Fuel tank pressure problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thetrooper236, Jul 15, 2020.
  1. Jul 15, 2020 at 6:33 PM
    thetrooper236
    thetrooper236 [OP] Member
    Oregon
    2017 DCLB Tacoma TRD Off-Road
    Recently purchased a used 2016 TRD off-road and very quickly found out that the vehicle would continuously shut the gas pump off if you attempted to fuel at more than an extremely slow pace. The gas attendant (in Oregon) commented that it seems as though someone syphoned from the tank, as they exhibit a similar issue. Additionally, while driving in hot weather, I have begun to hear air escaping from the gas cap during acceleration, or constant throttle. The sound is similar to a very quiet blow off valve... It would seem to me that the fuel cell is not able to properly relief pressure?
    Does anybody have any clue where to start with this one? Thanks!
  2. Jul 15, 2020 at 6:36 PM
    VirusCage
    VirusCage Well in the secondary immune response
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    1. Check the cap, replace.
    2. Check the filler neck for any damage.
    That is where I would start
    Montana_Actual likes this.
  3. Jul 15, 2020 at 6:49 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    check filler neck for any/all obstructions
    no reason the tank would be pressurized with the cap off adding fuel
    the tank is vented
    excess fuel is returned from the EFI back to the tank
    possibly pressurizing the tank
    the air U hear while driving could be an issue
    make certain the vent is open
  4. Jul 15, 2020 at 7:34 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Evap system is supposed to vent gasses back through the system and burn them off. Is your Check Engine Light on?
    Zim
    Chew and Big tall dave like this.
  5. Jul 15, 2020 at 7:36 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Sounds like a clogged vent. My buddy went through a similar thing with his Tahoe.
    hiPSI likes this.
  6. Jul 15, 2020 at 7:41 PM
    thetrooper236
    Oregon
    No, I do not have any engine light. I have heard EVAP system a couple times due to clogged lines, and also a flapper valve that could be damaged within the fuel cell itself. Unfortunately I just moved and my tools have not arrived yet. I guess once they do, I'll drop the tank and check all the lines first.
  7. Jul 15, 2020 at 7:47 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    You have a blocked vent, or a vent valve that’s not opening. Regs require Venting to atmosphere to be controlled (can’t remember specifics), but basically means you have a a few vents that are electronically controlled. It’s quite common for one to fail and exhibit the exact system’s you have.
    edit, it’s not venting to atmosphere it’s venting to canister
    hiPSI likes this.
  8. Jul 15, 2020 at 7:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Canister clogged from overfilling. No need to drop tank. Fix that and it fixes everything.
    Tacman19 and Chew like this.
  9. Jul 15, 2020 at 8:00 PM
    thetrooper236
    Oregon
    Would this be evident with crud and charcoal bits in the EVAP line? At what point would be whole canister be bad??
  10. Jul 15, 2020 at 8:34 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    When the tank vent is clogged to a point where you cannot put gas in the tank.
    Tacman19 likes this.
  11. Jul 15, 2020 at 8:49 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I’m not 100% sure how the Tacoma tanks are designed, but to me, it sounds like two problems...
    The ‘Slow filling of the tank at the gas station’ problem that the OP is describing sounds like the tube that goes from the top of the gas tank to the filler neck is pinched/twisted/blocked.
    The ‘Hissing noise from the gas cap while driving’ problem sounds like the EVAP system is blocked somewhere and building a lot of pressure.
    Chew likes this.
  12. Jan 27, 2022 at 5:26 PM
    thedirttaco
    thedirttaco Meth-mobile owner
    2018 black Tacoma
    Some things..?
    Did you ever fix this? I’m having the same issue. I’m about to get a new EVAP canister/system.
    fuel tank is pressurizing and can’t fill it at any fast pace at the gas station
  13. Jan 27, 2022 at 5:30 PM
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    Have you had the fuel tank out or a fuel pump changed? Sometimes when the tank is put back the fill line gets crimped and fuel won’t flow smoothly into the tank. Just a thought I have had that issue on another vehicle.
  14. Jan 8, 2024 at 3:11 PM
    thetrooper236
    Oregon
    Apologies for the much-overdue response!! Hopefully you fixed your issue by now, but I wanted to post my fix so others can hopefully benefit. The issue ended up being a clogged air vent for the EVAP canister. There is a "clam-shell" style air filter that is mounted to the fuel line just inboard of the fuel door (in between the bedside and bed itself). If you follow the vent line coming from the canister, you will certainly find it hiding up above the rear wheel well. I separated the filter halves, removed it from the fuel line and found it packed with dirt/dust. After I cleaned out the dirt, I sprayed the housing with compressed air ... re-installed everything and the issue is gone. For safe measure, I disconnected all EVAP lines from both at the charcoal canister and engine so I could blow them out with low PSI air and ensure they were not packed with any dirt. They were clean, so all signs point to the vent.
  15. Jan 13, 2024 at 3:14 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    Sounds stupid, but get gas from a few different stations to check this. I've had this issue with 2 GMC Sierras over the years and both turned out to be the local Shell station pumps. I go to Shell because of their gas quality, but I've found some other top-tier gas stations nearby where this doesn't happen.
  16. Sep 15, 2024 at 9:52 AM
    Tyr226
    Tyr226 New Member
    How did you reach this filter? Did you have to remove the bed? Ive been chasing an evap leak with codes that point to the evap canister. I get a lot of pressure buildup that releases when i remove the gas cap. I havent had issues refueling in about a year but i did use to have that problem.
  17. Sep 16, 2024 at 8:08 PM
    thetrooper236
    Oregon
    No, I did not have to remove the bed. It was a few years ago, but if I remember correctly... I reached up from underneath the truck to disconnect the lines from the filter canister, then removed the fasteners that held the filler neck to the bedside. After that it was a bunch of wiggling things around in order to get hands-on and remove the filter canister. Wasn't fun.
