Garage Door Opener recommendations? Direct Drive / Jackshaft?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Veccster, Jan 22, 2020.
  1. Jan 22, 2020 at 6:41 AM
    Veccster
    Veccster [OP] bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I'm not sure where to put this thread but I'm looking for recommendations on a good garage door opener. I know I can go the standard route with a Liftmaster Chain or Belt drive but I'm looking for something unique. Cost not a concern but functionality and performance is. Quiet would be nice so I was thinking about the Direct Drive units.
    Any recommendations or suggestions?
    Move this to the appropriate forum if necessary. Thought it would be relative because I park my 2020 Tacoma inside :thumbsup::taco:
  2. Jan 22, 2020 at 6:55 AM
    WARPED5
    WARPED5 Well-Known Member
    Ted
    NW IN
    2017 Blue TRD OR
    Veccster[OP] likes this.
  3. Jan 22, 2020 at 7:06 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    My parents have the liftmaster jackshaft opener. It's way quieter than my belt drive liftmaster. My next opener will for sure be a jackshaft one.
  4. Jan 22, 2020 at 7:08 AM
    Genypig
    Genypig Well-Known Member
    Yev
    2018 Tacoma TRD OR
    Here is my experience:
    I've had 3 types. Chain, Direct drive, and belt.
    Chain drives are very strong and quick, but they seem the loudest to me. Mine felt like it shook the entire house while opening. But none the less, opened super quick.
    My parents switched from chain to direct drive recently. It opens quick but still feels much louder than normal. Probably depends on brand and quality.
    I now have a belt driven LiftMaster. It is incredibly quiet but takes a bit longer to open and close. But seriously, it's quiet enough that you can sneak in the house at 12am and potentially not be heard. Im told that belts don't last as long, but mine has yet to break.
  5. Jan 22, 2020 at 7:21 AM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    Shaft-drive openers are great for getting back some overhead space, but they do not hold the door closed. They rely on an external locking pin/solenoid to hold the door down. I think there are also higher incidences of them dropping the cable off the pulleys. These were all concerns I had that made me stick to a traditional-style opener.
  6. Jan 22, 2020 at 7:46 AM
    Veccster
    Eric
    2020 Pro
    Thank you...good information. I do have concerns about the shaft drive systems. I don't have any need for more head space in my garage...ceilings are high and I don't store anything above head. Maybe it's not worth it.
    I'll probably lean toward belt-drive. I do want quiet.
    The belt-drive probably needs adjusted more often as the belt stretches. Even chains need adjusted periodically but not often.
    Yeah, there are a lot of bad reviews on LiftMasters website for the Direct Drive model. Seems like too many issues for me to go this route.
  7. Jan 22, 2020 at 7:56 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    I have a craftsman screw drive opener. It's not the quietest, but it has lasted 35 years without any real maintenance (put in by the previous owner).
    In the 25 years I have been in the house, I have replaced the transmitter and openers, and greased it a couple of times, but that's it.
    shakerhood and GreyBaldTaco like this.
  8. Jan 22, 2020 at 7:59 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I've had my belt driven opener for about 15 years. Goes up and down about 7-10 times per day.
    I've got to say when I replaced my failed chain driven opener with this belt deal, I was not impressed with the perceived durability of the belt. But I was was wrong. It's never failed for any reason and the belt is still within spec as far as tightness. I'd have no issue going with another belt drive should this one eventually go tits up, but will probably give a hard look at the screw drives.
  9. Jan 22, 2020 at 8:04 AM
    BARDENC
    BARDENC Well-Known Member
    Wilmington, NC
    17 SR5 DCSB
    tonered likes this.
  10. Jan 22, 2020 at 8:07 AM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I have two lift master belt driven units that were installed in 2001. I just replaced the belts, for the first time, in both a few months ago. They both get used 3-4 times per day. They are incredibly quiet as well.
  11. Jan 22, 2020 at 8:16 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    This is may not be the most appropriate but is the most populated by you previous gens. And Ranger owners. And Ridgeline white knighters.
    Grindstone and tonered like this.
  12. Jan 22, 2020 at 8:25 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Best garage door opener I ever had was the wall mount lift master 8500. Super quiet, smooth and I loved the electronic deadbolt that auto locked.
    We moved and plan to get those again.
  13. Jan 22, 2020 at 8:29 AM
    Vinci
    Sarasota, FL
    '17 MGM Limited 4x4
    There is a TON of great info on garage door openers on GarageJournal, in case you'd like to read more about them.
    I ended up going with a Craftsman/Chamberlain belt-drive. It's super quiet and quick (IMO).
    With regards to quieting down your door, swap out your rollers with nylon versions with ball bearings. It makes all the difference. Also re-torque all the bolts in the door. I have to do that at least once a year.
  14. Jan 22, 2020 at 8:31 AM
    JoeCOVA
    Joe
    Colorado Springs
    This is good advice. The rollers are often neglected and that track shifts. It’s good to ensure they are tracking well and properly lubed.
    tonered likes this.
  15. Jan 22, 2020 at 8:38 AM
    pralix
    pralix Active Member
    William
    2017 Cement Tacoma TRD Pro
    I recently replaced a Wayne Dalton iDrive with a Chamberlain RJ070 wall mount. I have been very happy with it. It is very quiet. The automatic deadbolt is very nice. The up and down arrows on the homelink mirror now show the status of the door. I would recommend it.
    Grindstone and Veccster[OP] like this.
  16. Jan 22, 2020 at 8:47 AM
    DeusExMachina
    DeusExMachina Well-Known Member
    Denver, CO
    2020 Tacoma 4x4 Sport 6MT access cab
    I have the Liftmaster wall mount/direct drive on a single garage. It gives a lot of additional headroom without having the motor in the center, which is nice. It's quite quiet too. But it is SLOW.
    I could almost open and close my Liftmaster chain drive before the Liftmaster wall mount opens. Not a huge deal, but one complaint. I had it installed because I had designs of installing a lift in the bay but have since changed my mind.
  17. Jan 22, 2020 at 8:58 AM
    Joe671
    Joe671 YouTube Mechanic
    Joe
    Washington State
    2019 Tacoma TRD Off Road
    I went with Chamberlain belt driven when my chain opener finally crapped out. Super quiet. Had no idea that you could buy a hub and use an app to open/ close the garage door lol. Could also set alerts to remind you if the garage door was left open. It has a battery back up in case the power is out. I'm not sure if these features are standard in new garage door openers as this one i have is at least 3-4 years old.
  18. Jan 22, 2020 at 9:21 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. The Chamberlain / Liftmaster MyQ hub is universal. I got one off the Amazon Treasure Truck for cheap. It works pretty well, with the best part being that we can see if our door is open or closed in the app. It would be nice having that integrated into the powerhead of a new opener, but it sure is nice having it for a 5+ year old opener.
    Joe671[QUOTED] likes this.
  19. Jan 22, 2020 at 9:34 AM
    Joe671
    Joe
    Washington State
    Ahhh, didn't know it was universal. I just wanted a quiet garage door opener because the chain one was way too loud. Didn't even know about the hub till my coworker told me about it lol.
    tonered[QUOTED] likes this.
  20. Jan 22, 2020 at 9:34 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    MyQ is pretty awesome. I'd look for one compatible. I've been using one for 4 years. Saved me a trip home to close it a few times. I have it alert me when it's been open more than 10 minutes as typically we close it before then. I also have it auto close at 10pm so we never accidentally leave it open overnight.
    Had a guy working on my house one day. Instead of giving him the garage code, I had him call me when he got to my house and I opened it remotely. I set it up the most secure requiring passwords and such in case someone hacks into it which seems to be common anymore. It's a little more cumbersome having the passwords on it, but I feel better about it.
    shakerhood, Joe671 and tonered like this.
