garrett electric turbocharger
Discussion in 'Performance and Tuning' started by xxOkieTacoxx, Sep 18, 2012.
  1. Sep 18, 2012 at 12:42 PM
    xxOkieTacoxx
    xxOkieTacoxx [OP] Well-Known Member
    Jake
    Texarkana, TX
    99 Tacoma SR5 3.4L 4x4/ 16’ DCLB TSS
    3.4L V-6 W/ custom intake,Flomaster super 44 dumped, 15" Incubus Alloy Wheels W/33x12.50 Yokohama Geolander MT'S, Bilstein 5100 Adj W/ OME 881coils, Pro Comp rear leafs W/ Bilstein 5100 shocks, Manual Hubs, Diff. Drop,Custom front bumper w/ winch W/ keyed disconnect and 2 250,000CP running lights, relocated blinkers, front bumper removed, radiator guards, custom skid plates, Rhinolined interior,
    Okay look at the site www.xsturbos.com
    This is a Garrett turbo with an dc electric motor that can either run 3 psi boost at 12v or 5-6 psi at 24v. My question is since I know that just flipping a switch and running 5-6 psi at all times isn't right, if I put a heavy duty rheostat on it and hooked it to the throttle body where it would adjust the rpms of the motor as the engine revved would that work? And also at 5-6 psi I could get by with just an ecu reflash?
  2. Sep 18, 2012 at 12:47 PM
    sfcadams
    sfcadams Retired Senior NCO
    Dan
    Elizabeth, Indiana
    2011 TRD Off Road DCSB Prerunner Skeewped
    ummmm, garbage?
  3. Sep 18, 2012 at 1:04 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Did you look at it? Is not one of those fart fans. Its an actual turbo impeller. It looks legit.
  4. Sep 18, 2012 at 1:20 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    LOL that has a LOW CFM RATE.
  5. Sep 18, 2012 at 1:23 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    That my friend is what you would call a scam.
  6. Sep 18, 2012 at 1:26 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    "sigh" yup my leaf blower mod still puts out more air.....
    Ya a company like Garret with a long and great history of Turbo units building something like this...WOW.
  7. Sep 18, 2012 at 3:18 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Well damn. I want more power for my taco but I have limited funds and saving up.money for a real turbo is out of the question. Im wondering though, im running 33's if I rehearse to 4.88's would I get the power back I had with 31's. My current fuel mileage highway is 20 ish. I run about 1800-2000 rpms at 70 mph.which isn't too bad. But putt putting around town and in the hills drains my tank quick
  8. Sep 18, 2012 at 5:46 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Still didn't answer my question....regear? Yes or no?
  9. Sep 18, 2012 at 5:51 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Gotta watch that one, he's good at that ;)
  10. Sep 18, 2012 at 5:51 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    re gearing will get you added torque. 4.88s is pretty high for 33's IMO most people go with 4.10s or 4.56. IMO an electric turbo is not a good idea. It might cost less but the fact that an electric motor can go bad isnt ok in my book. In a regular gas driven turbo it just turns by the exhaust much more reliable IMO. You have to pay to play a S/C is going to get you power in a lower RPM range. You can pick a used one up for a few grand if you are mechanically inclined you can install it yourself.
  11. Sep 18, 2012 at 7:17 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Thanks for the input tostidos. Much appreciated. Well my truck comes stock with 4.10's so I might try the 4.56's if you think 4.88 is too high cause I dont wanna lose my low gear for hills and mud. I just don't know how or where to get a turbo manifold made and im worried about detonation from too much boost. I don't know what the ecu can manage without a urd system. I just want to blput like 5-7 psi boost. Could the ecu handle that if I reflashed?
  12. Sep 18, 2012 at 7:24 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    The fact that their is porn links on the bottom of there page should throw up a red flag.
  13. Sep 18, 2012 at 7:39 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    That's just targeted advertising. The interwebs are watching you. I get ads for outdoor equipment like tents and shit.
  14. Sep 18, 2012 at 8:00 PM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    I see boobies at the bottom of the page. I wonder if anyone see's pictures of penis's? Not that there is anything wrong with that to each there own. What does everyone else see?
  15. Sep 18, 2012 at 8:06 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Well I talked to the supervisor from the toyota t-10 performance program at osuit technical college and he said to reflash the ecu all you have to do is disconnect the battery for 5 min and it will reflash it?
  16. Sep 18, 2012 at 8:12 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's not a reflash, that's a reset.
    It only clears codes (not all codes), but it also clears the buffers so if you have an inspection coming up, it won't pass for a week or more.
    Some trucks will also idle like shit until the ECU relearns the throttle and fuel trims.
  17. Sep 18, 2012 at 8:15 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    I saw that... At work. :eek:
  18. Sep 18, 2012 at 8:18 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Googling only finds a rumor for the next-gen WRX/STI, which are due late 2013, still a year away.
    :laugh:
    BTW, this kit, even if it works, is meant for a very short duty cycle (drag strip run) followed by lengthy recharging. Its intended usage is more akin to NOS.
  19. Sep 18, 2012 at 8:33 PM
    xxOkieTacoxx
    Jake
    Texarkana, TX
    Okay. Hmm. So could someone enlighten me on what a reflash is?
  20. Sep 18, 2012 at 9:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    A complete reprogramming of your ECU's memory from scratch.
    It is comparable to a fresh reinstall of windows.
