Front Suspension Lube
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Satchmo!, Jun 26, 2023.
  1. Jun 26, 2023 at 11:02 PM
    Satchmo!
    Satchmo! [OP] Well-Known Member
    2019 Tacoma TRD Off-Road
    Hello,
    Was reading some posts on here about lube on aftermarket UCA/LCA/Ball joints/etc. With a stock suspension system that makes noise, will it hurt to use silicone lube on the moveable points, even the leaf springs? I know they are sealed components, just curious if spraying them with some silicone lube would be beneficial or be harmful.
  2. Jun 27, 2023 at 6:47 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Are they making noise?
    I don’t know, but just be careful and not use something like WD40 and actually degrease things. It sounds obvious, but many still seem to do it.
  3. Jun 27, 2023 at 7:06 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I WoolWax the truck once a year, so *almost* everything gets coated. I also spray between the leaf springs.
    I can report that I haven't had any squeaks since I started that routine. Shortly after I had purchased the truck,
    the leaf springs started squeaking, but that went away after the first coat of WoolWax.
    Just my two cents.
  4. Jun 27, 2023 at 7:23 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I wouldn't spray liquid silicone lube inside the ball joint boots. You can get a needle tip for a grease gun and pump a little grease in there if you want. As for the cam bolts and UCA bolt, I covered them in anti-seize and not a single squeak can be found. As for the leafs, I put a powder lubricant on the anti-friction pads of the leaf pack about twice a year and no issues there either. I didn't want to put anything wet on them as I feel it would attract dust and cause creaking.
  5. Jun 27, 2023 at 4:30 PM
    Satchmo!
    No WD40, I haven't messed with anything on it. Was just curious thats all.
    I've undercoated the truck a couple times with the mil-spec wax spray for corrosion protection (forget the name of it). That shouldn't cause any problems. Have to look into woolwax.
    Thats not a bad idea, ill have to do some research on the grease/anti-seize/powder lube. Ya, last thing I want to do is add something that attracts dust/debris and make it worse.
    Thanks for the advise guys.
