Front Shock Installation How-To
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XC4ME, May 7, 2017.
  1. May 7, 2017 at 6:13 PM
    XC4ME
    XC4ME [OP] Well-Known Member
    Litchfield Park, Arizona
    05 Tacoma DC TRD Sport
    I searched, I really did. I thought there was a "How-To" on replacing the front shocks on a 2nd Gen. I even thought Chris had a video of it. I can't find it. Can anyone point me in the right direction? Thanks
  2. May 7, 2017 at 6:14 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  3. May 8, 2017 at 12:30 PM
    XC4ME
    Thank you!
  4. May 8, 2017 at 12:53 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    Follow the links in post above, and if your truck is not 4x4, you don't even have to remove the spindle. Just unbolt the sway bar on both sides and rotate it out of the way to maneuver the coil assembly out of the way thru the bottom. You can use a long handle from your floor jack to pry on the lower control arm a little bit. Just watch the brake and ABS lines.
  5. May 8, 2017 at 12:57 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    t1m829, lagbc and BOZOJUICE like this.
  6. May 8, 2017 at 1:17 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Any recommendation on replacing the Top Hats? I've seen videos where the through hole in the Top Hat gets rounded out by the shock's rod during its continuous compression and rebound cycles - which may be especially noticeable after 75K miles.
    (if replacing the top hats is recommended, may as well buy all new hardware too to avoid having to decompress the stock spring)
  7. May 8, 2017 at 1:21 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you're ordering new shocks and coils and are planning on replacing the top hats, then you may as well get them pre-installed before ordering to save yourself some effort.
  8. May 8, 2017 at 4:09 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Its literally 2 mintues extra per side to install and assemble the strut assembly yourself. saves you 80-120 bucks.
  9. May 8, 2017 at 4:13 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah but he's wanting new top hats too which would be ~$50. It's an extra $90 through headstrong for assembly, so only $40 for them to actually assemble the coils. Sometimes it's worth spending a few bucks for convenience.
    RJ_MacReady likes this.
