Front Red Coated Brake Caliper ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by george3, Aug 27, 2019.
  1. Aug 27, 2019 at 3:19 PM
    george3
    george3 [OP] Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Wondering how powder coated calipers hold up - are they worth the extra $$ or does the powder coat come off and the calipers rust up just like the ones that aren't power coated. Thanks for any reply from you guys with experience.
  2. Aug 27, 2019 at 4:11 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I think anything up north where the roads get salted eventually you’ll have some issues but imo it should at least delay that effect if taken care of. Here in Texas don’t have that issue powder works great.
  3. Aug 27, 2019 at 4:36 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    My son painted his own. It came out good and has lasted.
  4. Aug 27, 2019 at 5:38 PM
    mkrespke
    mkrespke Well-Known Member
    Phoenix, AZ
    07 4x4
    With high temp paint? Or did he powder coat too?
  5. Aug 27, 2019 at 5:39 PM
    TacomaSport86
    High temp paint I believe
  6. Aug 27, 2019 at 7:23 PM
    Rambo54
    Rambo54 TacomaBob
    Robert
    Eustis,FL
    2013 Nautical Blue Metalic Tacoma PreRunner DCLB
    Many !
    High Temp Caliper Paint !
  7. Aug 28, 2019 at 11:32 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Powder coating is usually more durable than paint, but it's more expensive. Powder coating also requires disassembling and rebuilding the calipers, while painting does not.
  8. Aug 28, 2019 at 12:09 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I painted mine maybe eight or so years ago; I want to say I used the Duplicolor caliper paint kit. The leftover paint is still in the garage with my other paints but I'm too lazy to go look right now. I didn't even dismount the caliper off the rotor, just sprayed it down with the caliper cleaner, scrubbed it well, sprayed it again then painted it. The stuff I used came in a can and you used a brush to paint it on. It goes on kind of thick but evens out.
    They're never going to look like Brenbos or other performance brakes but they still look good when I wash the wheels and get the brake dust off of them. I painted the rear drums at the same time with a spray type paint for brakes and it's held up well too, I think it was a Duplicolor product also.
    ETA- I checked and it was Duplicolor caliper paint (this one with the self leveling brush on paint: https://www.summitracing.com/parts/shw-bcp400) for the front and some black VHT caliper spray paint for the drums.
  9. Oct 19, 2019 at 5:56 AM
    2016Taco
    2016Taco Well-Known Member
    Greater Toronto Area
    2016 Blazing Blue TRD Sport Upgrade DCLB 4X4
  10. Oct 19, 2019 at 4:11 PM
    TacoTuesday1
    FL
    There are many options. Paint, powdercoat, and other coatings like G2 caliper paint which might be epoxy.
    A question worth asking though, if I may ask everyone:
    WHICH calipers, are worth investing any coating into, if at all?
    Even if it's just a cleaning in the sink with CLR or something, to remove brake dust.
    Audi calipers for example, I believe are Zinc-plated from the factory. Hidden under the brake dust over years.
    So whether it's cleaned up or re zinc coated, they look silvery.
    There's also a guy, Eric @ PMB performance, who does that process on Porsche calipers and probably more.
    back to the question of which calipers,
    ie whether to stick to stock and maybe put on cheap PowerStop brake parts, or StopTech Cryo Slotted w/ TRD pads,
    or to up the brake size to late model 4runner parts.
    2002 Audi A4 calipers with a 1.8T 4-cyl engine are 288mm front. 312mm front if it has the 3.0L V6.
    4.2L V8 in the S4 had 345mm.
    And later model year (05.5-08) A4 was 321mm, with the 2.0T or 3.2L V6 engines.
    which seems crazy for the 2nd gen Tacoma to be in the ballpark of stock, considering it's a big truck, possibly heavier, rides on a frame,
    bigger engine (4.0 V6)
    and bigger tires, especially if you've put 4runner tires or bigger, like previous owner did on mine (I forget the size, maybe 265 70 17 on 17"s)
    Zinc is also supposed to provide a smooth surface that protects against corrosion, especially in the cylinder where hydroscopic brake fluid can try to pull in water to rust otherwise bare metal underneath.
    That and grease on the piston seal (Dow Corning, Castrol Red Rubber grease, etc.) to provide a barrier that hydrates the seal, lubes it, and keeps out water.
    Though I don't know how it works with tolerances, regarding the size/dimensions of the piston, the bore, small thickness of the zinc plating, and how it all fits together so it's tight enough to function, but not so tight that it binds/seizes. I guess the seal helps with that.
    I read a Volvo guy mention a trick for brakes is to put some anti-sieze on the bleed screw threads if you ever have them out, to prevent future siezing and also help make a little barrier that keeps brake fluid inside when bleeding brakes, so it doesn't leak out the threads.
    Sometimes DOT4 does seep past the threads for me, and I've noticed ~$7 caliper paint may not hold up the best to that, even if I quickly react with a water rinse to get off the brake fluid.
    So then you get a line of discoloration down the paint. But if the bleed screw is on the inside of the caliper then it's hidden behind and not noticeable.
    Maybe epoxies and power coats hold up better to that, if it matters.
  11. Oct 19, 2019 at 5:11 PM
    Muddinfun
    Muddinfun Well-Known Member
    Plastic covers. LOL
    2016Taco likes this.
