Fuel Trophy - 17x8.5
Discussion in 'Wheels & Tires' started by SpeedStar, Apr 8, 2014.
  1. Apr 8, 2014 at 8:21 PM
    SpeedStar
    SpeedStar [OP] Active Member
    Chula Vista,Ca
    2012 PreRunner DCSB TRD Sport
    5100s at 1.75", rear 4pack.
    I was searching for new wheels for my Tacoma. Went with Fuel Trophy. They have two offsets, +6mm and -6mm. I went -6mm for a wider stance. Still stock 265/65 tires but they stick out about 2.25" wider. I like the stance. Also I have Billies at 1.75" up front. Just thought I would post in case anybody else was looking into these. 4uqeqydy_6f7767a009f8e16d0814a36d8081b6667a4af493.jpggabegeqa_1726b4636c11d26153e3ffd0f05e257a3059e904.jpgyty7emaj_fdf124774cfae951544a25eff85082f6911027db.jpgme8azeme_fc5850a3ee4eed314153361938a549727a831975.jpg
  2. Apr 23, 2014 at 1:24 AM
    huli467
    huli467 Turning Octopus
    Honolulu
    2015 TRD Sport 4x4
    The world is big...and I want to have a good look at it...before it gets dark - John Muir
    Looks good in my opinion! But I'm just biased.
  3. May 20, 2014 at 4:22 PM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    Do you have a pic down the side to see how much they stick out?
  4. Jul 10, 2014 at 5:21 AM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Wow! Your truck looks amazing!! Ya we need more pics to see the poke please!
    Im guessing you went with the 108mm center bore since fuel doesnt make the trophy wheel in our 106.4 bore?
    Did you use the 108-106 hub centric rings?
  5. Jul 10, 2014 at 5:55 AM
    SpeedStar
    Chula Vista,Ca
    Yes, 108 bore. No rings, but I have not noticed any shake.
  6. Aug 14, 2014 at 8:59 AM
    EastTx
    EastTx Well-Known Member
    Texas
    2017 Super White DCSB TRD OffRoad 4x4
    X2
  7. Aug 15, 2014 at 10:55 AM
    blazze2005
    South Jersey
    That's great news! Probably has allot to do with who balanced your tires. Glad to here all is good running the 108 bore
    But I will stick to being hub centric and lug centric
  8. Aug 15, 2014 at 1:10 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Truck looks pretty well.
    Did you have problems of shaking with your fuel octane. I have Procomp 7089 and they shake, and it's not the tire cause i've switch tires from one Wheel to the other and still have 18 oz of weight on one Wheel at the same place. Looking for option.
    I like the fuel trophy black with anthracite ring. They are not heavy and look nice. Glad to ear Speedstar dont have any problem. He runs stock AT20, a bit easier to balance then agressive offroad tires.
  9. Aug 15, 2014 at 1:27 PM
    sdoheny
    sdoheny Well-Known Member
    Seth
    Tampa, FL
    Sport
    N-Fab Text black 3 main tube, led interior lighting, sylvania ultra head lamps, led map/dome/license plate, rail mounted bed lights, trd skid plate, Aero Turbin muffler swap, MRBP Black Exhaust Tip, weather tech, fuel trophy, duratrac 265 70 17, plasti dip badges, Icon stage 4 suspension, TRD shift knob, AFE CAI, Raptor Light MOD.
    i like your style! here is a pic of mine down the side. with stock suspension 265 70 17 duratracs
    then with icon stage 4...
  10. Aug 15, 2014 at 1:50 PM
    Vassily28
    Do you have shaking or balancing problem with this combination?
  11. Aug 15, 2014 at 8:16 PM
    EastTx
    Texas
    Wow 18oz is a ton. Have you had tire shop try to spin tire on wheel 180 degrees on wheel?
  12. Aug 16, 2014 at 6:01 AM
    sdoheny
    Seth
    Tampa, FL
    Sport
    Absolutely not shaking. Purchased from goodyear store and they rotate balance them every 5k for free. Also got a 3 year alignment agreement with them for $180 so I get an alignment every rotation.
    asudevil likes this.
  13. Aug 18, 2014 at 5:10 AM
    Vassily28
    I've changed the model of tire and had the same problem after with closely the same amount of weights at the same place. So the problem is the Wheel. We spend almost 1 hour per Wheel with a friend to balance them.:eek: No tire shop will do that.
  14. Nov 19, 2014 at 11:45 AM
    swimtexan
    swimtexan Well-Known Member
    Love the pics, this is the wheel I will be purchasing soon!
  15. Dec 14, 2014 at 7:38 PM
    drscott11
    drscott11 Well-Known Member
    Went with these wheels for my Silver 2012 TRD Sport. Well, I'm ordering them tomorrow then installed on Tue. Will post pics once done.
  16. Jan 20, 2015 at 5:16 PM
    drscott11
    Here's mine...
  17. Feb 11, 2015 at 12:39 PM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Had my CNC guy make me some flush mount billet caps for these wheels. I like them way better than the regular caps.
    asudevil and Tridet167 like this.
  18. Aug 3, 2015 at 1:07 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    I have the same rims(trophyD551). I just had my wheels rebalanced with a road force balancer machine and any vibrations I had are now gone. I didn't know this but my rims didn't have the rings because Fuel don't make them. The guys at the shop failed to tell me this. It's a 2mm gap so maybe it's not so bad but wheels can work without rings but it's better to have them since that's a crucial connection, hub to wheel. Lot of force on there.
  19. Aug 3, 2015 at 1:15 PM
    Tridet167
    Tony
    Toronto, Canada
  20. Aug 13, 2015 at 11:07 AM
    Tacoman2013
    Tacoman2013 Active Member
    2013 TRD off-road Tacoma
    I am having a similar issue. Mine are not balancing right. Yesterday Discount Tires swapped out for a whole new set of tires same ones but new. The manager told me that the rims where hub centric but everything I have come across is telling me that they are not. Therefore, I do not have the hub ring in. On another post here, a discount tire rep claimed fuel wheels are lug centric. Can anyone clarify or confirm this?
