Fuel injection cleaning service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by scully, Feb 4, 2010.
  1. Feb 4, 2010 at 9:18 PM
    scully
    scully [OP] Well-Known Member
    San Diego, CA
    06 TRD Doublecab
    Rear TSB FJ Cruiser TRD anthracite wheels Bilstein 5100's allround Tint
    Was at Firestone today getting oil changed...I know should do it myself but time it tight these days. Anyway, they tried to sell me their "Fuel Injection" service for $89.00, which they recommend every 15k miles. Worth it, waste of money??
  2. Feb 4, 2010 at 9:20 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Run good higher octane gas and punch it once in awhile... injectors clean.
  3. Feb 4, 2010 at 9:23 PM
    Ptowntaco
    Ptowntaco Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
    youcan buy cleaner your self for like 15 bucks.... cant you?
  4. Feb 4, 2010 at 9:32 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    They're trying to up-sell you. They're probably going to pour a $5 bottle of something in your gas tank, save your $$. Watch out for the $80 cabin air filter too...
  5. Feb 4, 2010 at 9:36 PM
    scully
    San Diego, CA
    06 TRD Doublecab
    Thought so. Most manufactures don't even recommend fuel additives. I run 91 octane, get on it now and then and should be fine for 100K miles. Can't blame em for trying to make $$ I guess.
  6. Feb 4, 2010 at 9:38 PM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Does anyone run cleaner through the fuel system on a regular basis? Are they worth it?
  7. Feb 4, 2010 at 9:46 PM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    subscribed
  8. Feb 4, 2010 at 9:46 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    That shit is snake oil.
  9. Feb 4, 2010 at 10:59 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Yup.
    Though to be fair, some shops will actually remove the injectors and clean them. That can be useful... but honestly I'd only do it if there was a noticeable drop in performance, mpg, ect. With all the cleaning additives put in fuel these days, it's kind of a mute point.
  10. Feb 4, 2010 at 11:11 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Sure, I run Chevron with techron every 8-10 thousand miles. When I get up there in miles, I'll run some Seafoam cleaner. And I would say it is worth it, keeps everything clean.
  11. Feb 4, 2010 at 11:29 PM
    got_titan
    got_titan Well-Known Member
    sevierville, tn
    2010 trd sport dc 4x4
    i agree on the sea foam. just bought a 01 dc 3.4 and it was sluggish, had a bad idle and low power and mileage. did the seafoam through the brake booster line and the rest in the tank and within 200 miles it was a different truck. the power was back along with a steady idle and mileage.
  12. Feb 4, 2010 at 11:30 PM
    thisERICtaco
    thisERICtaco Well-Known Member
    Eric
    CA, oc
    06 AccessCab SR5
    well i work at toyota
    and to tell you the truth
    we use a product called "MOC fuel injector cleaner"
    its a kit that goes for about 30 bucks my price
    its basically a can of carb cleaner to clean the throttle body of carbon build up
    a bottle of fuel additive like lucas to pour into the gas tank
    and a bottle of injector cleaner that hooks up to a vacuum like usually the brake booster line and slowly let it suck up the fluid to swish around injectors to clean them.
    thats basically it
    you can buy something similar like at autozone or kragen and its called "seafoam"
    check it out
  13. Feb 4, 2010 at 11:33 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    seafoam!
  14. Feb 5, 2010 at 1:19 AM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    x4 Did it to wifey's car (03 accord 4cyl 96000mi) and she can tell a huge difference
  15. Feb 5, 2010 at 4:55 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Shell gas takes care of my injectors. I don't run much else.
  16. Feb 5, 2010 at 5:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Seafoam once in a while (do be careful as you can fuck up your cat converters with it)
    The Firestone fuel service is the vacuum induced style but is WAY more expensive than a bottle of seafoam....Your money is better spent elsewhere.
  17. Feb 5, 2010 at 9:41 AM
    dually
    dually Low and slow
    Or just pull the injectors and get them flowed and actually **cleaned** for $10 a piece at most shops.
  18. May 1, 2014 at 10:55 AM
    waheed
    waheed Well-Known Member
    Waheed
    Vancouver
    2010 Tacoma TRD OFF-ROAD
    Banks power Exhaust, 4x4 LED mod, Duratracs, SNUGTOP, LED insideNout
    I just talked to Toyota dealership in Canada here....they say that they drop the gas tank hookup another tank of something and flush the fuel lines and then reconnect the gas tank. I guess things changed since last post here in 2010. For $169
  19. May 1, 2014 at 11:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I think your dealer fed you a line of crap. They ain't dropping the gas tank and flushing the system for $169.00. The only part of an injector that you can clean is the spray holes on the outside of the injector to remove any build up from crappy gasoline. Don't get gas from a 3rd world country and you will not have any issues.
    The insides cannot get dirty as it is sealed ( welded together ), has a 1 micron inlet filter pressed into the inlet.
    I noticed an earlier post said something about getting the injectors removed and " flowed" whatever that is and cleaned. The flow can be checked but is set at manufacture and is not adjustable after.
  20. May 2, 2014 at 4:49 AM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Tell them you'll be there when they drop the tank and connect up that special tank of cleaner. That needs to be on video. Think they'd agree?
    Ethanol is both good and bad; the good it that it is a helluva cleaner. Likely don't need anything else unless you want to add Techron. Seafoam if it gets to that point.
