fuse box removal - for that 80A fuse ( 1999 2.4L)
Discussion in '1st Gen. Tacomas (1995-2004)' started by BeyondxB, May 3, 2018.
  1. May 3, 2018 at 8:24 AM
    BeyondxB
    BeyondxB [OP] Member
    1999 Taco 4x2 auto
    dents. lots of dents.
    Hi everyone so I was dumb and blew the 80A fuse, I am trying to find instructions on removing the fuse box to get to the 80A fuse that's secured by bolts.
    The closest thing I found was this video https://www.youtube.com/watch?v=LO9UgFbt1tY ,
    but it is not the same.
    My 1999 tacoma fuse box have 4 tabs that protrudes out of the side almost 1/4" , and they are really tight fitting.. i can't push them in much at all.
    So I want to ask here first before I monkey my way and break the tabs in/out :
    How to do you get to that 80A fuse!?
  2. May 3, 2018 at 8:48 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    My 5-Lug blew a metric ton of fuses in and outside of the cab, including the main 80A fuse in the engine bay fuse box after someone reverse-jumped it. What you have to do is remove the 3 bolts that hold the fuse box to the truck, and push in the plastic retaining clips separating the top and bottom of it. The 80A fuse is held in with a bolt, which is why it doesn't pull out like your traditional fuse.
  3. May 3, 2018 at 8:58 AM
    BeyondxB
    1999 Taco 4x2 auto
    Thanks for the reply!
    Push " in " you say? Ok I wanted to make sure, because that's a LOT of tab to push in. Heck they are not even a tab they are more like a solid plastic knob.
    Thanks!
  4. May 3, 2018 at 8:59 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Take a picture of the mechanism, let's make sure it's the right one. Lol.
    mechanicjon likes this.
  5. May 3, 2018 at 9:37 AM
    BeyondxB
    1999 Taco 4x2 auto
    I see three tabs/knobs, one on top middle, one on lower left, and one on bottom right. .... Thanks!
  6. May 3, 2018 at 10:27 AM
    BeyondxB
    1999 Taco 4x2 auto
    The truck is in the office parking lot so I have to wait until lunch time to go try it again
  7. May 3, 2018 at 11:37 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Those are the right tabs. Push inwards and down while simultaneously pulling up on the housing.
  8. May 3, 2018 at 9:32 PM
    BeyondxB
    1999 Taco 4x2 auto
    Ok it was a giant PITA and I end up calling BCAA and it took the two of us over 30 minutes to wrangle it out. Basically had to destroy all three tabs and yank the bottom half away to get to the bolts. A lot screw driver jabbing and prying right behind your wiring harness.
    But at least we got it done and luckily it was only the 80A fuse and everything else was still good.
    After changing the fuse I am back and running in less than 10 minutes.
  9. May 3, 2018 at 9:41 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Damn was it that hard it took me like 10 minutes haha
  10. May 3, 2018 at 9:49 PM
    BeyondxB
    1999 Taco 4x2 auto
    I don't think the fuse box has been touched since it came off the assembly line 19 years ago so yeah, it was SNUG.
    It's pretty loose now though! Hhahahaha
    But that 80A fuse placement is still terrible.
    BartMaster1234 likes this.
  11. May 6, 2018 at 8:53 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I lifted the top part out. there's 4 tabs that hold the relays and fuses part. Left the bottom bolted down. Grab the inside part with apair of needle nose and lifted while prying the 4 tabs out.
  12. May 6, 2018 at 8:55 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    like this.
  13. Apr 1, 2020 at 4:40 PM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
  14. Apr 1, 2020 at 6:07 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Identical, the fuse box physically never changed from 1995-2004.
    jeg0005[QUOTED] likes this.
  15. Apr 1, 2020 at 6:10 PM
    jeg0005
    Jon
    BHM, AL
    Good. Because I had a stupid mishap today and the truck is dead. I found the ALT 120a fuse was blown, hopefully that fixes it and I didnt fry the ECU or anything.
  16. Apr 1, 2020 at 6:12 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yup that's what that fuse is for. I reverse jumped my old blue truck and it blew the 120a fuse, and the EFI fuse blew.
  17. Apr 1, 2020 at 6:15 PM
    jeg0005
    Jon
    BHM, AL
    I'm glad to know I'm not the only one!
  18. Jan 4, 2021 at 10:03 AM
    Mavigogun
    Mavigogun Well-Known Member
    1998 Tacoma X-Cab SR 5 2.4L L4 SOHC 16V
    I’m still struggling to separate the upper portion of the fuse box. In the attached image, I have a screw driver inserted behind the catch tab, levering it open. The second image shows the same tab without the driver; behind the tab is a protruding D-shaped element- while levering the tab open, this D-element may be forced back into the box- but not completely, and not without risking destruction of the tab and surrounding bezel. It sure seems that just levering the tab open is insufficient remedy for freeing the upper portion of the fuse box. Any insight will be appreciated- but please, please, be painfully explicit, with hand-here-tool-this-way instruction, because I’m missing something.
  19. Jan 4, 2021 at 10:21 AM
    Mavigogun
    Update: I got it after reviewing previous images and discarding this account by mechanicjon:
    “I lifted the top part out. there's 4 tabs that hold the relays and fuses part. Left the bottom bolted down. Grab the inside part with apair of needle nose and lifted while prying the 4 tabs out.”
    Contrary to this claim, it’s impossible to separate the upper and lower box without unbolting the box on my ‘98- and the inner, lower portion of the box can’t be pulled up-and-out. If you are struggling, unbolt the box, lever all the tabs out, and it will easily separate by reaching into the box and pushing with one hand while holding the outer box with the other.
    Arctic Taco likes this.
