Fuel Injector Cleaner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PackCon, Feb 1, 2016.
  1. Feb 1, 2016 at 3:36 AM
    PackCon
    PackCon [OP] Well-Known Member
    Connor
    2017 Subaru Forester Limited
    How many of you guys use fuel injector products?
    Please share why you do or don't. Also, if you do, how often.
    I've never run these products in either of my prior trucks. My 250 has over 200k miles on it and no issues. I'm just wondering if it's a good preventive maintinence product or a waste of money. I would like to run my Taco for at least 400k miles.
    My dad warns against using things like this because he ran a bottle in his BMW and not long after had to replace his 02 sensors. He thinks the cleaner caused it. I'm not so sure.
  2. Feb 1, 2016 at 5:41 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    In days gone by, I've used a variety of snake oil treatments to include FI cleaners. I noticed no difference in performance, smoother idle; mpg.
    I did; however, use a can of BK 44K in a '91 Mercedes gas engine once and OMG!!! The car bucked and kicked like a rabid mule. After that tank of gas, things smoothed out and the car seemed to run a lot better.
  3. Feb 1, 2016 at 5:45 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Feb 1, 2016 at 5:47 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Chevron techron fuel system cleaner every oil change (5000 miles). I wait until Advance Auto has a buy one get one free deal.
    TXpro4X4 and DrFunker like this.
  5. Feb 1, 2016 at 5:54 AM
    pavemobile
    pavemobile Well-Known Member
    Wichita Falls, Texas
    2009 TRD Sport SR5 PreRunner
    K&N Intake
    Redline Si-1 will do the trick for you. Run an entire bottle in your tank of gas prior to an oil change, I've been using it in mine and family member's vehicles for over 20 years and no problems. PEA is the chemical that does the cleaning/carbon breakup; Chevron calls it Techron, Gumout calls it Regane, everyone has a name for it.
    If you can afford a few days down time, there is the option of removing and sending the injectors off for ultrasonic cleaning. It costs a little bit but you can return the injectors to their desired flow rates and function. I know at least one place will install stainless steel filter baskets for an extra $1.50 each to help combat high ethanol fuel problems. I bought a couple sets of injectors on here and sent them to a guy on the East Coast to be rejuvenated. Running a set now and had the other set prepped/lubed for storage as spares for later on.
    Torspd likes this.
  6. Feb 1, 2016 at 9:25 AM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    Once a year when I take a trip, I usually get a can of Seafoam and put it in the gas tank. Don't know if it really helps, but to me it's a little preventive maintenance in my mind. Throttle body is where it mostly gums up, that's the area where you'll notice a hesitation and realize something needs to be addressed. Their's several discussions on youtube about this. https://www.youtube.com/watch?v=u6UeJXkzDW8
  7. Feb 1, 2016 at 9:47 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Mostly I use straight gas. Occasionally I use Lucas and Techron concentrate, they are dirt cheap on Amazon. Lucas every 3-4 fuel-ups, and Techron once per year. The Lucas provides upper cylinder lubricant in addition to chamber/injector cleaning and slightly improved MPG. The Techron is a powerful cleaner (cleans the entire fuel system including fuel tank) and should not be needed more than once per year unless there are other issues going on.
  8. Feb 1, 2016 at 9:55 AM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I recently started using Lucas fuel injector cleaner at 6 ounces per 20 gallons of gas in my Tacoma. After a couple tanks my MPG went up from mid 17's to high 18/ low 19's.
    I put it in my wife's Corolla which started to shake slightly at idle in drive, now it doesn't.
    I'm not sure if it is actually cleaning the injectors or just conditioning the fuel as it claims to negate bad gas.
    I have used it in my 13 year old Honda push lawn mower for many years now. It starts first pull even after sitting for a month.
  9. Feb 1, 2016 at 11:47 AM
    PackCon
    Connor
    I have to be perfectly honest. I don't think I notice any significant difference between the before and after there.
  10. Feb 1, 2016 at 1:40 PM
    billybob50
    Bob
    I tend to agree, but if you look real close amazingly it did a little. That's why I do it only once a year to help prevent it from gumming up. To each his own as far as doing things, as preventive maintenance.
  11. Feb 1, 2016 at 5:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The most important thing is Make sure the product says on the container that it is O2 Safe.
    Lester Lugnut likes this.
  12. Feb 1, 2016 at 5:23 PM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    +1 Sea foam
  13. Feb 1, 2016 at 5:31 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I have heard of (and seen) many people have o2 sensors among other things fail after using seafoam. It's pretty much because it cleans it so well, the deposits all try to rush out the exhaust and cake on the filters and in the catalytic converter(s,) causing failure.
    But if you do it regularly, so there are not super large deposits, you may have better luck. I run Valvoline full fuel system cleaner every oil change. Just dump it in my tank, fill it up, (so it mixes with the fuel a little better than just dumping it in on top) and roll. Some people say it's snake oil, meaning it's a load of crap, and it may be. But if done right, (meaning it's done at intervals, not just when the system is already loaded up with trash) it shouldn't cause any problems.
    I know some mechanics that swear by this sort of stuff, and some that will urge you to steer clear of it. I'm of a rather mixed opinion, myself, but everyone's gotta formulate their own opinion, and the only way to do such is to do it and learn from it.
  14. Feb 1, 2016 at 5:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I try to stick with Top Tier Fuels so I don't have to bother with any cleaners
    Torspd likes this.
  15. Feb 2, 2016 at 4:44 AM
    PackCon
    Connor
    Excuse my ignorance but how does one do that?
    How do you know what truck dropped off what gas at a certain station?
  16. Feb 2, 2016 at 6:11 AM
    PackCon
    Connor
    Actually, I went through and watched all that guys videos and the Seafoam actually performed better than everything else he tried.
    I also wonder if that product is better because it doesn't go into your fuel system. I wonder what kind of harm (if any) can be caused the the fuel filter by adding cleaners to the fuel tank.
  17. Feb 2, 2016 at 9:19 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Like others have mentioned, I too use Chevron Techron every oil change for peace of mind. I have a few bottles stocked up when they are buy one get one free from Autozone. I also run a bottle when I go on a road trip when I know i'll burn through a few tanks before I get to my destination.
  18. Feb 2, 2016 at 9:55 AM
    Lester Lugnut
    Your point is well taken - I wonder the same.
    http://www.toptiergas.com/retailers
  19. Feb 2, 2016 at 11:49 AM
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    Yes I agree I guess I'm just a negative Nancy when it comes to stuff like this. Same as claims that some produce is grown organicly. How often is this verified and even if it is how bout the neighbor that is spraying pesticides all over the place LOL.
  20. Feb 2, 2016 at 4:32 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I have also run chevron techron. I also run Berryman. Not sure if it is axualy doing anything but like other have said , it's proventative maintain. I also run nothing but shell gas .
