Garage door opener won't work
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gps1204, Jul 18, 2024.
  1. Jul 18, 2024 at 6:11 PM
    Gps1204
    Gps1204 [OP] Active Member
    2021 Tacoma TRD Sport
    My 2021 homelink garage door opener quit working. I can't get it to sync with the remote. The light is rapidly flashing green when I try to reset the button not orange like the manual says it should. Anyone know what to do fix this?
  2. Jul 18, 2024 at 7:31 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Which mirror do you have?
    Specifically which gentex model. The instructions are different for different models.
    Also, which make/model/mfg date garage door opener?
  3. Jul 18, 2024 at 8:16 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Any chance any of the items were updated?
    My garage-door-app won't work off of my Iphone anymore ( been a few years now ) after we went with
    a 5-G wireless router. Apparently the 'apps' only work with 4-G and below. So I either downgrade my router,
    which ain't gonna happen, or I lose what was a cool app on my Iphone to open the garage door.
  4. Jul 18, 2024 at 8:34 PM
    MyTacoma2023
    MyTacoma2023 Member
    Rich
    2023 TRD Sport
    For the App control I went with a chamberlain smart garage control. Very easy install and has an app to control garage door. Got it from Amazon and had it a couple of years. Pretty inexpensive as well.
  5. Jul 19, 2024 at 12:21 AM
    HoldTheSprinkles
    HoldTheSprinkles Member
    Curtis
    2021 Cement Off-Road Access Cab
    You should still be able to utilize 4G devices / apps on your 5G router. Check your router settings.
    Chew likes this.
  6. Jul 19, 2024 at 1:25 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Go Tom the truck turn it on and on the home link hold down the two outer buttons until it flashes and usually goes out . Then press the remote button and button you want on home link and hold down for a while , it will start to flash slow then faster. Release both buttons . Now go to the opener in the garage and press the smart button behind the light cover, …. A led will light … once that happens go back to the car and hold down that same button on the home link . The lights on the opener should go on and off to let you know the freq is learned and it should work
  7. Jul 19, 2024 at 5:50 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    Your router should have two wifi outputs. 1 for your home network on 5G and then a second one that is on 2.4G. I have some items in my house that are the same way. The tech can't handle the 5G but it works perfectly with the 2.4G. You just have to set it up so it connects to it.
    Chew likes this.
  8. Jul 19, 2024 at 7:49 AM
    2021SR5V64WD
    I thought that was the case but don't want to fk around with it. We rely on good fast internet as the wife will spend half of her work-week
    at home and I do NOT want to fk around with that scene.... absolute worst case scenario is for me I have to jump a fence into the back yard
    and fetch a key to get into the house if locked out.
  9. Jul 19, 2024 at 7:56 AM
    shaggy135
    If your provider is any good, they should have it already setup. Curious if you look for your wifi if its already there.
  10. Jul 19, 2024 at 8:09 AM
    Gps1204
    It doesn't run off wifi. It's a Craftsman door opener. It worked fine until last night.
    kahanabob likes this.
  11. Jul 19, 2024 at 8:44 AM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Don't have a solution but maybe your opener is just starting to wear out if it's old. Maybe unplug it for a few minutes then re- plug.
    Gps1204[OP] likes this.
  12. Jul 19, 2024 at 8:55 AM
    Gps1204
    Going to try that.
  13. Jul 19, 2024 at 9:00 AM
    canuck guy
    Alberta
    23TRDOR
    If that doesn't work you could try disconnecting negative terminal on Taco for a few minutes then reconnect. Then try reprogramming. Maybe try and forget color of lights.
  14. Jul 19, 2024 at 2:54 PM
    TruckGuy63
    Gilbert
    New York
    Try what said lol
    I used to work on garage doors
    I had a business at one point
  15. Jul 19, 2024 at 3:18 PM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    It's the truck's fault. Sell it.
  16. Jul 19, 2024 at 5:26 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    do you have a hand remote for the opener, if so and that works then it is the mirror.
    then i would try the set up process for the home link mirror.
    this may or may not help
    https://www.youtube.com/watch?v=96s6YlRIE4g
    Gps1204[QUOTED][OP] likes this.
  17. Jul 20, 2024 at 1:00 PM
    canuck guy
    Alberta
    23TRDOR
    OP resolved?
    Or another looking for help then no follow up ?
  18. Jul 20, 2024 at 2:27 PM
    Gps1204
    Not resolved. Still trying to figure it out and haven't had time today.
  19. Jul 20, 2024 at 2:37 PM
    Gps1204
    Kahanabob's suggestion fixed it. I finally had time.
    Thanks everyone. I appreciate all of you!!
    Chew and soundman98 like this.
