FYI: My complete steps for driver side valve cover replacement on 5VZ-FE
Discussion in '1st Gen. Tacomas (1995-2004)' started by JustADriver, Nov 30, 2022.
  1. Nov 30, 2022 at 10:06 PM
    JustADriver
    JustADriver [OP] Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    I had to revise this as I went and was meticulous at documenting each step and labeling hoses and wires with the number of the step so that I could reassemble without stress. In the end it went well. Passenger side is a no brainer in comparison. The old gaskets were all OReilly garbage.
    1. Disconnect battery
    2. Disconnect 2 valve hoses from valve in front of throttle body
    3. Disconnect hose from plenum to power steering
    4. Disconnect hose from EGR to intake tube
    5. Disconnect hose on intake tube resonator
    6. Loosen clamps and remove intake tube, set aside
    7. Disconnect throttle cables
    8. Disconnect 3 small air hoses from throttle body
    9. Disconnect PCV hose
    10. Disconnect wire for middle engine coil by throttle body
    11. Disconnect IAC valve wire
    12. Disconnect EGR wire with brown clip
    13. Disconnect TPS wire with black clip
    14. Disconnect IAC air hose
    15. Unbolt throttle body nuts and bolts, pull off throttle body from studs
    16. Disconnect coolant hoses from throttle body, plug hoses
    17. Set throttle body and gasket aside
    18. Unclip wire harness above AC valves
    19. Unbolt ground wire nearby on back of engine bay
    20. Unclip vacuum modulator valve, remove hose, set valve aside.
    21. Disconnect throttle kickdown cable from bracket clips, unbolt bracket
    22. Unbolt 2 EGR pipe brackets
    23. Unbolt EGR pipe on both ends, pull off studs, remove used gaskets to be replaced
    24. Disconnect small upper air hose from EGR
    25. Disconnect upper coolant hose from EGR
    26. Unbolt EGR valve, set aside
    27. Unbolt diagnostic port ground wire
    28. Pull diagnostic port off clip
    29. Disconnect brake booster hose from intake plenum
    30. Disconnect evap hose from top of plenum
    31. Disconnect large air hose next to evap hose from top of plenum
    32. Disconnect valve wire with green clip
    33. Disconnect top air hose from brown valve
    34. Disconnect wire from brown valve
    35. Unbolt bracket holding green and brown valves, pull away.
    36. Disconnect lower hose from brown valve, set valves and bracket aside.
    37. Unbolt 4 bolts and 2 nuts from upper plenum, lift off plenum and gasket.
    38. Unbolt front valve near PCV valve from lower plenum, set aside.
    39. Remove lower bolt of large black bracket, pull away
    40. Unbolt 2 brackets holding lower fuel line to middle plenum
    41. Remove nuts and bolts from middle plenum including horizontal bolt to plastic wire harness in rear. Pull off plenum and gasket and set aside.
    42. Cover intake holes with tape and towel
    43. Unclip 3 fuel injector wires
    44. Repair plastic cover of wire harness with Tesa high heat harness tape, to make sure no plastic pieces will fall into engine.
    45. Pull out spark plug boots, unclip wires from timing cover, move away
    46. Unclip wire harness from passenger side valve cover
    47. Move radiator hose clamp a few inches away from timing cover so the cover can move
    48. Unbolt timing cover bolts to pull timing cover away a few inches
    49. Unclip wire harness from engine mount
    50. Unbolt 8 valve cover bolts
    51. Remove valve cover
    52. Remove cam seal
    53. Remove half moons
    54. Clean mating surface on engine
    55. Apply sealant to half moons and reinstall. Install bolts only hand tight.
    56. Apply sealant to cam seal and reinstall. Install bolts only hand tight. Do not torque yet.
    57. Remove tube seals and valve cover gasket
    58. Clean valve cover
    59. Install new tube seals and valve cover gasket
    60. Apply grease to inner surface of tube seals for spark plug tubes to slide on
    61. Torque cam seal bolts when 1 hour has passed for sealant to set, or depending on sealant instructions.
    62. Apply sealant to engine mating surface on required spots.
    63. Reinstall valve cover. Install bolts only hand tight. Do not torque yet.
    64. Work backwards from step 49 to start reassembly. Stop before reconnecting fuel injectors.
    65. Torque valve cover bolts to 53 in-lb when 1 hour has passed for sealant to set.
    66. Continue backwards through reassembly steps, cleaning mating surfaces as needed, installing new plenum gaskets, EGR valve gasket, EGR pipe gaskets, and throttle body gasket when you get to them.
    Taco! and Area51Runner like this.
  2. Nov 30, 2022 at 11:00 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    :worthless:
    J/K ;)
    Thx for taking the time to list the steps you took and putting it out there for everyone else.
    Cheers :cheers:
  3. Nov 30, 2022 at 11:10 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    You're missing a few VERY important steps. I don't see any steps that include dropping the 10mm socket into an impossible to reach location, swear breaks, or scheduled time to check TW for torque specs... Other than that, looks great.
  4. Nov 30, 2022 at 11:15 PM
    JustADriver
    Yeah pics would be huge I know, but too much trouble! I wasn't sure I was going to share it or even be successful.
    If someone uses this along with Timmy's video (which omits a lot of small steps and I don't think his truck had an EGR system), that should cover everything.
  5. Dec 1, 2022 at 8:05 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Just did this job on both sides. It's quite nice not smelling burnt oil after driving :) Nice write-up! I ended up replacing every vacuum line I could. That helped quite a bit.
  6. Dec 1, 2022 at 12:10 PM
    JustADriver
    It feels good to get done! Pending dry weather to leak check it. I think those cam seals were the leak culprit, just from getting old and not being replaced by the shop when doing their shitty gasket job. I managed to do it all without dropping any nuts or breaking anything except a wire harness clip.
    Area51Runner likes this.
