FS: 2016 Toyota Tacoma Matte Black and Reflective Black Vinyl Decal Tailgate Inserts
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by rrentrop, Nov 1, 2015.
  1. Nov 1, 2015 at 1:50 PM
    rrentrop
    rrentrop [OP] TVDvinyldecals.com Vendor
    Rich
    Orange County, CA
    2016 Tacoma 4x2 Limited MGM
    T-Rex Billet Grille, N-Fab Steps, Tailgate decals, Bed Lights, Power Tailgate Lock
    Customize the appearance of your 2016+ Toyota Tacoma with these precision cut vinyl decal inserts for your tailgate. These decals provide a finished look to the stamped “TACOMA” letters on your tailgate. Made from premium cast 2 mil vinyl film, these decals are designed for permanent applications and have a durability rating of 10+ years when properly applied.
    Price = $20 + $3 for shipping with tracking. Combined shipping on multi-item orders and free shipping when you order 3 or more items!
    http://stores.ebay.com/tacomavinyldecals
    Custom colors are available in 751 vinyl (7-8 year durability). Please PM me if you are interested in something other than matte or reflective black. I can get most of the colors listed here if there is sufficient interest:
    http://www.orafol.com/gp/europe/en/support/colour-cards/oracal-751c-high-performance-cast
    I have gloss white, gloss red, gloss light gray, gloss dark gray, gloss black, anthracite (dark gray metallic) and silver metallic vinyl in stock, some with matte options. I also have reflected red and blue available.
    Details instructions are below the attached images (and included with each order).
    This installation should take about 30 minutes. Here is what you will need:
    Denatured or Isopropyl alcohol
    Spray bottle
    Water
    Dish soap
    Masking tape
    Soft towel
    Proper cleaning and preparation of the surface prior to vinyl application is critical to the success of the decals. The following cleaning and surface preparation conditions must be followed immediately prior to application. Failure to adhere to these requirements can cause adhesion loss and therefore reduce the durability and performance of the decals.
    1. Position your truck in a well-lit area away from direct sunlight. The optimum temperature range for vinyl adhesion is 60 to 80 degrees F.
    2. Clean the stamped letters on the tailgate with denatured or isopropyl alcohol to remove any dirt, wax, or oils that may exist. Be sure to test in an inconspicuous area on the vehicle first to make sure the alcohol doesn’t damage the paint.
    To ensure proper alignment within the stamped letters on the tailgate, we recommend the “wet” application method. Apply one decal at a time and be patient! We include one extra “practice” decal letter (T) to familiarize yourself with the application process.
    1. Make a soap solution by filling a spray bottle with water and adding 3-4 drops of dish soap for every 6 oz. of water.
    2. Spray the stamped letter on the tailgate with the soap solution, ensuring that the entire stamped area is wet.
    3. Peel the corresponding vinyl decal letter from the paper backing and spray the adhesive side with the soap solution. Use masking tape to separate the vinyl from the backing paper if it does not peel cleanly.
    4. Carefully apply the vinyl letter within the stamped letter on the tailgate and position it so that it is centered in the deepest area of the stamped letter. The soap solution will help move the decal to the desired position before the decal adheres to the vehicle.
    5. Anchor a corner of the vinyl decal letter with your thumb and gently slide your other thumb across the letter to squeegee the water out from under the decal. Do this lightly at first to allow you to reposition the decal as needed as you squeegee it with your thumb. The vinyl will quickly adhere to the vehicle as the moisture is removed with each pass of your thumb so be sure it is positioned correctly and make several light passes over the decal. Once adhered to the vehicle the vinyl decal letter cannot be removed with destroying it (This is why we provide the “practice” decal letter).
    6. Gently blot the excess moisture from the area with a soft towel and make several more gentle passes with your thumbs until there is no more moisture coming out from under the vinyl decal.
    7. Repeat these steps for the remaining letters.
    8. After all the vinyl decal letters have been applied return to the first decal and use a bit more pressure with your thumbs to squeegee out any remaining moisture. Repeat this final step on the remaining vinyl decals.
    Please allow 24 hours for the vinyl decals to completely dry and properly adhere to the tailgate. Do not get the vinyl decals wet during this time.
    These videos show the wet decal application process on different vehicles, but it is essentially the same on the Tacoma:
    https://www.youtube.com/watch?v=9c6bxUnZBVg
    https://www.youtube.com/watch?v=sjqoqRhi5WU
    Please note that the above instructions are based on industry standards for vinyl applications on automobiles. When properly applied these vinyl decals should last for 10 or more years with no shrinkage or peeling. Since we cannot control the actual application process we do not provide any warranty as to the durability and longevity of these vinyl decals. If after applying the “practice” letter you don’t feel that you can complete the installation yourself, I am sure your local window tint/auto graphics shop can do it for a nominal fee.
    Sauzacoma, Ry_Guy28, AgeGuy and 3 others like this.
  2. Nov 18, 2015 at 5:25 PM
    Sauer Taco
    Sauer Taco Well-Known Member
    Paul
    Finksburg MD
    16 TRD Sport DCLB BBP
    Just bought and having a friend install these as well as doing my tint. he does this for a living. Thanks!!
    rrentrop[QUOTED][OP] likes this.
  3. Nov 21, 2015 at 1:39 PM
    bflofoxrider
    bflofoxrider Well-Known Member
    Brandon
    Fayetteville, NC
    2014 Tacoma DoubleCab 4x4
    do you have the ability to print color on vinyl at all?
  4. Nov 25, 2015 at 8:22 PM
    cain0725
    cain0725 Well-Known Member
    2016 TRD off Road
    OEM leveling kit
    just ordered mine from ebay,, thanks and i hope it goes well!
    rrentrop[OP] likes this.
  5. Nov 25, 2015 at 9:19 PM
    DJSPEC
    DJSPEC @GuardianAdventures
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    Viper Alarm NorthStar 31 Battery Pelfreybilt Battery Cage OEM roof racks, step sides 35W 6000k HID Fog Lights 35% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Firestone Destination MT/2 295/70R17 Method 702 17” 0 offset Wet Okole Seat Covers OEM Tow Hitch Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar Snugtop Rebel King 2.5 adjustable front and rear Dakar HD Leaf Springs Icon tubular UCA Dirt Kings LCA
    Just got these installed! This would be impossible to install without the water and soap mixture! I used a tweezers to peal the decal off the paper backing.
  6. Nov 25, 2015 at 10:42 PM
    rrentrop
    Rich
    Orange County, CA
    Not at this time, but I will look into it.
  7. Nov 30, 2015 at 6:17 PM
    Caliph420
    Caliph420 Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    Just got mine from your eBay store, great value, love the new look, if you follow your directions page and use plenty of solution to keep it wet its easy
  8. Nov 30, 2015 at 9:48 PM
    rrentrop
    Rich
    Orange County, CA
    Looks great! The matte black on MGM is very subtle in certain lighting conditions, but then can stand out in others.
  9. Dec 8, 2015 at 3:10 PM
    mjones1970
    mjones1970 Well-Known Member
    What do you all think would look nicer, black or chrome on a red limited that has the 4x4 and v6 chrome emblems on the tailgate?
    The black would complement the black part of the bumper but I wonder about chrome to match the emblems.
    Thanks for your feedback.
  10. Dec 8, 2015 at 3:51 PM
    13bajaguy
    13bajaguy Well-Known Member
    Bozeman,MT
    MY 15 Tacoma
    Stock for now
    I was wondering where these were coming from... Gotta order some!
    Millerman93 likes this.
  11. Dec 8, 2015 at 6:10 PM
    mjones1970
    Thanks, with yours and the OPs feedback I ordered the black.
  12. Dec 11, 2015 at 10:21 AM
    bflofoxrider
    Brandon
    Fayetteville, NC
    If you find someone who can print graphics on vinyl to match my grille lettering, I'll definitely order a set ☺️image.jpg
  13. Dec 19, 2015 at 7:08 PM
    manfrommarrs
    manfrommarrs Member
    Marcus
    2016 Tacoma Access SR 2.7L Auto
    Mine's basically an office on wheels, I drive 50k+ miles a year. I have a computer desk bolted to the front inner passenger seat rail. Also has a Lund tri-fold tonno cover to carry catalogs and product samples. Eventually want to get a Leer or ARE camper top with side fold out windows.
    Just ordered a set today.
    BTW, can you make precut vinyl for the rocker panel sections? See that lower body "cavity" between the wheels and that small one just in front of the rear bumper? I want to give my truck a little contrast so it doesn't look like a parts store delivery truck, LOL. I could probably do it from scratch with some vinyl but I don't want to take an exacto knife after my truck.
  14. Dec 21, 2015 at 8:49 AM
    rrentrop
    Rich
    Orange County, CA
    Coming soon: Dark Grey Metallic (similar to MGM). These will look good on black and on silver Tacomas. They will be available for sale next week.
  15. Dec 21, 2015 at 12:37 PM
    HCTacoGuy
    HCTacoGuy Well-Known Member
    Homer City PA
    2025 Tacoma TRD Sport 4x4 Black
    Ready Lift SST 2.5 lift Method Black 703 17 x 8.5 +35
    I am looking for a set of the silver metallic to match the sport logo. I couldn't seem to find the silver on Ebay, can you send me a link to order the silver ones?
  16. Dec 21, 2015 at 12:42 PM
    rrentrop
    Rich
    Orange County, CA
    You can order them directly from me. PM'd.
  17. Dec 21, 2015 at 9:14 PM
    metdfd
    metdfd Well-Known Member
    Just purchased a set from your eBay listing. Can't wait to receive them
  18. Dec 22, 2015 at 6:00 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Nice, I remember doing this to my old mustang rear bumper. Definitely looks better than bare paint no matter what color you go with.
  19. Dec 22, 2015 at 6:01 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Black Tacoma lettering and pleeeeeeze get some fishing line and remove that dealer emblem up top.
    brendanwebster911 likes this.
  20. Dec 22, 2015 at 10:36 AM
    rrentrop
    Rich
    Orange County, CA
    Also now available is reflected black, red, and blue.
