Fuel injector hydrolock engine while running?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gerriputo, Jan 12, 2024.
  1. Jan 12, 2024 at 11:25 AM
    gerriputo
    gerriputo [OP] Well-Known Member
    Posting for a friend that I've been helping. Technically a 3rd gen 4runner but it's the 5VZ and figured I would get more reads here.
    1997 4runner that he bought about 2yrs ago. He has known the PO by working at her house and she finally decided to sell. Folder full of maintenance records including (2) head gasket jobs with the second time having a new set of heads put on. Late August/early September 2023 he blew another head gasket. With the new heads being done last time he figured maybe it was the block and decided to go with a replacement engine.
    He was looking at getting a Yota1 engine and I found a company on eBay called Phoenix Engine Specialists. They offered a long block with no core, quick build time and about 2/3 the price. Motor showed up quickly and looked good. We installed over the course of a couple days with all OEM gaskets. Engine ran great after installing, with no leaks and no codes.
    Fast forward to about 2 weeks ago and 800 miles on the PES engine. His 21y/o son is driving down the freeway when there is a catastrophic failure and has to be towed home. Tow truck driver finds pieces of the block on the road. I realize the son is young but I honestly do not think the engine was being driven hard.
    They remove the engine and pull the oil pan. It looks like from front of engine to back it's bearing position 2 and 3 that have broken rod caps and position 4 has a bent rod. The guess is that there was a single rod failure that caused the rest of the damage by broken pieces flying around and jamming into tight spaces.
    Friend calls the builder and is first told that the engine was either over revved or hydrolocked. After a couple more calls and going over pictures, the builder is now saying the engine was hydrolocked from a stuck injector and won't budge from that. They have offered to have him send their engine back along with his old short block and build him a motor for $1800.
    Sorry for the novel but wanted to try and give the full story. I find it hard to believe that a stuck injector with a flow rate of 240cc/min can flow enough to hydrolock a cylinder at freeway speeds. I can of course see an injector doing that when the engine is not running. But I wanted to see what people thought on here and if they have seen similar happen. I came across another thread of a rod through a block that looked similar but there was never anything said as to what caused it.
    Thanks in advance for any help.
  2. Jan 12, 2024 at 11:58 AM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    what are these black pieces?
  3. Jan 12, 2024 at 11:59 AM
    Glamisman
    Glamisman Well-Known Member
    Pull the oil filter and carefully cut the plate end off and unroll the media. You are looking for fine metal bits of bearing etc. If there is nothing then it truly came apart fast. If it has bearing material then there was a build issue. Will they accept an internet motor diagnosis, who knows.
  4. Jan 12, 2024 at 12:08 PM
    ControlCar
    Steven
    Sugar Land TX
    initially this is my thought
    fuel 'typically' doesnt hydrolock an engine
    IF this occurred.....the head would be damaged from incorrect timing from a the part that controls timing for the head and short block to be in-sync.....T-chain or gears or tensioner
    other things i noticed...
    -doesnt look like oil deprevation(no rainbow heat marks on bearing surfaces)
    -there is a large amt of scoring on bearing surfaces(dry start when 'tested' by vendor?)
    -that is a shit ton of RTV overlapping the pan/block surface
    im trying to get a hold of my friend that builds engines
    to see what he says
    he loves crap like this
  5. Jan 12, 2024 at 1:02 PM
    ControlCar
    Steven
    Sugar Land TX
    HA!
    i got a hold of him
    first of all and MOST IMPORTANTLY............
    -was there signifigant amt of fuel in oil?
    -did the oil smell strongly of fuel?
    if not this is a excellent way to disprove vendor's 'fuel hydrolock' condition for failure.
    secondly, he noticed a cracked rod but no bent rods
    again, hydrolock condition would bend rods not crack rods
    here is your pix of 'cracked' rod:
    TartanEagle likes this.
  6. Jan 12, 2024 at 1:08 PM
    ControlCar
    Steven
    Sugar Land TX
    75% of our convo were about these 2 pix
    we think this is the failure point
    unknown exactly which side failed first, but friend makes some good pts
  7. Jan 12, 2024 at 1:17 PM
    gerriputo
    I believe those pieces are from the block and he pulled them and the bolt/nut from the skid plate.
  8. Jan 12, 2024 at 1:22 PM
    ControlCar
    Steven
    Sugar Land TX
    see the dent on the oil pan
    can be determined that the side of the rod cap with the missing bolt struck OP
    the opo side of rod cap has bent connecting bolt.....and is sheered off
    (pix quality too low to see if there are beach marks on sheered bolt to deter if metal fatigue)
    we are guessing from your pix that the rod cap side with the bent bolt failed.
    on down stroke the cap became loose, twisted and eventually failed and struck pan
    then catastrophic to SB occurred.
  9. Jan 12, 2024 at 1:22 PM
    gerriputo
    Really appreciate you and your friend taking the time to look and talk this over. I don't think there was a strong smell of fuel but I will verify. Here's the latest pictures he sent me.
    ControlCar[QUOTED] likes this.
  10. Jan 12, 2024 at 1:28 PM
    ControlCar
    Steven
    Sugar Land TX
    the other theory is that the twisted rod cap with missing bolt was never on the cap/never torqued
    see the threads on the missing bolt side?
    would think that those threads would be in much worse condition if bolt came off bc of forced impact with oil pan
    this would also explain the bent connecting bolt on the opo side
    this theory wouldnt hold if the vendor just dressed up engine and just used a used SB...friend said this possible from vendor
    eager to see what others say!
    friend wants me to update him on this too
    GL
  11. Jan 12, 2024 at 1:31 PM
    ControlCar
    Steven
    Sugar Land TX
    there is the cracked rod
  12. Jan 12, 2024 at 2:19 PM
    ControlCar
    Steven
    Sugar Land TX
    hey
    my friend just called me back
    OldSilver is going to love this..............
    he said another possibility
    bc of the uneven wear on the crankshaft journal
    bc that uneven wear is the furthest from the harmonic balancer
    poss tht the crankshaft was unbalanced....causing that rod cap bolt to come loose then catastrophic engine dmg
    worn/not torqued harmonic balancer
    the only reason this might not be the case is only 800 miles driven
    OldSilver has lots of experience/knowledge on this HB stuff
  13. Jan 12, 2024 at 2:36 PM
    gerriputo
    Here are the pictures from cutting the oil filter open. Break-in oil (royal purple) was used initially and oil change was done at 600 miles. I asked about metal in that oil but he doesn't recall. Might still have that first filter.
  14. Jan 12, 2024 at 2:49 PM
    gerriputo
    Wouldn't all this metal disprove the builders claim that the damage is from a fuel hydrolock? If it hydrolocked sure there would be metal from things flying around, but the engine isn't going to get many revolutions after locking. All this metal seems like it would have taken a bit longer of the engine running to accumulate. Friend says he is pretty sure there is metal in the heads also, which seems likely if the filter had that much.
    Also, one of the broken parts looks to have broken the oil channel in the block between the oil filter and oil cooler. This seems like it would stop oil flow because of th ebig hole in the block.
    Thanks again.
  15. Jan 12, 2024 at 5:47 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Seems like the rod bolts weren't torqued. The way the threads are gauged indicates its been loose for a while. Nut probably lost enough torque to side load the other bolt and break it whipping the rod and piston around. Checking the torque of the other rod bolts would prove this theory. I doubt the injector stuck open and I doubt that much fuel would cause a hydrolock. It would be easy enough to test but the engine builder shows clear signs he doesn't want to pay for a replacement anyways.
    gerriputo[OP] likes this.
  16. Jan 12, 2024 at 11:01 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    This right here says the nut was missing before it blew up. The nut was missing and threads here damaged. Every blown motor from over revs or hydralock the nuts were still on the bolts. The bolts would be broken or bent but nut would still be on there.
  17. Jan 13, 2024 at 7:35 AM
    Glamisman
    My thoughts exactly. If the motor started to eat itself slowly there would be metal in the filter and like you said not too many RPMS after the block got ventilated.
  18. Jan 13, 2024 at 9:57 AM
    ControlCar
    Steven
    Sugar Land TX
    Oil/oil filter look fine
    Assuming no fuel or fuel smell
    not a stuck injector hydro lock 100%
    from the evidence shown
    2 possible causes now
    1-something to do with those rod cap fasteners
    2-HB
    how did harmonic balancer look?
    Was the crank shaft bolt super easy to take off?
  19. Jan 13, 2024 at 3:51 PM
    gerriputo
    Engine came without harmonic balancer so it was swapped from old engine and torqued with a new bolt.
    Seems like we all agree that it is very unlikely this was caused by a stuck injector. Friend is going to send a link to this post to the builder but I'm not optimistic they will do the right thing. What is the point of a warranty if they will not stand behind their product? I understand in this day and age that some consumers will make claims that are false and try and take advantage of businesses, but this is not the case here and some simple questions and investigation would help determine what happened.
    I hope I am wrong and that the builder will reevaluate. If they do, I will make sure to post that so that future engine shoppers can know who to buy from and who to avoid.
  20. Jan 13, 2024 at 4:03 PM
    ControlCar
    Steven
    Sugar Land TX
    GL
    hope everyone’s diagn/comments help your cause
