Front suspension bolt help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Theegood, Mar 16, 2017.
  1. Mar 16, 2017 at 10:18 PM
    Theegood
    Theegood [OP] Member
    Stock
    2013 Tacoma DCSB 4X4. Front lower shock bolt stripped thread. No good. went to dealer got part# 90105-A0113. Cool.... Not cool. Bolt is smaller that original. How's that possible? Anyone know if the part number is wrong cause I searched forums and looked online Toyota parts and they say same part # for 2013 tacoma. If I do go to a hardware store what do I ask for to be a good enough bolt.. hearing a certain strength or something.
  2. Mar 16, 2017 at 10:24 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    I think it's a grade 8- 9/16 fine thread bolt. mic the old one and measure the length
    REDdawn6 likes this.
  3. Mar 16, 2017 at 10:38 PM
    270wsm
    270wsm Well-Known Member
    AZ
    Grade8 ^^
  4. Mar 16, 2017 at 10:43 PM
    Theegood
    Stock
    Thank you guys thats what I saw some where on the forums didn't know if I could just use a random similar bolt from a hardware store.. knew it had to have some specifics.
  5. Mar 16, 2017 at 10:57 PM
    jhaykane
    jhaykane Local 8251
    JB
    Hawaii
    2006 Tacoma 4WD
    Non Stock
    Those are for the base model. I believe this is the bolt you're looking for, 9010514104.
  6. Mar 17, 2017 at 5:17 AM
    sjwhitaker
    sjwhitaker Today Was A Good Day.
    Jake
    Berea, KY
    2010 DCSB TRD Offroad 6MT - Icon Stage 2 - 285/75/16 Falken AT3W
    I would just go to your local hardware store. Grade 8 would be overkill for way less money than the dealer. I'm pretty sure the stock bolt is nowhere near grade 8. If you live in a salty environment consider applying some anti seize to prevent this from happening in the future.
  7. Mar 17, 2017 at 5:35 AM
    SeanBonham
    SeanBonham Well-Known Member
    Sean
    Derby City
    2012 DCSB SR5 4x4 6mt with some thangs
    If you have a fastenal by you, that is the place to go.
    sjwhitaker likes this.
  8. Mar 17, 2017 at 5:39 AM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    You just need a stronger impact to zip it on there!
  9. Mar 17, 2017 at 6:18 AM
    Theegood
    Stock
    Did you choose prerunner as an option? When I look there is base and prerunner and xrunner I think. I thought prerunner was 2wd but it makes sense cause in the manual it always seperates 2wd and prerunner/4wd. Shows you guys I'm fairly new to tacomas yet alone working on vehicles.
  10. Mar 17, 2017 at 6:26 AM
    Theegood
    Stock
    If that's true about grade 8 and it being better than stock then I have a Fastenal pretty darn close to me and than I can hold off dealing with a dealer.
    sjwhitaker[QUOTED] likes this.
  11. Mar 17, 2017 at 6:41 AM
    sjwhitaker
    Jake
    Berea, KY
    Just go to Fastenal. They will either have or will be able to get the EXACT specification bolt usually the next day. I'd be willing to bet they have it in stock though. Take it with you if you can.
  12. Mar 17, 2017 at 6:48 AM
    Theegood
    Stock
    That's the plan for me. I wanted to stick with what Toyota put in there but I appreciate the help cause I've seen a few posts mentioning just going to a hardware store and making sure to get a specific grade just couldn't find those specific posts and if it applied to me.
