Front Wheel Bearing Hub Assembly Part Number - 5 Lug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by uaflyer, May 15, 2022.
  1. May 15, 2022 at 9:43 AM
    uaflyer
    uaflyer [OP] Active Member
    Ken
    2006 Tacoma Base 2.7L 4Cyl
    front mud flaps, seat cover
    As with many, I have had difficultly finding these. Checked the usual vendors, Amazon, Ebay, Rock Auto.
    This is for a 2WD RWD Base.
    Presume 6 hub is for 4WD, but funny its the same hub
    1) What is the part number that might cross to a reasonable resource.
    2) If anyone knows the part number for dust shields, {aka Brake plate) better is an after market stainless version/
    Finally, are there other seals and o-rings that are commonly replaced, but typically not included.
    Do rear o-rings or other parts also work on the front. I ask because at least the o-ring appears to by some vendors.
    Its been interesting that almost all the videos out there are using hub assemblies and not pressing bearings.
    I am generally lazy and don't have easy access to a press.
    Thanks
  2. May 15, 2022 at 9:54 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    It’s not an assembly, it’s a press fit deal so you’ll have to reuse your hub and press out the old bearing.
    Jimmyh likes this.
  3. May 15, 2022 at 10:12 AM
    uaflyer
    Ken
    Not doubting you , I was hoping a full assembly with lugs exists for ease and I have significant rust on the parts.
    Are there any other [arts besides the bearings that are re[;aced ?
    Thinking of just ulling fron a junk yard and press them separately.
  4. May 15, 2022 at 10:18 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I’m not super familiar with the 5 lug so hopefully someone who’s done the job can chime in, but I believe you might be able to just get a whole knuckle off a junk yard truck for a lot less work if you can find it. The 6 lugs have aftermarket hub manufacturers and many vendors sell the hub/bearing as a unit. 5 lugs aren’t so fortunate.
    Jimmyh likes this.
  5. May 15, 2022 at 10:24 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’ve never seen an assembly. If there were an assembly, it would have to include the knuckle/spindle. Like @6 gearT444E said.
    I know somewhere on this site, there is post with a .pdf on the process to replace bearings.
    I think @Dm93 posted it.
    6 gearT444E likes this.
  6. May 15, 2022 at 10:27 AM
    TnShooter
    Deogee
    STOCK
