Fuel Door Lube / WD40
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOma_2012, Dec 14, 2023.
  1. Dec 14, 2023 at 7:11 PM
    TACOma_2012
    TACOma_2012 [OP] New Member
    Fuel Door Lube / Wd40
    Fuel door for almost all tacomas has been a problem. Its Hard to open, Bent, rubbing noise, and rusted hinge. Some say apply Wd40, Lube, or Grease? Some say Apply Wd40 then apply Lube later on?
    What to apply(product) and why?
  2. Dec 14, 2023 at 7:17 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    I don't have any issues with my 06's fuel door
    I consider WD40 a solvent more than a lubricant
    50Buck and gotoman1969 like this.
  3. Dec 14, 2023 at 8:00 PM
    whiteknight4x4
    whiteknight4x4 Well-Known Member
    Drew
    Missouri
    2008 SR5 Reg Cab Taco
    2.5 inch lift: Full Dobinson's suspension kit, Freedom Off-road UCAs, 265/75r16 tires on factory Baja alloy wheels. x2 Baja Designs Squadron Sport Led Pod lights. CBI Moab 2.0 Aluminum Bumper w/full hoops, Warn Evo 8k winch. Ultraguage. Midland CB radio with 3ft Firestick Firefly. Tacomabeast/Spyder Headlights. Rear diff breather. Cruise mod. A.R.E. Topper. Prinsu topper roof rack. Hail damage mod.
    I used Ballistol on mine when it started doing that. Worked like a charm. It’s a true lubricant and prevents rust. You can clean guns with it and all sorts of stuff.
    Torspd likes this.
  4. Dec 14, 2023 at 8:01 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Original WD40 is not a lubricant. The brand does make lubricants that work great just read the description on the can.
  5. Dec 14, 2023 at 8:03 PM
    Al Hoff
    Al Hoff Well-Known Member
    Grand Rapids, MI
    2018 Tacoma Off-Road QUICKSAND
    Mine jammed up and bent hinges on a cold day at the gas station. Just had to bend it back and I shot it with a little bit o lithium grease.
    Rocketball likes this.
  6. Dec 14, 2023 at 8:17 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I used a little chain lube, works like a champ!
  7. Dec 14, 2023 at 8:26 PM
    TacoTuesday1
    FL
    I WD40 hinges every so often. Never had this happen
  8. Dec 14, 2023 at 10:12 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Probably any grease would work. Maybe try lard?
    O'DubhGhaill likes this.
  9. Dec 14, 2023 at 11:05 PM
    Waasheem
    Waasheem
    2007 xrunner
    Wd40 then lube serves a purpose. Wd40 penetrates, lube after will be pulled in. If you put just lube, it might not penetrate in as good or at all.
  10. Dec 14, 2023 at 11:38 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Pull dipstick to check engine oil. Wipe off dipstick with fingers. Lube hinge with fingers. Done.
    Big tall dave, Torspd and SR-71A like this.
  11. Dec 14, 2023 at 11:56 PM
    MGMDesertTaco
    I use Blaster Silicone Spray from Home Depot. It's not messy like white lithium grease and won't attract a bunch of dirt. Works well for door hinges, fuel door hinge, tailgate hinge, garage door tracks ect.
    Canadian Caber and TacoSR523 like this.
  12. Dec 15, 2023 at 12:17 AM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    I vote for chain lube; I use it on all hinges.
    Big tall dave, Rocketball and 23MGM like this.
  13. Dec 15, 2023 at 12:38 AM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    Fluid film
  14. Dec 15, 2023 at 1:08 AM
    TacoSR523
    TacoSR523 Well-Known Member
    VA
    2023 Tacoma SR5 Barcelona Red
    Just a few accessories, mud flaps, bed cover , racks, seat covers, ….
    Yup, that’s what use.I also use it on bikes motorcycle chains.
    MGMDesertTaco[QUOTED] likes this.
  15. Dec 15, 2023 at 10:50 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    WD-40... Water Displacement mixture 40. that is what its name means. and it is not the best lube, I use lithium on things but I also have a lot of white lithium grease.
    wilcam47 likes this.
  16. Dec 15, 2023 at 11:17 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    WD40 is great stuff but it is not a lubricant. Use either a spray can of silicon spray lubricant or white lithium lubricant.
  17. Dec 15, 2023 at 12:58 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    No WD40 is not a lubricant, but it can work. At least temporarily, and it will flush out rust and dirt from the hinge. Once that is done there are better lubricants I like white lithium grease.
  18. Dec 15, 2023 at 1:04 PM
    Pyts
    Pyts Well-Known Member
    09 2.7 RWD
    Stock
    white lith < silicone paste < dow corning molykote 33
    or. whatever's lying around. get a new door from the junkyard :(
  19. Dec 15, 2023 at 5:29 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    Yup, Blaster white lithium spray after some WeaponShield lube. GTG.
    Pyts likes this.
  20. Dec 16, 2023 at 5:38 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Be unique. Use paraffin wax or bees wax. :D
    Pyts likes this.
