Fuel Gauge stuck on full in 2020 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lynx416, Apr 6, 2023.
  1. Apr 6, 2023 at 8:15 AM
    Lynx416
    Lynx416 [OP] Well-Known Member
    2020 Tacoma TRD Sport
    Running boards, Tonneau cover
    Hi,
    My fuel gauge is stuck on full in my 2020 Tacoma and is not moving. I am probably just outside the warranty, which sucks. Only 19,000 Km but just over 36 months. I see some newer Tundra’s are having this issue and thrust is a calibration issue. My distance till empty is counting down but it is showing a lower driving distance when the tank is filled.
    I hope it isn’t a sending initial unit as that is costly.
    Any thoughts?
  2. Apr 6, 2023 at 9:27 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    first thing to check is; see if your truck falls under the fuel pump recall. I can't remember the years it spanned, I know my 2019 was cause I had it done.
    Lynx416[OP], MadKatt and na8rboy like this.
  3. Apr 6, 2023 at 10:12 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Most likely.
    some say removing the bed is easier then dropping the tank to get at the sending unit.
    do what @Chew said first
    Lynx416[QUOTED][OP] and Chew like this.
  4. Apr 6, 2023 at 11:41 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    maybe you're just getting really good gas mileage.
  5. Apr 6, 2023 at 11:42 AM
    twtaco$
    twtaco$ Well-Known Member
    How long has it been like this. My old truck if you had the key on it would stick it on full for a while then return to normal. Didn’t like me filling the tank with the key on engine off. Just a thought
    Lynx416[OP] likes this.
  6. Apr 6, 2023 at 11:44 AM
    avi8or_co
    avi8or_co Well-Known Member
    2019 Cavalry Blue TRD Sport, 2023 Lexus IS500
    You’re very likely in the fuel pump recall group, I’d look into it. Fuel sensor is on the pump itself and they replace the whole assembly with the recall.
  7. Apr 6, 2023 at 12:41 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    Infinite gasoline glitch!
    :D
  8. Apr 6, 2023 at 4:44 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Car companies hate him. Governments want him silenced. Gas stations are scared to death. It’s… infinite MPG man.
  9. Apr 6, 2023 at 5:10 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Gazillion mpg
  10. Apr 8, 2023 at 6:40 AM
    Lynx416
    I wish. A heavy duty mechanic friend of mine suggested I disconnect the battery for a hour and see if that resets it.
  11. Apr 8, 2023 at 6:41 AM
    Lynx416
    I searched by VIN and I don’t appear to be. According to my VIN there are no outstanding recalls.
    Or is this a hidden recall?
  12. Apr 8, 2023 at 6:59 AM
    auskip07
    Skip
    Atlanta, Ga
    why an hour? couldnt you just disconnect and then cycle the key to drain the system?
  13. Apr 17, 2023 at 6:37 PM
    Lynx416
    Resetting battery power definitely reset my fuel gauge, I am happy I didn’t go the expensive route of trusting a dealership to solve this. I only disconnected the battery a few minutes.
    Superdave1.0 likes this.
  14. Apr 17, 2023 at 6:47 PM
    dljohndrow
    dljohndrow Well-Known Member
    Dave
    2018 Tacoma
    I had this happen a couple of months ago. I don't drive my truck much and I think that may have been my issue. A bottle of fuel system cleaner did the trick in about 10 minutes of driving.
  15. Apr 17, 2023 at 6:52 PM
    Lynx416
    My truck is a low mileage vehicle too.
  16. Apr 18, 2023 at 2:09 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    WOW! i guess with these 3rd gens when something goes wrong do just like you would with a TV or Computer, unplug and plug back in.
