Fuel pump relay location?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sticky91612, Apr 11, 2022.
  1. Apr 11, 2022 at 12:31 PM
    Sticky91612
    Sticky91612 [OP] New Member
    Francisco
    2002 Tacoma prerunner
    Where is the fuel pump relay on 2002 Tacoma prerunner extended cad
  2. Apr 11, 2022 at 2:10 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  3. Apr 11, 2022 at 2:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    What engine?
    They usually go through the EFI relay to the Circuit Opening Relay then to the fuel pump.
    Anyways, it’s likely the Circuit Opening Relay you’re looking for.
    Bivouac and Dm93 like this.
  4. Apr 11, 2022 at 2:36 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    i'm going to add in a relay when i swap my fuel pump. according to gadget, the fuel pump sees less than 12v. I'll rewire it so it will get full battery power.
  5. Apr 11, 2022 at 9:44 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Toyota calls it the Circuit Opening Relay, it is located under the steering column on 1st gen trucks.
    There's no fuel pump resistor on 1st gen Tacoma's, it gets full battery power anytime it's on.
    2nd gen Tacoma's have a 2 speed fuel pump that uses a resistor for low speed.
    Bivouac and TnShooter like this.
  6. Apr 12, 2022 at 8:49 AM
    e.deCastro
    Eric
    San Diego
    i never said there is a resistor but the long run and various connections there is a significant voltage drop (verified by gadget) so it does NOT get full voltage.
    can't find the data right now but it doesn't hurt to rewire the pump.
  7. Aug 16, 2023 at 4:20 PM
    Toyota_girl
    Toyota_girl New Member
    Hello I need some help my Toyota Tacoma 2002 2.7 does not want to start It will not spark
  8. Aug 17, 2023 at 1:45 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Why add another relay you all ready have 2 relays.
    Unless of course your making a completely new circuit by passing all factory fuel pump circuit using a switch to turn the pump on and off via a relay . Don`t forget circuit protection and a light when the pump is energized I have fixed quite a few that left the pump on all night and drained the battery.
