Fuse location for wiper fluid motor??
Discussion in 'Technical Chat' started by surfsupl, Oct 15, 2013.
  1. Oct 15, 2013 at 6:22 PM
    surfsupl
    surfsupl [OP] Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    anyone know where the fuse is for the wiper fluid motor? My wipers work just fine but since Saturday it quit squirting wiper fluid on the windshield. (yes their is fluid)
    2nd gen
  2. Oct 15, 2013 at 6:28 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    the compartment by ur left knee, open it, and then pull it up/out.
    bottom left 10a fuse
  3. Oct 15, 2013 at 6:34 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    my phone wont upload to TW live for some reason.
    if ur still lost, PM me ur number and I can text u a pic
  4. Oct 15, 2013 at 6:40 PM
    surfsupl
    Gregg
    WestCoast
    I saw that fuse marked as WSH , I wanted to double check
  5. Oct 15, 2013 at 6:47 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    thats the one.......... I used an add a fuse on it for one of my gauges, and I can tell ya that the washer motor will NOT work with that fuse out :)
    atleast it didnt when I tried
  6. Oct 16, 2013 at 7:55 AM
    surfsupl
    Gregg
    WestCoast
    I found it kind of odd that the fuse blew out. I use the wiper fluid motor maybe 3 times a week mostly when under trees. This is the first truck/car I have had this problem. Who knows :notsure:..................I guess it bets a major issue:)
  7. Oct 16, 2013 at 4:10 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I wouldn't worry yet.... Could be as simple as a bad fuse.
    Keep an eye on things and let us know if it happens again.
    Off topic, have u tried rain x?
    I love that stuff.
  8. Oct 20, 2013 at 10:31 AM
    surfsupl
    Gregg
    WestCoast
    Replaced fuse, still nothing. I found a replacement pump for 20.00. I'm going to check a couple other things b/4 ordering it.
  9. Aug 19, 2017 at 2:23 PM
    surfsupl
    Gregg
    WestCoast
    Pump quit working again. fuse good/new pump installed. Still nothing. Is their a relay for this? Another fuse besides the 10 amp by my left knee?
    Thanks
  10. Nov 29, 2017 at 9:55 AM
    roseserv
    roseserv New Member
    '08 Tacoma ExtCab. 4x4
    Did you find a solution to this? My wiper pump just quit as well. Working one day then the next day it wasn't! Fuse is good and check the wiring(as much as I could). Maybe something to do with the harness that was recalled or a problem with the switch arm?
    Checked the fuse box on the drivers side wheel well in the engine compartment. Didn't see a fuse there.
    BTW: On my truck the fuse is a 30amp.
    Thanks for any assistance.
  11. Nov 30, 2017 at 7:28 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    so you will want to check if voltage gets applied to the pump, remove the electrical connector and probe the terminals (just make contact, dont bend them) while having someone activate the switch and see if there is 12V, if there is its the pump, if not you need to check the wires, with a wiring diagram check if its power or ground switch, (if the switch is before or after the load) most things are power switch but not all. after finding this out ohm out the wires, you want less then 5 ohms of resistant at the absolute most, most wires have 0.X ohms but 5 ohms is a very definitive problem, if the ohm reader(multimeter) read OL then you have a open in that wire, find the open and fix it.
  12. Dec 2, 2017 at 12:21 PM
    roseserv
    roseserv New Member
    Thanks for that Joey, was hoping there may have been a common solution for this. It seems a few people have had this problem. Now that I'm back in town, am pulling out the multi-meter and going to trace down the fault. Will post what is found later.
  13. Dec 23, 2018 at 1:24 PM
    KevinTaco98
    KevinTaco98 Well-Known Member
    Kevin
    1997 3.4L Tacoma
    None yet :D
    Did you ever find out what it was lol? Changed the fuse out and that didn’t fix it. So it’s probably the pump. I don’t hear any noise at all from it
  14. Dec 25, 2018 at 6:15 AM
    roseserv
    roseserv New Member
    Yes, thought I had posted a response, must have been on another site. lol
    It was the pump motor, made the mistake of checking for voltage while the motor was still connected. Pulled the connector and got voltage when the switch was activated. Replaced the pump.
    Still, never had a pump just stop working like that, usually make some noise or work poorly first.
  15. Dec 25, 2018 at 8:24 AM
    KevinTaco98
    Kevin
    1997 3.4L Tacoma
    None yet :D
    I thought so because I changed the fuse and if it was just clogged I would at least hear the motor which I didn’t. I’ll change it out and see what happens thanks
  16. Jan 4, 2023 at 10:30 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Having problems as well, but the fuse is good. Suggestions? Im not the most electrical savy so im not sure how to test the motor
  17. Jan 6, 2023 at 3:02 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Do you have a Volt meter check for voltage at the pump pumps do not last forever.
  18. Sep 16, 2023 at 9:11 AM
    Chuck Norris#1
    Chuck Norris#1 New Member
    2012 Black Tacoma 4x4
    My pump was not working so I checked the fuse (30a) and it was good. Plugged the fuse back in and what do you know? It works again. So pull fuse out and put back in just to rule that out.
