Functional hood scoop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by darkyota33, Dec 17, 2018.
  1. Dec 17, 2018 at 8:58 AM
    darkyota33
    darkyota33 [OP] Well-Known Member
    AJ
    Upstate NY
    '05 TRD Sport, 4x4 Manual 6 spd trans, Black.
    Replaced engine with an '07 FJ Cruiser motor. Clutch accumulator deleted. WIP. plan to add new exhaust, cold air intake, URD short throw shifter,
    Just wondering, has anyone tried to make the hood scoops on the TRD sports functional?
    Looking at cold air intakes. K&N's is probably fine, but pulls air from under the hood.
    URD's "true" cold air intake looks good, although I'm not sure it's as plug-and-play re: incorporating all the stock connections to the air dryer assembly.
    can't help but thinking:
    if i'm going to go through the trouble of installing a new cold air intake....
    and I have a hood scoop...
    is there a kit that you can bolt on to get the air from the scoop directed through the air filter?
    anyone customized one?
    thanks!
  2. Dec 17, 2018 at 9:01 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    No point at all. The stock intake pulls air from the fender well anyways, and is essentially a CAI. Even if you pulled slightly cooler air from somewhere else, you're not going to gain anything. I can monitor intake air temp via my ultragauge and at speed, it's only a few degrees warmer than outside temp.
    vtown, TacomaMike37 and TacomaSport86 like this.
  3. Dec 17, 2018 at 10:00 AM
    darkyota33
    AJ
    Upstate NY
    Oh wow, really? Okay. yeah I was wondering how much of a difference it makes. advertised as 10+ horses on the vendor websites, but i always question those. thinking like an old hot rodder I guess! thanks!
    EatSleepTacos likes this.
  4. Dec 17, 2018 at 10:02 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    It would cost too much.
    Plus who cares? Its a truck not a race car. It looks cooooo and thats all that matters.
    23MGM, JCVD and darkyota33[OP] like this.
  5. Dec 17, 2018 at 10:22 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you want to make it functional, just cut a hole in it and that'll let heat escape better while sitting in traffic. Or you can mount a small light bar in there which is cool.
    JCVD, Fatmonk8 and darkyota33[OP] like this.
  6. Dec 17, 2018 at 10:24 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
  7. Dec 17, 2018 at 11:07 AM
    darkyota33
    AJ
    Upstate NY
    LOL!! omg, that is hilarious. :bananadance:
    is this the only thing the hood scoop is good for!?
  8. Dec 17, 2018 at 11:22 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Drill a bunch of holes in it, get back to us....
    johnnybuck2 and darkyota33[OP] like this.
  9. Dec 17, 2018 at 11:24 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    All I’ve seen posted in threads asking this question of functionality is that the scoop sits in a spot that essentially sees no direct airflow when actually driving.
    darkyota33[OP] likes this.
  10. Dec 17, 2018 at 12:44 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
  11. Dec 17, 2018 at 12:44 PM
    TegoTaco
    Ontario, Canada
  12. Dec 17, 2018 at 12:45 PM
    TegoTaco
    Ontario, Canada
  13. Dec 17, 2018 at 12:52 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
  14. Dec 17, 2018 at 1:30 PM
    darkyota33
    AJ
    Upstate NY
    JayRolla likes this.
  15. Dec 17, 2018 at 1:38 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    If you ever watch water drops dance along the hood while driving you’ll see there is minimal movement from them as they run up your hood. This is due to the aerodynamics of the front of the truck that pushes air up and over the hood and creates a lower pressure zone for about 1.5-2” above the hood.
    Ever stick your hand out the window while driving and find that spot where it feels like your hand is sucked in closer to the vehicle. Kind of like that.
  16. Dec 17, 2018 at 1:40 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Just build a custom sheet metal cold air pan/ box that seals to the hood , pretty simple and easy way to get cold air
    I know this is a carb set up but you'll get the idea , this is on my drag race car !!! and it allows cold air from the cowl windshield area
    darkyota33[OP] and JayRolla like this.
  17. Dec 18, 2018 at 7:07 AM
    darkyota33
    AJ
    Upstate NY
    Oh yeah! now we're talking. :headbang: drooling over that thing already.
    just wish I could afford that! any way to get them cheaper??
    JayRolla[QUOTED] likes this.
  18. Dec 18, 2018 at 7:13 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    buy a used one or broken kit and rebuild it
  19. Dec 18, 2018 at 8:04 AM
    JayRolla
    Colorado Springs
    I was about to drop $5k on supercharger for my Caddy. Now decided to do 150 shot nitrous and will be about $1200. Could give her some juice. Haha.
  20. Dec 18, 2018 at 8:06 AM
    darkyota33
    AJ
    Upstate NY
    I'm down! i'll look for that. put a feeler out already on car-part.com to see if any salvage yards have one.
    depending if I can rebuild my engine or need a whole new one will make a difference in the budget
