Fumoto Valve/Oil Change Drain Plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yaozer, Nov 5, 2013.
  1. Nov 5, 2013 at 8:35 AM
    Yaozer
    Yaozer [OP] Well-Known Member
    North Jersey
    2011 Red DCSB TRD Sport
    Flowmaster exhaust, 3" Old Man Emu lift, Konig Countersteer Rims, and too much more.
  2. Nov 5, 2013 at 8:49 AM
    zk6760
    zk6760 Well-Known Member
    SLC, UT
    2010 Off Road
    Just got it!
    I had one on my Subaru and it was one of the first things I purchased for the Tacoma. If you're worried about damage there are some skid plates that will protect the drain valve. As for leaking, I've not once had a drop come out of it in the 3+ years that it has been on my vehicles. You can buy a small retainer clip to put around it to make sure the lever doesnt get snagged on anything as well.
  3. Nov 5, 2013 at 8:53 AM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    I added one. It's been great so far.
    In retrospect I would get the F-103S.
    umpi5 likes this.
  4. Nov 5, 2013 at 8:55 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    It's not specifically for a Prius, it's threaded to fit many vehicles. Read the Amazon reviews and there's a few Tacoma owners listed. If you're worried about damage and don't intend on using a tube, there's also the F-103 (doesn't have the nipple so it's lower profile) http://www.amazon.com/Fumoto-F-103-Engine-Drain-Valve/dp/B003UT6LCO/ref=pd_sbs_auto_1 I plan on getting one once my Toyota Care runs out.
  5. Nov 5, 2013 at 8:59 AM
    Yaozer
    North Jersey
    Thanks for the clarification. I'd like one with the nipple. I may pick these up for the 2011 Taco, my wife's 2010 Prius, and my mom's 2011 Accord. This looks promising.
  6. Nov 5, 2013 at 9:10 AM
    ziggynagy
    Stoughton, MA
    Make sure to check the sizing... Honda Accords are 14mm so you'll be an F-106 Fumoto. Most Toyotas are 12mm and use the F-103.
    Couple decent sites to check what size you'll need for your vehicle:
    http://www.qwikvalve.com
    http://www.fumotousa.com/size_import.htm
    CharlieVictor likes this.
  7. Nov 5, 2013 at 9:40 AM
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    I've used them on my trucks prior to this Tacoma. I changed the oil at 1100 miles and installed the short nipple version, and I prefer it over the full nipple valve.
    These valves are very high quality and you will not have any leak issues. In total, I probably have around 120K miles using them, and have never, ever had one drop from leakage.
    If you get one, don't use a big honkin' wrench to tighten. A small 6" crescent works great. They don't have to be super tight. They come with a very nice sealing crush washer. Good luck.
    REDdawn6 likes this.
  8. Nov 5, 2013 at 10:15 AM
    Yaozer
    North Jersey
    Thanks Zig and DE. These valves are really cool. Man, wish I saw these earlier. I'd be concerned about trail damage as well. However, I saw photos in another review with some guy that dinged up his oil pan on a rock after he came down right on the valve. The valve was fine, but his oil pan was toast.
  9. Nov 5, 2013 at 10:22 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    the irony heh
    ChadsPride likes this.
  10. Nov 5, 2013 at 10:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have one and love it!!
    But I agree...if you're wheeling, you don't want one of these unless you have an engine skid plate (or some other armor to protect the oil pan).
  11. Nov 5, 2013 at 10:26 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I've always thought about getting one, but I'm more worried about the malicious A-hole who might notice the valve there and drain the oil out of my truck just for the heck of it...
    hoverlover likes this.
  12. Nov 5, 2013 at 10:35 AM
    Tao Zero
    Tao Zero Well-Known Member
    I had one on my Ford which made draining 4 gallons of oil very easy. Also works great when you need to fill the small container and send it off to Blackstone. I will be getting one for my Tacoma. You can drain the oil right into the milk jug, turn it off when the jug gets full and get another!
  13. Nov 5, 2013 at 10:42 AM
    Janster
    Jandy
    Lancaster, PA
    Always take notice to puddles of oil under your truck.......
    Get one because its convenient for you. By not buying one, you're letting the A-hole dictate your livelihood. :p
    Don't piss anyone off. LOL
  14. Nov 5, 2013 at 10:59 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    You can back up the ball valve with a nylon zip tie which also will help stop malicious mischief. A Glock 23 also works well for that. :thumbsup:
    This is the one I have and I love it! I put an empty 5.5 quart laundry detergent bottle down there open the valve. No mess! :D
    sodak and ChadsPride like this.
  15. Nov 5, 2013 at 2:23 PM
    steviestyles
    Colorado Springs
    Bone Stock
    True, but there's a reason we lock our doors at night as well.
  16. Nov 5, 2013 at 2:29 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    I've used Fumoto valves on my Toyotas since 2002. I've never had an issue with fit, accidents, etc. And I've wheeled, although not as hard as some guys here.
    The only thing you may run into is the Honda's have a recessed area where the oil plug is. I had to send one back to Qwik Valve (Fumoto seller) because even with an adapter, the clearance was very tight and I couldn't close the valve fully.
  17. Nov 5, 2013 at 2:31 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    I got one when i changed my oil last weekend.. It was super easy to install and it hasnt leaked any oil. I say go for it, i got the one with the nipple(i dont wheel super hard) and if someone wants to drain my oil well.. idk lol.
  18. Nov 5, 2013 at 5:56 PM
    BradyT88
    BradyT88 Well-Known Member
    Any of you guys running these with skid plates? Just curious if they fit or not? I can't recall how much clearance I have at the moment and am not currently near my rig to check.
  19. Nov 5, 2013 at 6:09 PM
    Agent Smith
    Yes, I am, albeit only factory skids, I'm thinking you have nice custom ones though.
  20. Nov 5, 2013 at 6:20 PM
    BradyT88
    Yep. Haha. 1/4" thick steel. I can practically bend the factory ones with my hands... so they were gone quickly.
