Fuel system/injector cleaner recommendations?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Quicksandbeast, Sep 29, 2018.
  1. Oct 9, 2018 at 6:33 PM
    #41
    Reedld
    Reedld Well-Known Member
    Leon
    Painted Post NY
    2022 DCSB Tacoma Army Green TRD Sport
    Yes, I was aware of our gen truck engines having that option.
    shakerhood[QUOTED] likes this.
  2. Oct 10, 2018 at 5:36 AM
    #42
    max_o
    max_o Well-Known Member
    Colorado
    2018 Silver Sky DCSB OR
    I use LiquiMoly Jectron on my daily driver VW GTI, which has 131k miles on it. Seems to work well. Just one can in the tank at fillup every 1200 miles. The GTI requires an intake valve cleaning due to carbon buildup once every 40k or so. Mine is due as we speak and currently runs like garbage. Rough idle and a loss of power. Too busy modding the Taco right now to worry about the GTI though :D
  3. Oct 10, 2018 at 5:48 AM
    #43
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    I realize this is based on a different engine (4.0L) but I've added AMSOIL PI fuel treatment to the gas tank at every 10,000 miles since new. I also clean the throttle body every 50,000 or 100,000 miles, don't remember which. My MPG has never skipped a beat, still on the original fuel injectors, engine runs like a top after 393,000 miles. Do I use top tier gas? nope, always 87 octane and whoever has the best price near the house.
    MountainManGuy likes this.
  4. Oct 10, 2018 at 7:19 AM
    #44
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Pay a few cents more and purchase fuel with an additive like Chevron with Techron. Shell and others also provide additive, but make sure the pump indicates the added additive. Pays off in the long run. Cheaper the fuel, no additive.
    tonered likes this.
  5. Oct 10, 2018 at 7:36 AM
    #45
    Locoluna825
    Locoluna825 Well-Known Member
    Garrett
    San Diego, CA
    2008 Tacoma TRD sport 2x4
    URD TCAI and MAf Calibrator, Lexus front GX470 big brake swap, TRD Baja Suspension, 3 leaf progressive AAL.
    I used to work for a Honda dealership in 2015 as a Lube Tech. We used a fuel injector cleaner in a bottle. It was a product from Exxon Mobile and alot of us agreed it was the same thing as Chevron Techron. I still can't get over the dealership would charge the customers over a hundred dollars for that service and all we were basicly doing was pouring a bottle of Chevron Techron into your gas tank. You could of purchased that at Costco by the case for less than 20 bucks.
    To this day I still tell my family and friends not to pay for that service from the stealership.
    tonered likes this.
  6. Oct 10, 2018 at 7:47 AM
    #46
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    BillsSR5, Gator352 and tonered like this.
  7. Oct 10, 2018 at 7:54 AM
    #47
    Señor
    Señor Well-Known Member
    CA Central Coast
    '18 TRD OR DCSB Magnetic Gray Metallic
    Gas and water don't mix. Water will separate to the bottom of the tank, where the pick-up is. Not to say water can get into your fuel system through condensation or yes, water in the station tank through a leak.
  8. Oct 10, 2018 at 7:57 AM
    #48
    TXRailroads73
    TXRailroads73 RUNNIN' WITH THE DEVIL AND MY ROAD DOG T100
    Adam
    The Lone Star State, RGV, TEXAS
    1997 Toyota T100 3.4V6 4WD
    None all stock
    I just changed out my fuel filter, and before that I've been using the Lucas high mileage fuel system cleaner, fixing to change out my ignition coils n wires n plugs
  9. Oct 11, 2018 at 8:17 AM
    #49
    Silentwolf
    Silentwolf Well-Known Member
    2017 Tacoma SR
    Cruise Control,Led Reverse lights, Weathertech mudflaps, Weathertech headlight protectors,Lund stepbar, Interior Leds, AVS Hoodflector, AVS In-Channel Ventvisor, aFe Pro DRY S airfilter, K & N cabin airfilter, A/C drain valve, Mostplus Led Headlights
  10. Oct 24, 2018 at 8:59 PM
    #50
    GulfCoastMike
    GulfCoastMike Co-pilot Angel
    Pascagoula, MS
    2017 MGM AC SR5 3.5L A/T
    A couple of years ago, I spent way too much time researching fuel system / injector cleaners.
    What I discovered was that Redline SI-1 contains a higher concentration of PEA (Techron), than any other product. By what I read, Techron is the best cleaning agent available.
    I use it 4-5 times a year and I’m very happy with it. Locally, it is only available at O’Reilly’s, for me.
    Another option:
  11. Jan 14, 2019 at 10:09 AM
    #51
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    My truck has just under 150kms. After sitting overnight it would struggle to start. Ran a bottle of fuel treatment and the issue is now gone. I was worried I had a clogged fuel filter. But this seemed to remedy my issue. $10 well spent
  12. Jan 14, 2019 at 11:43 AM
    #52
    Bryanccfshr
    Bryanccfshr Well-Known Member
    2018 Trd OR , 2018 TRD Pro 4Runner
    DS4 addresses this. The 2gr fks has direct and port injection. The port injection keeps the back of the intake valves clean by using some fuel in the port side during normal driving. The “cleaning cycle” is how the high pressure direct injector os cleaned to prevent deposits in the injector itself.
    I am a big believer in top tier fuel.
    If you stick to Costco, chevron, Texaco, Valero and Shell, you will be in good shape.
  13. Jan 14, 2019 at 11:49 AM
    #53
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
