Fuel Pump Whine?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dung, Dec 17, 2018.
Can you hear your fuel pump?
  1. Loud
    7 vote(s)
    23.3%
  2. There, but unobtrusive
    7 vote(s)
    23.3%
  3. Inaudible
    16 vote(s)
    53.3%
  1. Dec 17, 2018 at 7:54 AM
    dung
    dung [OP] Well-Known Member
    2018 TRD OFFOAD
    I just got back from the dealership for the rear-end whine and and second whine coming from the back of my truck. When you open my sliding rear window you can hear what sounds like the electric fuel pump plain as day. It is present from 30 mph up to 70 or so where wind noise starts to drown it out. It is annoying loud, much like Cicadas in the midwest during the summer.
    As soon as you shut the window it is muffled. The problem is, I love having my windows down.
    The mechanic/and GM that went for the ride along said they can't fix it since it is pumping. I test drove another identical truck on the lot and it wasn't making this noise.
    Does anyone else have this issue?
  2. Dec 17, 2018 at 9:15 AM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
  3. Dec 17, 2018 at 9:21 AM
    dung
    2018 TRD OFFOAD
    Thanks, though I wouldn't consider this to be a chirping noise. It sounds exactly like a cheap electric fuel pump from Autozone mounted to the back window. The noise is pretty well constant. If you are going highway speed and drop it to neutral and the engine idles down the noise is still there as well so it doesnt seem to be rpm dependent.
  4. Dec 17, 2018 at 10:48 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The High Pressure Fuel Pump that is mentioned above is under the hood, and it chirps like crickets.
    gotblika likes this.
  5. Dec 17, 2018 at 10:58 AM
    gmtech
    gmtech Well-Known Member
    quad cities illinois
    2016 trd or. 2024 trd OR iforcemaxx!!
    Stock AF
    want some cheese with that Whine? does it make the same noise when the car is sitting still? and running.
    the fuel pump in the tank runs all the time when engine is running. and does not change rpm for engine load.
    if you can hear it with the truck stopped and running it could be the pump. but you should be able to get out and lay under the truck and hear it coming from the tank. also.
    Amchuge likes this.
  6. Dec 17, 2018 at 11:19 AM
    dung
    2018 TRD OFFOAD
    Yes, cheese please....I would prefer a ride in the wambulance though :)
    The noise isn't made while at a stand still with the engine running. It doesn't sound like the pre-start prime either.
    TacoGreg likes this.
  7. Dec 17, 2018 at 11:27 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Then its not your fuel pump man. Close thread and poll and start another...
    shakerhood likes this.
  8. Dec 17, 2018 at 11:46 AM
    dung
    2018 TRD OFFOAD
    OK, what do you want me to POLL TW on, Suppressed 556 vs 300 BO for home defense?
    hiPSI[QUOTED] likes this.
  9. Nov 24, 2019 at 9:56 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    I have the exact same noise from my pump that you have. I know this is an old thread but did you get it fixed. if I used Techstream and activate the pump on low duty cycle I can replicate the noise.
  10. Nov 25, 2019 at 9:06 AM
    Furball
    Furball Well-Known Member
    Minnesota
    2017 TRD Off Road
    i have a 17 OR and mine does this, with rear window open at moderate speeds, it sounds like a metallic spinning whining sound, pitch does not change.
  11. Nov 25, 2019 at 9:15 AM
    dung
    2018 TRD OFFOAD
    They won’t acknowledge it as being a problem. Your pump is pumping, it isn’t broken, normal characteristic
  12. Nov 25, 2019 at 10:19 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
  13. Nov 25, 2019 at 10:21 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Landmines.
    The hammer likes this.
  14. Nov 25, 2019 at 11:14 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    Well we will see. I've decided to trade the Tacoma in for a Tundra and disclosed the pump noise. The sales side said they would fix it under the powertrain warranty but if the service end declines the repair it wont effect my trade because "there is nothing wrong with it".
  15. Nov 25, 2019 at 11:59 AM
    SweatyBiscuit
    SweatyBiscuit Well-Known Member
    Paul
    Northern AZ
    2016 Taco TRD OR
    Katzkin leather, heated seats, Popnloc, bed lights, remote start, bhlm....
    Mine is most noticeable when sitting in traffic or the drive through line. Almost sounds like a bad pulley or belt. It is pretty annoying. I’ve heard that they all make the noise.
  16. Nov 25, 2019 at 12:58 PM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    You're talking about the high pressure fuel pump (HPFP) that sounds like crickets or tensioner pulley from under the hood . If you have anything worthy of contributing to that issue, please post here.
    https://www.tacomaworld.com/threads/t-sb-0016-18-chirping-noise-fm-high-press-fuel-pump.542250/
    Otherwise, this thread is talking about the fuel pump that is in the fuel tank and the sound that emanates from the rear of the vehicle.
    Obxdrew likes this.
  17. May 19, 2022 at 5:50 AM
    YotaComa99
    YotaComa99 Guy who should have read the directions
    South Florida
    2019 OR long bed, 1999 2.4L single cab
    887s on 5100s, OME HD springs, ECGS bushing, LR UCAs, leer 100r, non-OEM TRD pro grille (sensors work). It'll be an overland rig one day.
    I know this thread is old but I recently lifted my truck and want to rule out this noise. I did have to do a fairly extreme CB drop kit to stop driveline vibrations (they're there still, but only very subtly from 20 to 27mph)
    So; a constant volume, Cicada-like sound starting around 30mph and not changing at all with added speed up to 70, is likely fuel tank fuel pump whine(low pressure pump in the actual tank, NOT hi-press under hood)? The sound completely dissapears at lower speeds. I have not tried slapping it in neutral yet but will on my drive home today, if the sound goes away doing that I'll come here and leave an edit.
    I'm constantly paranoid about my U-Joints ever since the lift and this sound just seemed weird, so if someone could give me some piece of mind I'd be eternally grateful.
  18. Jul 26, 2022 at 12:12 PM
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    for everyone citing the HPFP thats in the FRONT under the HOOD thats a completely different sound.
    This sound is only audible explicitly when the rear window is open, i have extensively researched this issue and i still dont know what it is but to describe it a 'shimmering' or 'cicadas in the summer' is the closest way to describe it.
    Obxdrew likes this.
  19. Aug 11, 2023 at 5:21 AM
    Obxdrew
    Obxdrew Member
    Drew
    2020 Tacoma Off Road 6sp MT
    None yet
    Yea I hear the same cicada like noise with my rear slider open when driving, there has to be a reason for this?
  20. Aug 11, 2023 at 10:54 AM
    shakerhood
    Southern Ohio
    The high pressure fuel pump is under the hood, you usually will notice it if you get beside a building or an enclosed space.
