Fuel Max Performance Chip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GregLee98, Feb 16, 2012.
  1. Feb 16, 2012 at 6:26 PM
    GregLee98
    GregLee98 [OP] Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
  2. Feb 16, 2012 at 6:29 PM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Most likely not.
    There are no proven "chips" for these trucks.
    Your best bet for an increase in power (and only under open loop) would be a URD Maf Cal from urdusa.com
  3. Feb 16, 2012 at 6:51 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The 35hp and 4 mpg part is bullshit.
    The the 50% better throttle response can't be argued, it's real.
  4. Feb 16, 2012 at 7:13 PM
    badger
    badger Well-Known Member
    07 SR5
    35 hp + fuel reduction = 100% bullshit. All they have to do to improve throttle response is get rid of the electronic lag.
  5. Feb 17, 2012 at 7:38 AM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    Pardon my ignorance, Blasphemous, what is the difference between this one and the URD MAF sensor? Besides price?
  6. Feb 17, 2012 at 7:45 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    what you posted plugs into the obd2 and does nothing
    urd maf is hard wired into the ecu and leans out the factoru rich fuel mixture
  7. Feb 17, 2012 at 9:22 AM
    worthywads
    Can the URD be tuned for better MPG and less power?
  8. Feb 17, 2012 at 9:25 AM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    solid question ^ :popcorn:
  9. Feb 17, 2012 at 9:27 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I would imagine not. The Maf Cal only works in open loop mode, which is definitely not the efficiency portion of the powerband.
  10. Feb 17, 2012 at 10:24 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, if you're running in open loop frequently, you aren't going for MPGs. If you aren't familiar with open vs. closed loop, typically open loop is higher RPM and higher throttle position. Typical driving around town may never put you in open loop.
  11. Feb 17, 2012 at 11:50 AM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    So the URD MAF is basically only for power and expect to lose some more MPGs?
  12. Feb 17, 2012 at 12:05 PM
    memario1214
    Colton
    Missoula, MT
    If you are always with your foot in the throttle looking for those extra horses, expect less power. If you drive like normal, there's no change in MPG
  13. Feb 17, 2012 at 12:11 PM
    Pugga
    Massachusetts
    In closed loop, your current MAF sensor adjusts the fuel map if you will to make the engine more efficient. Once you go to open loop, the ecu defaults to a set map. The URD calibrator wouldn't allow the engine to just default to a set map when in open loop, it instead keeps talking to the ECU and tires to make the engine as efficient as it can be in the open loop. It's not really complete to say it's just for power the problem is someone looking for MPG improvements wouldn't spend a lot of time in open loop. If you tow, you might find yourself in open loop more frequently because your engine will keep trying to make more power. Hopefully not too confusing.
    Even with the URD MAF calibrator, in closed loop, you will see no change at all as your ECU will stick to it's normal routene.
  14. Feb 17, 2012 at 3:13 PM
    worthywads
    Gotcha
    But I must point out that deceleration fuel cutoff is also an open loop mode, zero fuel use. Doesn't really apply to what a maf cal could effect though.
  15. Feb 18, 2012 at 4:51 AM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    Open loop/Closed loop. Can someone explain in knuckle dragging terms?
  16. Feb 18, 2012 at 4:57 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  17. Feb 18, 2012 at 7:47 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Open loop: warmup up mode before the cat is up to temp. Basically the ECU is running a static set of parameters and is not using O2 sensor feedback.
    Closed loop: the ECU is fully online and adjusts parameters based on feedback from system O2 sensors and other inputs to optimize combustion and timing.
  18. Feb 18, 2012 at 7:52 AM
    Raylo
    MD, USA
    Oh, and aftermarket "performance" chips, unless designed to support a specific mod like a 'charger, are worthless... except to the folks selling them. Come up with a fancy high perf name, tweak a few of the parameters that have already been exhaustivey optimized by Toyota, make ridiculous perf or mileage claims, then sell them with an asterisk that "results may vary" which basically is an overt admission of their worthlessness. What a business....
  19. Feb 18, 2012 at 7:57 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Closed loop is literally a closed loop, like a circuit. Read map, send fuel, read o2 sensor, change map, read map, send fuel, read o2 sensor, change map... and so on. That way barometric pressure, humidity, fuel quality, and engine-specific tolerances all are constantly compensated for to improve efficiency.
    If the ECU can't trust the o2 sensor it can't do that recurring logic loop, thus "open" loop (like an open circuit). The fuel trims (map changes) determined during closed loop operation ARE applied when in open loop operation.
    The o2 sensor is useless when 1) it's too cold on startup 2) full throttle when the engine is running richer than stoichiometric and 3) when in DFCO when zero fuel is going through the engine.
  20. Feb 18, 2012 at 8:04 AM
    GregLee98
    Greg
    08 Tacoma TRD Sport
    I figured it was worthless. Just wanted to know what everyone thought of them.
    Anyone have experience with the URD MAF sensor?
    Is it only power/HP/torque gains? Or can I get MPG too?
    And don't tell me it depends :)
