Front right axle seal part number and tools
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FloridaFree, Feb 14, 2023.
  1. Feb 14, 2023 at 5:34 PM
    FloridaFree
    FloridaFree [OP] Well-Known Member
    TRD OffRoad 4x4 mgm
    OME 887 with nitro chargers, icon add a leaf ECGS bearing former 886
  2. Feb 14, 2023 at 5:37 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    90311-47026. You got the right one.
    Not sure about tools or the exact process. @Texoma may know, although he normally doesn’t change those with the gear jobs he does.
    With my limited guessing, I would assume use a seal puller to get it out and then a large socket or seal driver to hammer it in straight and then stop at the same spot that the old one was at. Take a few pics of the old one for reference.
    FloridaFree[OP] likes this.
  3. Feb 14, 2023 at 5:48 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    Thanks.
    Yeah I was thinking of using the PVC pipe to hit it in
    Good idea on taking the pics for ref on the depth. there is supposed to be a lip but I will take the pics anyway.
  4. Feb 14, 2023 at 5:55 PM
    BLtheP
    Plano, TX
    I actually have one of those because I just bought it for my regear but didn’t need it. I don’t think it had a lip but I can confirm. The left side is for sure installed to a specific depth.
    I’m not exactly sure on removing the CV, on past vehicles I used a pry bar. On the Tacoma specifically, remove the two lower steering knuckle bolts so that you can swing the brakes/steering knuckle away from the diff which lets you get the diff end of the CV out and moved out of the way without having to disassemble the stub shaft from the unit bearing or tear down the brakes or anything like that.
  5. Feb 14, 2023 at 6:00 PM
    BLtheP
    Plano, TX
    No lip on mine. I never did confirm it was the right seal in the diff but it was the only option I ever found on the parts diagrams. Pretty sure it’s right.
  6. Feb 14, 2023 at 6:06 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    https://www.youtube.com/watch?v=4tQwuenQAQY
    This is what you're describing. Thanks for the info.
    This is the lip I am talking about. Maybe this video isn't a tacoma.
    its at 4:22
    BLtheP[QUOTED] likes this.
  7. Feb 14, 2023 at 6:23 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    BTW: $4 National P/N 710595 interchanges with the OEM part: https://www.rockauto.com/en/moreinfo.php?pk=2480322&cc=3441741&pt=1860&jsn=11
    A screwdriver is enough to pry the old seal out. Make sure the seal seating surface in the diff housing is free of rust. Sand it smooth with sand paper if you see rust. Put some grease or diff oil on the seal to prevent tearing as you drive it in. It's difficult to get the seal to go in square. I used a seal driver, but instead of hammering on the handle, I hammered on the disc portion at different spots to get the seal to go in square.
    No need for slide hammer or bearing puller, unless you're replacing the ball bearing in the diff. The CV axle needs a pry bar to pop free from it's spring clip. Once popped free, turn the pry bar around and hammer along the notches on the CV joint cup.
  8. Feb 14, 2023 at 6:38 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    Bought the toyota one at 5x price. comments everywhere said it was necessary. not sure.
    I am going to pass by autozone so I will rent the puller and maybe a seal driver
  9. Feb 14, 2023 at 6:45 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^The Toyota seal leaked, so you buy the exact same part and expect a different outcome? :p
    Again, what is the puller for? Seal driver is very helpful.
  10. Feb 14, 2023 at 6:46 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    Maybe I went through some headlight deep mud.....
    The puller is free to "rent"
    Do you know if I need the toyota 75w-90 GL5 from toyota or mobile 1 works?
  11. Feb 14, 2023 at 6:51 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Then make sure the front diff breather isn't clogged. Might be the root cause of the leak. :laugh:
    Any major brand 75W90 will be fine. In my experience Pennzoil/Shell/Quaker State (same mfr) smells a bit less horrid than the other brands.
  12. Feb 14, 2023 at 6:58 PM
    BLtheP
    Plano, TX
    Eh, not like they leak often. OEM seals are usually better quality than anything aftermarket. *usually, not always*
  13. Feb 14, 2023 at 6:58 PM
    BLtheP
    Plano, TX
    Whatever gear oil you want to use is fine as long as it’s GL5.
  14. Feb 14, 2023 at 7:07 PM
    FloridaFree
    TRD OffRoad 4x4 mgm
    I looked at it. doesn't appear muddy
    Should I just hit it with water?
    Can I just pull the top off?
  15. Feb 14, 2023 at 7:19 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Remove the breather from the hose and make sure air can flow out of it.
  16. Feb 15, 2023 at 3:36 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Exact seal depth is super important.
