GAS CAP HARD TO REMOVE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WAGONWHEEL, May 5, 2012.
  1. May 5, 2012 at 1:01 PM
    WAGONWHEEL
    WAGONWHEEL [OP] Active Member
    Dallas/Ft Worth, Texas
    2012 PreRunner, SR5
    None
    The gas cap on my 2012 is very hard to remove. My wife cannot remove it and I have trouble with it. We are not over-tightening it, just one click like it says on the cap. Anyone else have this problem?
  2. May 5, 2012 at 8:40 PM
    delscorcho
    delscorcho Well-Known Member
    Yorba Linda, CA
    09 DC LB SR5, Black Sand Pearl
    Haven't experienced that problem but my cap stopped clicking when tightening. I just go till snug now. Not sure if these caps are prone to problems.
  3. May 5, 2012 at 8:46 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    It will loosen up, it's a little tight when new. My new 12 was the same, it's fine now.
    David
  4. May 5, 2012 at 8:51 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Sounds like a good excuse to get a locking cap. The Stant is a piece of shit...get the Murray brand at Shucks/O'reilly Auto Parts.
  5. May 5, 2012 at 10:00 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    If it doesn't loosen up after a few uses, check whether the threaded section of the filler tube is actually round. I've seen a couple in the past (not 'yotas though) that were manufactured slightly oblong and the cap easily screws very tightly in there. If that's the case you'll also likely get CELs for the gas cap a couple times a year at random.
  6. May 6, 2012 at 1:53 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    its new...complain to your dealer and maybe theyll replace it.
