Front window glass busted, then regulator breaks? Am I getting screwed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nautilus, Jun 26, 2020.
  1. Jun 26, 2020 at 6:58 PM
    nautilus
    nautilus [OP] Member
    2002 Tacoma
    Hey TW, got my front drivers side window busted out last night and am supposed to head on a camping trip tomorrow, so I called around and found the only place who could come out today and put in new glass. Everything was working fine before this.
    The dude said the window motor had also broken, but was able to "fix" it, and now it rolls up and down but is slow and makes a loud sound, kinda like it's off track or starting to fail? I've had broken windows in the past and never had a regulator and motor conveniently also break at the same time.
    Did he mess something up, or is it totally possible that it really broken because of the broken glass?
    For the record, I'm about to order a new regulator and motor and will put it in (myself) when I get back from my trip. Any recs on best parts would be dope, I'm thinking of ordering a Dorman part for value/ease.
  2. Jun 26, 2020 at 7:03 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Seems unlikely the regulator would be damaged from getting the glass broken. I would try not to use it until you can get in there and see what's going on. Possibly the window run (rubber in the tracks) has gotten out of place and is causing binding of the glass in the track.
  3. Jun 26, 2020 at 7:07 PM
    Wsidr1
    Indiana
    The lower part of this rubber glass run can easily come out of the parts marked Front and Rear Lower Frame. The glass will bind up and the window will move slower.
  4. Jun 26, 2020 at 9:34 PM
    nautilus
    2002 Tacoma
    Thanks for your help! Turns out the dude used electrical wire to tie in the window instead of bolting it (???). I have no idea why, other than when I was realigning the glass to sit on the regulator the bolts and the glass didn't seem to line up. I don't know enough about how regulators operate to know if there is something wrong with the regulator or not, but it seems fine, maybe just a bit wobbly.
    wilcam47 likes this.
  5. Jun 27, 2020 at 3:00 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Looks like the bolt got dropped .
    is it in the bottom of the door ??
    I have seen some aftermarket glass really poor but I doubt that is your problem
  6. Jun 27, 2020 at 8:56 AM
    nautilus
    2002 Tacoma
    Bolts werent in the bottom of the door, pretty sure the dude took them with him. Going back to the place today to make sure they fix it. Pretty damn annoyed since I was trying to leave to camp today and I can't even easily fix it myself.
  7. Jun 27, 2020 at 9:10 AM
    dblees
    dblees Well-Known Member
    Dave
    SW Oregon
    02/01 TRD mongrel
    Short answer to your original question - YES, you are getting screwed, at least if you gave them money for this so-called "repair." Not sure what part of the world you live in, but around here anybody who cobbed a job that badly would likely receive... umm.... retribution. Using that wire instead of a bolt is unbelievably incompetent, imho. Good luck with the fix.
  8. Jun 27, 2020 at 10:44 AM
    nautilus
    2002 Tacoma
    Yeah, definitely got screwed. Looks like the bolts on the glass didn't line up correctly and that's why the dude did that sketchy fix. I'm pretty damn pissed, he also ripped off the water shield and threw it away, damaged the trim that holds the body clips in, AND scratched the door panel itself.
    He fixed it so the glass is bolted in now and lines up correctly, which is literally the bare minimum.
    Soooooo, uh....does anyone know where I can get a new water shield? I'm thinking I should be able to just cut some plastic sheeting to size.
  9. Jun 27, 2020 at 7:11 PM
    Wsidr1
    Indiana
    Starting point anyway.
    https://www.toyotapartsdeal.com/Pag...Filter=()&Keywords=67832&Source=PartRecommand
  10. Jun 28, 2020 at 9:49 AM
    paetersen
    paetersen Well-Known Member
    yes, cut some plastic sheeting to size, that is literally all it is.
  11. Jun 28, 2020 at 9:59 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    WHY are you taking your truck back to the guy that did this work?? Wire in place of a bolt?? He should not touch your truck again. Period.
    CrustyTaco likes this.
  12. Jun 28, 2020 at 10:06 AM
    paetersen
    Responsibility and Accountability. The shitgibbon who fucked it up needs to make it right.
    Hobbs and GQ7227 like this.
  13. Jun 28, 2020 at 10:36 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    In principal I agree with that statement. But once someone has been positively ID'ed as a grade A moron they don't get to work on my vehicles anymore.
    dblees and Hobbs like this.
  14. Jun 28, 2020 at 10:39 AM
    Hobbs
    Yep…
    Yes, without touching the truck. What kind of repair will he make next?
  15. Jun 28, 2020 at 10:39 AM
    Hobbs
    Yep…
    Word!
  16. Jun 28, 2020 at 10:42 AM
    Hobbs
    Yep…
    That's the kind of repair I'm looking for!
    High Noon likes this.
  17. Jun 29, 2020 at 5:40 AM
    Wsidr1
    Indiana
    I heard he got out of auto and started a pool repair company
    Hobbs[QUOTED] likes this.
