Fuel Filter location 07 tacoma
Discussion in '4 Cylinder' started by boatflower, Jul 31, 2018.
  1. Jul 31, 2018 at 8:58 PM
    boatflower
    boatflower [OP] Member
    Where is the fuel filter located on a 07 Tacoma?
  2. Jul 31, 2018 at 9:13 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    Fuel filter is part of the pump unfortunately. Only way to change it is to drop the tank.
  3. Aug 1, 2018 at 6:17 AM
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    behind the ashtray
    HiperTexas likes this.
  4. Aug 2, 2018 at 9:23 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    There is no "proper" fuel filter in your truck. The filter mentioned by tinker_troy is a sock over the fuel pickup tube, which does a good enough job of screening out particles to keep the injectors from plugging. But I would not call it a filter. Anyway, the factory system works fine and 99.99% of owners will not see a problem related to fuel filtering. Some people have installed aftermarket inline fuel filters, you could probably find those threads with a search.
  5. Aug 2, 2018 at 9:24 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    As others have said, it's inside the tank. URD makes a external filter conversion though, and it makes the fuel filter super easy to change. Did mine for the first time in about 10 minutes last night.
