.
  9. Aug 15, 2023 at 12:40 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I've had my truck almost 5 years. I just let it hang.
    Malvolio, ToyoTaco25 and 5nahalf like this.
  10. Aug 15, 2023 at 1:30 PM
    John3976
    Bill
    There is a welded nut on the back side, the aluminum piece has to go on the front on the left side. The right side has a slot milled into the aluminum that engages the inside frame of the door cover.
    3GTCMLMTD[QUOTED] likes this.
  11. Aug 15, 2023 at 2:39 PM
    ToyoTaco25
    North Carolina
    More like wearing a belt or suspenders with overalls.
  12. Aug 15, 2023 at 2:40 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I'm glad there are people like you in the world.
    ToyoTaco25 likes this.
  13. Aug 15, 2023 at 3:08 PM
    John3976
    Bill
    If you don't want one don't buy one, pretty simple if you ask me. My money, I will spend it on what I feel adds value to my truck.
    hiPSI[QUOTED] likes this.
  14. Aug 15, 2023 at 3:20 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    People post what they please. All opinions are here no right or wrong. That's what a forum is. Like it or not.
  15. Aug 15, 2023 at 3:57 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Please take this with the heavy dose of humor, as it is intended.
  16. Aug 15, 2023 at 4:23 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Support MESO who made to OG Gasshole.
    faawrenchbndr likes this.
  17. Aug 15, 2023 at 4:31 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Ha! Gotta love the MESO faithfuls...
    :tumbleweed:
    eurowner[QUOTED] likes this.
