Fuel additive?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jan 17, 2024.
  1. Jan 17, 2024 at 6:00 PM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Any of you guys running a fuel additive occasionally that you put in the gas tank? Like chevron, lucus, seafoam, amsoil? I started using amsoil upper cylinder lubricant recently on my new 23 tacoma.
  2. Jan 17, 2024 at 6:13 PM
    MGMDesertTaco
    I use Chevron Techron and Lucas total fuel system treatment with Costco gas. Lucas seems to make a small noticeable difference, the Chevron Techron not so much.
    MKC1911 and Gfenza89[OP] like this.
  3. Jan 17, 2024 at 6:34 PM
    eurowner
    eurowner Duke Sky
    Scoty
  4. Jan 17, 2024 at 6:43 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Every now and then when I'm feeling my pockets are deep i'll dump in two bottles of the cleaner on sale.
    When I buy a new used car like most recently a 92 Camry, and I actually want to attempt cleaning, I get ACDelco fuel system treatment-gasoline.
    To be honest, if you use Top Tier gas and take a highway drive every now and then you don't need cleaner
    TnShooter, RDT415 and Gfenza89[OP] like this.
  5. Jan 17, 2024 at 6:46 PM
    Gfenza89
    I only run shell, Exxon, or Sunoco or any other top tier fuel. Still like to use the fuel additive though sometimes
  6. Jan 17, 2024 at 7:08 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    I run Amsoil PI every oil change
  7. Jan 17, 2024 at 7:12 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Every couple of months I put in a can of gumout multi system fuel cleaner. It has PEA in it which is what you need. I don’t know if it works but I have never had a issue with fuel delivery. Occasionally I’ll check the trim level with my OBD scanner and its +/- 1. That’s pretty good for 190,000 miles.
    Gfenza89[OP] likes this.
  8. Jan 17, 2024 at 7:21 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    My limited experience:
    2 F-150 4.9's that went 375K plus - no additives and no related issues from the lack thereof.
    2 1st gen Tundras that went 350K plus - no additives and no related issues from the lack thereof.
    2 2nd gen Tacomas that went 350K plus - no additives and no related issues from the lack thereof.
    All running the cheapest 87 in whatever town they lived in at the time.
    Take it for what it is..
    Used to use all that shit when I was a kid though. lol
    Even Slick-50 :rofl:
  9. Jan 17, 2024 at 7:23 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No. Why.
  10. Jan 17, 2024 at 7:24 PM
    Gfenza89
    Good stuff
  11. Jan 17, 2024 at 7:25 PM
    Gfenza89
    Good to know thanks
  12. Jan 17, 2024 at 7:54 PM
    Dead-Weight
    Dead-Weight Well-Known Member
    Scott
    Sedalia, CO
    ‘22 OR Lunar Rock
    Pine tree air freshener
    Why do you feel that you need to use the additive? Does your engine run rough? I haven’t had mines long enough to notice anything that needed fuel additive to correct.
    TacoSR523 and BMH like this.
  13. Jan 17, 2024 at 8:17 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    I use a bottle of this or that in the tank every few months. Lucas is my first choice, but I’ve used the others.
  14. Jan 17, 2024 at 8:31 PM
    WA7
    WA7 Well-Known Member
    Craig
    PNW
    2021 Trail Edition
    One bottle of Techron with my last fill up before each oil change.
  15. Jan 17, 2024 at 9:09 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    I do the same. The PI interval is a shy of the OCI but it's close enough for me.
  16. Jan 17, 2024 at 9:25 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Sta-bil when my truck sits from Dec through April. Nothing else.
    Remember anything other than gasoline in your tank has a chance of poisoning your catalytic converters.
  17. Jan 18, 2024 at 12:14 AM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    you know that tick tick sounds you hear once in awhile , its self cleaning my friend :gossip:theres no need to add some feel good in a bottle :laugh:
    TacoSR523, Dead-Weight, BMH and 3 others like this.
  18. Jan 18, 2024 at 3:59 PM
    Gatafly
    Shawn
    So what is the magic tik tik cleaning, the engine switching over to port injection? Normal port injectors get dirty over time. A decent injector cleaner can help over time and probably increase the cleaning of the valves. If you don't keep your vehicle for many years than probably not needed, but I keep mine a long time and never once had an issue.
    TartanEagle and Gfenza89[OP] like this.
  19. Jan 18, 2024 at 4:04 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    My 3RZ gets a glass of Saki every full moon. Very effective.
  20. Jan 18, 2024 at 4:05 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Techron is a great product. I stock up when my local Advance auto parts store runs a BOGO sale on it.
    Williston likes this.
