Front passenger power window stopped working? Kind of?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dozer.bw, May 8, 2018.
  1. May 8, 2018 at 11:52 AM
    Dozer.bw
    Dozer.bw [OP] Member
    2012 Toyota Tacoma
    so I go out to my truck the other day and went to roll down the passenger window from the driver side and .... nothing! So I leaned over to the passenger door and hit the button and .... down it goes? So we start down the road and I had the passenger roll it it up and it went 1/2 way up and stopped then jiggled the button and it didn’t work so played with the button a little more and it goes up? So the driver button doesn’t work at all but the passenger button doesn’t want to work but if I messed with it it could? Does anyone know what this could be? I checked fuses and the day before the switches were fine? And I don’t think it’s the motor because we got it to move? And no it’s definitely not the child lock lol , thank you
  2. May 8, 2018 at 11:53 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Loose wire in passenger door maybe.
    Dozer.bw[OP] likes this.
  3. May 8, 2018 at 12:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Try banging on the door to shake the brushes around in the motor
  4. May 8, 2018 at 12:31 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Pull the door panel off and check for power and ground at the window motor connector, if power and ground are present then suspect a bad motor.
  5. May 8, 2018 at 12:36 PM
    Clearwater Bill
    Billy
    Largo Florida
    Sometimes this behavior is from a dirty/worn switch.
    But both sides behaving the same says that's unlikely.
    It can't be a fuse. They are either good or bad, not intermittent.
    So as @Bebop suggests, if the voltage checks out and the connection is secure, it's likely the motor is on it's way out.
    Dozer.bw[OP] and Bebop like this.
  6. May 8, 2018 at 12:53 PM
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    I'd squirt some silicone lube down the window track. May find a decent U-tube?
  7. May 8, 2018 at 3:51 PM
    Dozer.bw
    2012 Toyota Tacoma
    Thank you for all the replies , I will update after checking everything
  8. May 15, 2018 at 8:37 AM
    Dozer.bw
    2012 Toyota Tacoma
    Ok so I took the panel off and jumped the wire for the passenger window and it rolls up and down just fine? It’s strange that the passenger door switch stopped working as well as the switch for the passenger window on the driver side though?
  9. May 15, 2018 at 10:12 AM
    Muddinfun
    Muddinfun Well-Known Member
    The switches are sort of wired in series. You need both switches for the window to move. It's kinda like the Christmas lights that if 1 bulb is bad, the whole string goes out.
  10. May 15, 2018 at 11:19 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    IMO this is a temporary band aid. It should work fine without this and it wont last forever. Eventually, whatever is worn or broken will get worse and hopefully its not during a rain storm. One exception, i added a little silicone in there when i installed my in channel visors until they broke in.
    My one maintenance item is i use aerospace 303 to clean and protect the channels. Cleans out dirt and keeps new debris from sticking pretty well.
  11. May 16, 2018 at 11:18 AM
    Dozer.bw
    2012 Toyota Tacoma
    Just bad switches , I looked at the driver door switches and it is a cluster module and then of course the passenger door is just the one and with them wired in series I suppose it has to go through the passenger door and back to the driver side so my final hypothesis is the passenger door switch needs replaced lol , thank you everyone for your responses!
    supralee and Muddinfun like this.
  12. May 16, 2018 at 11:23 AM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Had/have the same issue, don't think it is a switch, in my case at least, only because the window was replaced after some asshat broke into the rig.
    think mine might be a piece of glass or something in the roller track......will take it apart one day....
  13. Oct 9, 2019 at 10:04 PM
    Rallyman
    Rallyman New Member
    Scott
    Laconia, NH
    I race the Truck
    Lots of lights, stickers, rally computer, harness
    Suddenly, the passenger window would not work from either door switch on my 2016. I checked the fuses and power to the switches and regulator. All good. By grounding the yellow wire in the passenger door switch the window would go down, and grounding the blue, the window would go up. Regulator/motor is ok. So it seemed like the switch. I carefully opened the switch and bent the contactor arms to insure they were touching the power bars. I put the switch back together and it works fine now.
  14. Feb 19, 2021 at 10:48 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Hey Scott, could you tell me which fuses are for the RH window? Any fuses in the interior box, or just under the hood.??
    My 2016 just went this way, after 5 years.
    Thanx man.
  15. Feb 19, 2021 at 5:56 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    20A Door F/R - Front Right
    30A Power - Rear Right and P/W master Switch
  16. Feb 20, 2021 at 2:14 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    You forgot a couple, there are two fusible links and the relay that could fail as well making it look like a failed power supply.
    over60 and TnShooter[QUOTED] like this.
  17. Feb 21, 2021 at 10:38 AM
    over60
    Muskoka, Ontario
    Thanx a lot. Now to find a mild day so I can go check it out.
  18. Oct 21, 2021 at 7:20 AM
    Old&fat
    Old&fat Well-Known Member
    21 TRD offroad
    I have a similar problem. Last night I installed an OEM automatic tailgate lock. The lock works fine, but now I'm having front passenger side window problems. From the driver side controls, the window doesn't work. But from the passenger side controls it works just fine. Everything else in the door works, too; mirrors, speakers and locks. The fuses check out, any ideas? Fwiw, the toyota app keeps telling me the window is down when it's not. Thanks!
    Edit, I just realized this is in the 2nd gen forums. I'll leave it in case someone onow the answer here.
  19. Oct 21, 2021 at 12:48 PM
    Old&fat
    21 TRD offroad
    Thanks to 5nahalf for solving my problem. Thread here, https://www.tacomaworld.com/threads/front-passenger-window-problem.741629/
    supralee and TnShooter like this.
  20. Jan 24, 2024 at 7:55 AM
    stonyinvt
    stonyinvt New Member
    2012 Black Tacoma 4 Door
    I'm having this issue as well with my passenger door window. 2012 taco. checked motor, all good. pulled out my motor and connected it to my friend's taco and it works. so, not the motor. fuses seem fine. could it be a wiring issue and, if so, where do I look? are there wires that run through the dash? if so, how do i access them? im def a wiring newbie here, with not much experience, so any help is super appreciated. thanks!
