Front suspension, stock vs Rough Country
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tluke81, Sep 16, 2021.
  1. Sep 16, 2021 at 1:39 PM
    tluke81
    tluke81 [OP] Active Member
    Looking to lift my truck 3 inches. In the back, I'm doing Rough Country N3 shocks with a block, but I'm stumped on what to do in the front. RC offers a 3in strut spacer in a kit for the stock Bilstein 4600, and they offer a lifted N3 strut. There is a $300 price difference and I'm not sure if it's worth it. I've heard RC drives stiff (I daily drive + road trip with occasional offroading) so I was considering just doing the strut spacer kit, let me know what you all think.
  2. Sep 16, 2021 at 2:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    Forget RC and start over.
    If alternatives are out of budget right now, wait and save until they are in budget.
    And just for giggles, Tacomas dont have struts. Regardless of what people and catalogs call them.
  3. Sep 16, 2021 at 2:44 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    All that money into a truck with nice suspension and your going to install the cheapest crap available and ruin the truck with spacers and blocks?
  4. Sep 16, 2021 at 3:00 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    A 3” top-of-coil spacer seems like a bad idea. Firstly, when your coil over is fully extended, your wheel will be 3” lower than it’s supposed to be, except it probably won’t be because your ball joint will bind or your uca will contact your coil before that. Secondly, when your suspension bottoms out, the shock will take the hit before the bump stop. Not good IMHO. Plus it requires about the same amount I would guess (ive never installed a spacer).
    If you drive your truck like it’s a princess you might never have a problem. I don’t, so I went with a full coil over upgrade.
  5. Sep 16, 2021 at 3:09 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Also the stock bilsteins are Not 4600's, they're smaller.
  6. Sep 16, 2021 at 8:43 PM
    tluke81
    I'm not going to do the spacer I decided, but would the 3 inch RC lifted struts + shocks in the back actually be a bad idea? I knew they used to be bad, but I've read a lot saying that their quality has really improved and they aren't a bad option anymore.
  7. Sep 16, 2021 at 8:48 PM
    tluke81
    I've read that RC used to be bad, but they have greatly improved. I was really leaning towards the RC lifted shock/strut or whatever it is with the 3-inch block/shocks in the back. What would be some issues id run into? I know it is not the best, but it would still perform better than stock suspension with 65k miles on it, right? To save money I might wait till I can install it myself in a few months rather than go to a shop now. If I did that, what would you recommend for a 3 inch lift?
  8. Sep 16, 2021 at 8:55 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    One of the guys up there are correct. It’s not a strut. We have upper control arms so technically it’s just a coil over.
    The issue is RC just isn’t better than the OEM.
    If the coil overs you are referring to are anything like I’ve seen, you are basically down grading from OEM, and spending my money to do so. In my opinion anyways.
    Consider something like 5100s if you want 3 inches or seriously try waiting and save up the funds for something mo bedda.
    gman2431 likes this.
  9. Sep 16, 2021 at 8:58 PM
    tluke81
    My original plan was to do 5100s in the front with the stock springs, then 5100's + icon add a leaf in the back. I think that would only give me like 2 inches max though. I can afford something better the issue is I don't want to spend $2k on new suspension haha
  10. Sep 16, 2021 at 8:59 PM
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    Stick with stock unless you're going to spend money. Why cheap out when the truck wasn't cheap to begin with?
    It's just fine out of the box for the majority of buyers
  11. Sep 16, 2021 at 9:15 PM
    Myles G
    Myles G Well-Known Member
    Myles
    Rough country isn’t as bad as people make them out to be. Just don’t use their coil overs or shocks and you’ll be fine.
    RangerComa likes this.
  12. Sep 16, 2021 at 9:42 PM
    BRFab
    BC
    Their molle panels look great for the price. Suspension, not so much
    Pongo likes this.
  13. Sep 17, 2021 at 5:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    You haven't stated the model/configuration of your truck or how you use it.
    At least tell us if its 2wd or 4wd.
  14. Sep 17, 2021 at 5:40 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I was gonna do a rough country lift but I decided to wait, increase my budget, and get a set of fox 2.0s. It doesn't lift as high but it feels much better on and off-road. I do have a small spacer in the rear but its unnoticeable.
  15. Sep 17, 2021 at 7:35 AM
    JayRolla
    Colorado Springs
    They have not improved. They are cheap for a reason.
  16. Sep 17, 2021 at 8:08 AM
    gudujarlson
    Minnesota
    These trucks come with about 3" of down travel from the factory. Using coil overs, for each 1" of lift you loose 1" of down travel. Having zero down travel seems like a bad idea. Shoot for 2" of lift,
  17. Sep 17, 2021 at 8:15 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Bilsteins and an AAL arent even close to $2k. If you can afford $2k then you can surely afford spending half on a better option.
    $1000 - Entry Lifts and Suspensions
    $2500 - Premium options for OEM replacements
    $5000 - Performance suspension which may require fabrication
    SpeySquatch likes this.
  18. Sep 17, 2021 at 9:19 AM
    tluke81
    No yeah I mean I want at least 3 inches and the Bilstein 5100 wouldn't get me there. Seems like all better options are around $2k after that.
  19. Sep 17, 2021 at 9:21 AM
    tluke81
    2018 Tacoma TRD Offroad V6 4x4, I daily drive it, take it on 10-hour drives multiple times a year and I occasionally go off-road.
  20. Sep 17, 2021 at 9:22 AM
    tluke81
    Okay, ill check it out, thanks.
