Fuses for accessory power ports
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dlarso, Oct 26, 2021.
  1. Oct 26, 2021 at 11:52 AM
    dlarso
    dlarso [OP] Active Member
    Dave
    2018 TRD 4X4 Offroad
    2" lift front/back
    My in-dash and console power ports have gone dead. Does anyone have a map of the fuse boxes that might show me where to look? The service manual is alarmingly void of any meaningful direction.
  2. Oct 26, 2021 at 12:00 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    If I am not mistaken, under the left side of the dash is a fuse box. Remove the cover and there should be a fuse map on the cover. Replace the fuse with quality fuse, not some Amazon junk.
    dlarso[QUOTED][OP] likes this.
  3. Oct 26, 2021 at 12:20 PM
    zDirtyDeedz
    zDirtyDeedz @FlatironsOverland
    Dylan
    Boulder, CO
    '19 White DCSB
    The fuse for the in-dash cigarette lighter port can be found under the dash to the left of the steering column. The fuse in question is a 15 amp low-profile mini blade fuse, and on the fuse box lid is labeled as "P/OUTLET NO. 1".
    How did you blow them? Any normal car charger shouldn't do that
    dlarso[OP] and Speedfreak like this.
  4. Oct 26, 2021 at 1:07 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    This might help
    Speedfreak likes this.
  5. Oct 26, 2021 at 7:40 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Note there are some slight changes between yrs/models
  6. Oct 27, 2021 at 4:24 AM
    brandon78lusch
    Brandon
    ah
  7. Oct 31, 2021 at 3:14 PM
    dlarso
    Dave
    2" lift front/back
    Thanks to everyone (I couldn't figure out how to thank each of you individually). Appreciate your responses. I found that fuse box. It was a bear to get down to pop the cover off and I bet it'll be harder to put back.
    [As it happens it was a "snap" to put back on]
    Now to see if my fuse puller works. Here's what the fuse cover looks like to anyone who may need.
    [The fuse-puller, that's supposed to come with your Taco when you buy it new, wasn't included. When I went to the dealership they gave me another puller 'cept not the right size (was too wide). So I still don't have either of those power outlets.]
  8. Nov 11, 2021 at 12:51 PM
    dlarso
    Dave
    2" lift front/back
    zDirtyDeedz - The only thing I have plugged in is my dash cam. I'm guessing that's the problem. I've had it since 2018 and never had a problem with it before, but i guess it's just getting old and crappy. Not terribly unlike the Throttle Commander I had for better throttle response. After a couple years it started screwing with my engine control computer and I had to take it out.
