Front Tires Squeal Like I'm In A Chase Scene From Chips!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mobtown Offroad, Oct 3, 2014.
  1. Oct 3, 2014 at 2:10 PM
    Mobtown Offroad
    Mobtown Offroad [OP] Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    The All,
    I have a 2014 RC 4x4 Tacoma. Truck is bone stock, never left the blacktop (yet), has the oem 245/75-16 Dunlop Grandtrek AT20's, psi is always right at 30. I check with almost every fill up. My front tires squeal like they're low on pressure or I'm in a parking garage every time im turning from a stop. Doesn't matter what the weather is or where I'm at. I have two friends, one with an identical truck to mine minus the transmission and color, other has a double cab, 4 cyl Prerunner. Both have identical tires that I have and both keep them at 30 psi and they both tell me theirs don't squeal, ever. I now have 3300 miles on the truck, they've been doing it since I left the dealership with it new in July.
    What gives! Someone give me some insight as to what's going on or at least let me know I'm not alone and it's just that Toyota got cheap and threw crap tires on these trucks (which from what I learn is pretty truthful).
    Thanks in advance!
  2. Oct 3, 2014 at 2:21 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    are you Jon or Ponch ?
  3. Oct 3, 2014 at 2:55 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    Love the Dane Cook reference.
    What do they pave it with...it's not concrete.
  4. Oct 3, 2014 at 2:59 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Rotate the tires..... Do you get the same thing?
    When do they squeel? On turns?
    Rotate tires with your buddies...... and see what happens.
  5. Oct 3, 2014 at 3:11 PM
    53wick
    53wick Well-Known Member
    kentucky
    2014 accesscab prerunner
    I run 36 psi in mine, 2014 prerunner v-6 with no problems. you might have frontend alignment checked
  6. Oct 3, 2014 at 3:12 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    LOL!! CHIPS FTMFW!!!!!
  7. Oct 3, 2014 at 4:31 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    They squeal when turning from a stop. Doesn't matter if I pull away slowly or quick. I've rotated mine and they still squeal, both my friends have had rotations already and they didn't have squealing before or after.
  8. Oct 3, 2014 at 4:32 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Slightly more psi makes sense to me with yours considering you have a heavier motor. I will try a higher psi, I haven't done it yet because I didn't want to have uneven tire wear. I was going to ask dealer to check alignment when it goes in for its 5000 mile service.
  9. Oct 3, 2014 at 4:33 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    If this is true I'll be somewhat annoyed considering it left the factory out of alignment.
  10. Oct 3, 2014 at 4:33 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Jon!
  11. Oct 3, 2014 at 4:34 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Mine squeals. Nothing to do with alignment that my tire rubs the road surface and makes noise occasionally.
  12. Oct 3, 2014 at 4:39 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    They could possibly have some coating on them still if the tires are very new. I would swap wheels and tires with your buddy and see if it happens still to your truck or if the tires are the culprit. I doubt your alignment is off far enough for the tires to be squeeling like that. At speed the truck would be undriveable if it was alignment.
    Does it squeel on all pavement types...if so then that's weird BC squeel should change drastically for different pavement types like fresh asphalt or old pitted asphalt. And usually a fresher asphalt will let the tires squeel at lower speed.
    Are the tires stock? Maybe they are rubbing against something?
  13. Oct 3, 2014 at 4:53 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Only squeals on blacktop, old or paved fresher. I haven't really driven it on a concrete road. I can't imagine the alignment is that off. Truck tracks straight as an arrow. Oem stock tires, only 3400 miles on the truck.
  14. Oct 3, 2014 at 5:25 PM
    adamh1977
    adamh1977 Well-Known Member
    arkansas
    trd sport 4x4
    any time fog,tinted windows to 5% ,plasti dipped gun metal gray,toytec 5100's eibach coils ,led map and dome lights
    i was thinking the same thing hahahahahahahahahaha
    :D
  15. Oct 3, 2014 at 5:37 PM
    ancient11
    ancient11 Well-Known Member
    robert
    tallahassee
    2019 4 cyl srsx ac
    Mine squeal too....only when turning sharply at low speed. 10,000 miles and otherwise run smooth and quiet
  16. Oct 4, 2014 at 7:21 AM
    Pigpen
    Northwest Montana
    That's the sound of your truck telling you it wants some more stylish (higher quality) shoes. It's tired of being made fun of by the other Tacos in the parking lot.
  17. Oct 4, 2014 at 7:33 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Patience grasshoppa. Once they're worn it'll be getting 235/85-16 Duratracs. But I cant justify replacing tires that work perfect (another than being annoyingly squeaky).
  18. Oct 4, 2014 at 8:06 AM
    tucktuck
    tucktuck Active Member
    Thomas
    Indy
    My '96 4Runner (326K miles) has done that since day one while turning at low speeds ... never had any issues with tires. I've gotten 150K miles out of two sets of Michelin LTX ATs - still with decent tread remaining. Mostly highway miles.
    When turning into a parking space heads often turn because it screeches so loud...
  19. Oct 4, 2014 at 8:26 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  20. Oct 4, 2014 at 8:30 AM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I forgot how great those Harley's looked. My great uncle actually bought one and fully restored it to look just like theirs. Good stuff.
