Fuel door lock replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cooperoso, Jan 17, 2010.
  1. Jan 17, 2010 at 3:01 PM
    Cooperoso
    Cooperoso [OP] New Member
    Ohio
    Tacoma 99
    Hi,
    The Fuel door lock on my Tacoma stopped working. Can anyone tell me where to best get a new lock or another way I can fix this problem? I disassembled the lock so I could reliably fill the tank and my door swings open every time I park.
    Thanks for any help,
    C
  2. Jan 17, 2010 at 3:02 PM
    SACTOWN
    SACTOWN Mr. bougie, apparently
    Greg
    Duct tape!?!?!
  3. Apr 1, 2010 at 5:00 PM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2020 TRD PRO 6sp
    free bump
    i just got my taco and my door/ignition key didnt work so i had to break the back tab of the lock...
    Anyone know a good replacement?
    Toyota dealership = $75.23 for lock replacement assembly
  4. Apr 1, 2010 at 5:08 PM
    th3bigk0
    th3bigk0 GETTN IT
    Dylan
    Lamecaster
    13 TRD Double Cab
    Fox 2.5 RR C/O's,Camburg UCA,Camburg Spindles,KING 2.5,OME Dakar Leafs,285 KM2,XD HOSS 16'',BHLM,HID's,CB,Hornblasters Shocker 540 train horn,KICKER 12 ported....
  5. Apr 1, 2010 at 5:12 PM
    oldsman71442
    oldsman71442 Well-Known Member
    Jeff
    oahu HI/ Redding CA
    10 DC 4x4 TRD Sport
    I just used a magnet and put it on the interior of my gas tank door and it stayed shut... they are super easy to replace if you try to replace the lock cylinder
  6. Apr 1, 2010 at 5:14 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    i'd measure it and go to either a locksmith and have him order one or a hardware store and look for a replacement
  7. Apr 1, 2010 at 5:22 PM
    mattleegee
    Tacoma, WA
    2020 TRD PRO 6sp
    I know they are super easy to replace but just finding one is what concerns me, i will pop mine off and see what i can figure out (googles: tacoma, washington locksmith)
  8. Apr 1, 2010 at 5:31 PM
    ak47
    Anthony
    Washington
    stock 2nd owner
    also when you say it doesnt work what do you mean? do you mean it wont turn? did you try to spraying it with wd40? and i know that not all my door keys will work in it maybe try your spare door key? idk just a thought
  9. Apr 1, 2010 at 7:31 PM
    mattleegee
    Tacoma, WA
    2020 TRD PRO 6sp
  10. Apr 1, 2010 at 7:33 PM
    mattleegee
    Tacoma, WA
    2020 TRD PRO 6sp
    I got one key with the truck... and it doesnt work, only in the doors/ignition, belive me i tryed different depths, angles, degrees, no go on key, i was stranded at a gas pump with no gas and needed a fix then...
  11. Apr 7, 2010 at 5:17 PM
    Cooperoso
    Ohio
    Tacoma 99
    Thanks everyone for the feedback.
    I will be trying the magnet first then the replacement Cylinder and key set.
    C
  12. Aug 18, 2014 at 6:48 PM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    Reviving an old thread here.
    I have the same problem on my 98.
    The tab is already broken so now the door just swings freely. Ive also seen that the 2001-2004 fuel doors are the same type/style as the 2nd gens. Has anybody tried putting this fuel door assembly on the pre 2001?
  13. Aug 19, 2014 at 1:14 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    not to advance your old revival but the 01-04 has a plastic tab that the door latches on to (spring clip) so you could replace the entire door/interior filler piece (not the neck just the plastic piece)
  14. Aug 19, 2014 at 6:49 AM
    mmadej87
    mmadej87 Mayday
    NMB, FL
    98 Xcab Prerunner
    yea thats what im looking at. i inspected mine and i see all that holds it in is 4 philips head screws. just wondering if anybody has tried this, hopefully toyota will sell me one already color matched
  15. Nov 12, 2016 at 6:28 PM
    Nsteinbock
    Nsteinbock New Member
    Brea, ca
    00 Prerunner
    Try getting a master key made and use that. $20 at dealership. Could be old key is worn and doesn't bring pins down and lock cylinder is fine.
  16. Nov 12, 2016 at 6:48 PM
    Indy
    Indy Master of all I survey.
    I found having to unlock it every time was really annoying. 2 seconds to fix it.
  17. Nov 15, 2016 at 6:03 PM
    Nsteinbock
    Brea, ca
    00 Prerunner
    Took door lock cylinder apart to clean tumblers and didn't notice where spring was. This is a pic of after I put it back together. Just wondering if anyone knows if this is the correct placement of the spring. Thanks.
  18. Nov 15, 2016 at 9:08 PM
    96Tacoma4WD
    96Tacoma4WD Well-Known Member
    So Cal
    1996 Toyota Tacoma V6 2dr Extended Cab 4WD SB
    Alpine head unit and CD changer
    WD-40 with alot of movement - worked for me. usually gets stuck with dirt over time.
  19. Nov 15, 2016 at 10:28 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    My 01 fuel door doesn't even have a lock
    Man my poverty spec keeps getting poorer
  20. Nov 16, 2016 at 6:44 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Either does my 04. I use a locking gas cap. Although I've seen thieves just cut the fuel line and drain it that way in certain vehicles.
    PROseur[QUOTED] likes this.
