Fuses continue to blow
Discussion in 'Lighting' started by Spicy.x.Taco, Sep 30, 2017.
  1. Sep 30, 2017 at 11:16 PM
    Spicy.x.Taco
    Spicy.x.Taco [OP] Active Member
    Ben
    Reno,NV
    17 TRD Off-road
    3 inch SDT lift. 2 inch wheel spacers. Rigid Industries D-series Midnight Edition Ditch Lights. Tacomabeast door decals. TEQ Hood decal.
    Need help with ditch lights. I recently installed some Rigid Industries D series midnight edition ditch lights to my 17 Taco. I continuously blow fuses as soon as I flip the switch to turn them in. I've attached the ground wire and the power wire to different spots multiple times and have tried higher powered fuses than the 15 that they provide and I have no wires exposed. Any ideas on what might be wrong? Should I just buy the cigarette lighter wire for power that has the switch on it from rigid?
    MotoEd likes this.
  2. Sep 30, 2017 at 11:44 PM
    Faheygf87
    Faheygf87 Well-Known Member
    2016 Blue TRD Off Road MT
    Pretty hard to diagnose without actually seeing it. Was it a kit that you bought or just the pods?
    If it was just the pods, how do you have them wired? Straight from the battery with a switch in-line or with a relay?
    Pictures of the wiring would be helpful.
  3. Sep 30, 2017 at 11:57 PM
    Spicy.x.Taco
    Ben
    Reno,NV
    17 TRD Off-road
    It was a kit that I bought from a shop here in Reno called Custom Truck Accessories. They sell a kit that includes the pods and wires and a switch. The brackets were the only things not included
  4. Oct 1, 2017 at 12:01 AM
    Faheygf87
    I'd take it back, or at least demand they look at it.
    If it was meant to be plug and play, and it doesn't work, then it doesn't work.
  5. Oct 1, 2017 at 12:04 AM
    Spicy.x.Taco
    Ben
    Reno,NV
    17 TRD Off-road
    Yeah that's what I was thinking. I just don't want them to charge me for simply. Seeing what's wrong.
  6. Oct 1, 2017 at 12:21 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    2005 Silver DCLB 4x4
    ARE Shell. Pelfreybilt front bumper. hi-clearance rear bumper w/swing out. Rigid light bar/fog lights/reverse lights. Pelfreybilt front skid. Home/hand made slidders. DR front coilovers. Camburg UCA. AllPro Expedition leaf pack w/u-bolt flip and Timbren bump stops. 285 70-17 on stock rims with Spider Trax wheel spacers. EBC slotted/drilled rotors with green pads.
  7. Oct 1, 2017 at 12:24 AM
    Spicy.x.Taco
    Ben
    Reno,NV
    17 TRD Off-road
    :cheers:
    MotoEd[QUOTED] likes this.
  8. Oct 1, 2017 at 12:25 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    Hope it's a quick fix-a-ru for you tomorrow.
  9. Oct 1, 2017 at 12:27 AM
    Spicy.x.Taco
    Ben
    Reno,NV
    17 TRD Off-road
    Yeah I'll definitely let you know
  10. Oct 1, 2017 at 1:05 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    What amperage was the fuse? Did the kit include a relay? Edit - I see 15A fuse, that should warrant the use of a relay since switches generally go up to 3A or so. Still, blown fuses mean current draw is way more than it should be so there's a short somewhere in the kit on the + side.
    Look for discolored wire ends or arc damage, a 15A arc will leave traces.
  11. Oct 1, 2017 at 1:27 AM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Could the ground wire (-12v) and the hot wire (+12v) possibly be swapped? If the +12v wire was connected to the case of the lights and that was grounded to the truck, the fuses would blow immediately when the switch was turned on.
    Spicy.x.Taco[OP] likes this.
  12. Oct 1, 2017 at 8:41 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    lol, demand? how about just ask nicely lol
    start looking at your wiring. something is wrong. start with the lights. hook each light up to the battery to see if it works. then work your way back.
    o0oSHADOWo0o, Radarninja and MotoEd like this.
  13. Oct 1, 2017 at 9:10 AM
    MotoEd
    MotoEd Ed-MotoEd
    Ed
    Northern NV
    I like this approach. Keep it simple stupid. That's what I was taught at my mechanics school
