gamo air rifles
Discussion in 'Guns & Hunting' started by tacomaman06, May 29, 2010.
  1. May 29, 2010 at 7:06 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    who all has a gamo......what do you have? been looking at them...........and some are pretty friggin pricey, but since i live in city limits.......prolly gonna get one for squirrels and rabbits here.
  2. May 29, 2010 at 7:11 PM
    alex1988
    alex1988 Well-Known Member
    Galveston, Texas
    2wd>4wd.... Its all about the cup holders
    I had one that shot 1,000 fps. Pretty badass air rifle, took down squirrels all day long and very accurate. I don't believe it was over 100. Check Academy sports and outdoors
  3. May 29, 2010 at 7:13 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I have the Gamo Nitro Express and it's a great air rifle. It's a tight gun and is very powerful and accurate... The Gamo Big Cat is just as nice and is a bit cheaper also. Good luck with them squirrels. :)
  4. May 29, 2010 at 7:36 PM
    Griztaco
    Griztaco Well-Known Member
    ID
    TRD
    I have a RWS, and a friend of mine has a beemen. When we were kids we absolutly destroyed vermin, both were very good and I'd bet the gamo's are the same way.
  5. May 29, 2010 at 7:48 PM
    86ceeten
    86ceeten Well-Known Member
    Brian
    NW Florida
    08 TRD Off Road PreRunner
    Limo tint, 18x10 Diamo Karat, Toyo 285-60's, Rear TSB, 5100's all around, front at 2.5", Debadged, Sound System (evolving)
    Silent Cat with a 3x32 scope. Awesome air rifle. 1200 fps with the pointed pellets.
  6. May 29, 2010 at 7:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the silent cat is what im leaning towards.
    the bone collector air rifle they have is nice too.....but way up there in $!!
  7. May 30, 2010 at 10:58 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I'll be getting one this year for pigeons. 1100ft/sec minimum for my taste.
  8. May 30, 2010 at 3:06 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  9. May 30, 2010 at 5:10 PM
    Packman73
    2007 TRD Off Road
    My in-law's Ruger takes quail down no problem. I might just get one of those. A refurbished one is fairly cheap; ~$70.
  10. May 30, 2010 at 5:16 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    anyone shoot the gamo whisper?
  11. May 30, 2010 at 5:28 PM
    Gauntlet
    Gauntlet Active Member
    Oswego, N.Y.
    2010 TRD Off Road Access Cab
    Personally, I prefer my issued Remington model 700 TWS with a Leupold mark IV scope, firing Federal .308, 168 boat tails. It is great for anything with four or even two legs. :rolleyes:
  12. May 30, 2010 at 5:42 PM
    Rumnhammer
    Rumnhammer Member
    Baltimore MD
    2010 Silver Access cab 4wd SR5
    Backup camera switch,charcoal filter removed,front mudflaps trimmed
    I have a Gamo Viper, modded into a super Viper. All the seals replaced, the lubes replaced, luther-Walther barrel, and a replacement spring. Oh and a two stage tuned trigger.
    It is a tack driver.
    I had all the work done by a guy called Rich in Michigan. He does fantastic work. and you will get a world class gun back, that shoots nothing like the stock Gamo.
    Here is a link to his site.
    My Homepage
    The Viper with the full Q shroud pic is my rifle.
    I take Squirrels regularly with little effort out the dining room window.
    even if you don't mod it, the stock gamo is a great air rifle.
    Chris Rummel
  13. May 30, 2010 at 5:59 PM
    Packman73
    2007 TRD Off Road
    Let's keep the apples with the apples and the oranges with the oranges.
  14. May 30, 2010 at 6:09 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    I had two gamos, A Big cat and a Hunter extreme, they are pretty good guns, I ended up trading the two of them for a savage .22 so no more pellet guns.
  15. May 30, 2010 at 6:15 PM
    Dimonback
    Dimonback Well-Known Member
    Patrick
    Austin, Tx, from all over hell and back
    Geezer double cab w/ shell
    I picked up a Winchester pump up just because I'm in a suburban area and wanted lower velocity (less worry about how far it'd go if I missed). It does a good enough job on my pigeon problem even at only half power.
    If you're going to go at 1000fps or less, why not use a .22 rifle with CB caps...? About the same noise, and likely as accurate as your high priced air rifles. When I used them on skunks in Colorado, I could watch the bullet.
  16. May 30, 2010 at 8:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i have a couple of .22's......but want a better pellet gun than the old pos ones from walmart that i used to have as a kid. plus....they are pretty fun to shoot.
  17. Jun 1, 2010 at 7:07 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    x2. Even though I ended up buying a cheap'o one, Im still shopping around looking for a good break over barrel pellet gun.
    where do you find refurbed ones?
  18. Jun 1, 2010 at 11:10 AM
    nitrus5
    nitrus5 Well-Known Member
    Have you guys looked into the Refurbished Air guns? Most of them have a decent warranty. I've been wanting to get one just can't seem to decide which one. I seen Cabela's has acouple on sale that are new and some that are refurbs.
  19. Jun 4, 2010 at 3:06 PM
    Packman73
    2007 TRD Off Road
  20. Apr 22, 2012 at 9:56 AM
    Teniente
    Teniente Well-Known Member
    Carson City, NV/Ensenada, Baja California, MX
    White 2006 SR5 DCSB 4x4
