Front wheel bearing are they hard to replace?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1999tacotrd, Jun 17, 2009.
  1. Jun 17, 2009 at 11:24 AM
    1999tacotrd
    1999tacotrd [OP] 1999 Taco TRD xtracab 3.4 V6 4x4
    Hi after further inspection of the rattling of the brake dust cover i noticed the wheel bearings is on there way out cause it spins ruff instead of smoothly so my ? is are they hard to replace? i know i have did many cars in the past but never did a truck that had lock out hubs.
    Also is there any free guides on how to do it?
  2. Jun 17, 2009 at 11:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes there is a "free" guide. Gimme a minute or two..........
  3. Jun 17, 2009 at 11:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    The section you want is towards the bottom.
    moto.mike likes this.
  4. Jun 17, 2009 at 12:51 PM
    JVTACOMA
    JVTACOMA Well-Known Member
    York, Pa
    I did mine...well, as far as i could, what I mean is, i pulled both front spindles off and took them to NAPA. The bearings are pressed in and very hard to get out even with a press. I got all the parts from Toyota and NAPA did all the press work. They turned it around in about 3 hours.
  5. Jun 17, 2009 at 1:14 PM
    1999tacotrd
    Did u have to remove the lock in hubs when u did it? or can they be replaced w/o removing the hubs
  6. Jun 17, 2009 at 7:27 PM
    1999tacotrd
    Well sure enough that's that the rattling sound was :) i use a angle grinder and cut that dam dust cover off and now no more rattling. I think i might just try to buy a whole another wheel assembly instead of trying to get new bearings
  7. Jun 18, 2009 at 1:39 PM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    Good luck Spindles are not cheap and I needed one, took me a few months to find a used one. do you have manual hubs or Autos?
  8. Jun 18, 2009 at 1:45 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....new hub assy's/spindles at the dealership are $167 a piece. i checked when i bought my wheel bearings the other day. still havent changed my bearings, but im gonna later down the road. they are guaranteed to be a pain in the ass.
  9. Jun 18, 2009 at 1:52 PM
    PrezidentRedz
    Redz
    Owings, MD
    just take the spindle out and go down to a local napa.
  10. Jun 18, 2009 at 1:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well, thing is, i think my passenger side spindle may be a bit warped, so i think im gonna wait and just get new spindles later on and do it all at the same time.
  11. Jun 18, 2009 at 1:59 PM
    PrezidentRedz
    Redz
    Owings, MD
    how did you warp it? I got hit by a Car,!
  12. Jun 18, 2009 at 2:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly....i think that the people who owned it before me, seeing as how bad of shape it was in, never balanced their tires, and that constant vibration and outta round movement may have warped it a little. i installed my new cv's, and alotta the shake went away, but i still have some around 60-70mph, and i have had my tires balanced a few times to rule that out. hell, who knows, it may be that the tires arent balanced all that great, so we'll see i reckon.
  13. Jun 18, 2009 at 3:44 PM
    1999tacotrd
    Mine are lock outs and do the 4x4 4cly and 6cly 4x4s use the same lockout hubs?
    im thinking i might take my spindle off and pay a shop to replace the bearings for me but if it cost more then 167 to do it i will just buy a new one.
    i know in the past on my 95 eagle talon the bearings went out and the bearings coasted $39 for the kit and i got a whole other spindle at the salvage yard for $45 so i went that rout
  14. Jun 22, 2009 at 10:10 PM
    JVTACOMA
    York, Pa
    99 4X4 I4 and V6 used the same wheel hub assem. the bearing are one sealed unit/side. pressed in and need pressed out. take a look at this, it may help you understand a little better.
    that price listed above is just for the Spin.. not hub, bearings or seals. the bearings for our trucks are $, a little more expensive then the talon ones you did...
    csrf likes this.
  15. Apr 6, 2015 at 9:42 PM
    thereverend
    thereverend rev
    Adam
    B'ham AL
    '14 DCSB TRD Sport 6spd SC
    TRD SC, URD 1 size smaller SC drive pulley, Volant CAI w scoop, TacoTunes full kit, MagnaFlow muffler for flow but ran out rear to kill the drone.
    At what point / miles are find a need to replace the unit bearing / hub assembly?
  16. Apr 6, 2015 at 10:35 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Nice dig.
    Usually they are only replaced if needed. There isn't a maintenance schedule for them.
    If they grind or sound unhealthy.....replace.
  17. Apr 7, 2015 at 4:48 AM
    043RZ
    043RZ Well-Known Member
    Spring Grove, PA
    2004 Tacoma SR5
    6" Fabtech Lift, OME Dakar leaf springs, BudBuilt Traction Bar, 15" American Racing Wheels, 5.29 Nitro Gears, 35" BFGs AT, Pioneer 200 Watt Stereo, 6x8 Pioneer speakers, Raised Front and Rear Diff Breathers, Deck Plate Mod, Red Interior Underglow, Red Exterior Underglow, Cool White LED Rock Lights,
    x2 on having a shop with a press replacing them. When i had my passenger side bearing replaced the shop doing the work said it took everything there press had to push them out and said it was close to 40tons to pop it loose. When it finally popped, it sounded like a .12 gauge going off. In some ways i wish toyota would have made the front bearing assembly servicable like the older 90-94 pickups.
    Luv my yota and cruxofthebisquit like this.
  18. Apr 7, 2015 at 2:54 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Hmm.. well we just got a 20 ton press. Hoping that'll do the trick. Will be doing this before too long on mine. Is there any special mounts/tools needed for the press like to position the hub correctly? Or just stick it in there and press away?
  19. Apr 7, 2015 at 5:26 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    We did this with a 20 ton press and it also took a lot of heat - like cherry red - to get it to pop loose. Most guys say you need a 50 ton press to make this job go smoothly.
    cruxofthebisquit likes this.
  20. Apr 7, 2015 at 7:00 PM
    NightProwler
    Harlan
    Maricopa, Az
    Crap.. well maybe I'll try my luck, then go to Napa if all else fails. I don't think we have the capability to heat it up that hot, ha. Jeesh.
