Front lower control arms replaced-now clunking
Discussion in 'Suspension' started by SoraTaco, Feb 22, 2019.
  1. Feb 22, 2019 at 2:05 PM
    SoraTaco
    SoraTaco [OP] Jersey Country Girl
    Arin
    Arkansas
    09 TRD 4x4
    I had both front lower control arms replaced with an immediate alignment done. Once all the work was done, this clunking noise started. It mainly happens when you initially change your direction (forward and backward) with a hard turn of the wheel to either side. It's getting progressively worse. Three mechanics have looked at it and cannot find anything noticeably wrong and suspect faulty parts. The only other thing they noticed was too much play in the cv axel, which I'm also going to replace but said it wouldn't cause the clunking noise. Anyone have any ideas before I buy more replacement parts? They are Duralast from Autozone (laugh... I brain dumped Rockauto and went with the quickest shipping company to an APO, overseas location... not my smartest move).
    You can view a video I was able to get while backing up:
    https://youtu.be/X-On7ddzIuI
  2. Feb 22, 2019 at 2:08 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Torque alignment cam Nuts / Bolts to 130ft#'s and report back
  3. Feb 22, 2019 at 2:10 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Maybe try making a video while you are not crunching over rocks or whatever else in was crunching over. As all I could here was crunching of rocks
    whatstcp likes this.
  4. Feb 22, 2019 at 2:12 PM
    SoraTaco
    Arin
    Arkansas
    09 TRD 4x4
    You can hear it at :12... anything before that was rocks. It only clunked once at that time stamp
  5. Feb 22, 2019 at 2:13 PM
    SoraTaco
    Arin
    Arkansas
    09 TRD 4x4
    On it, hopefully get that done this week and see what it does. Thank you
  6. Feb 25, 2019 at 11:04 AM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Did the bump stops get put back in the new lower control arms or when the control arms were installed did they torque them down when they had the full weight of the truck on them?
    TacoCasa likes this.
  7. Feb 25, 2019 at 11:07 AM
    tcjacado
    tcjacado Well-Known Member
    Do the outer tie rods have play in them. Or the inner tie rods
  8. Mar 2, 2019 at 4:50 AM
    SoraTaco
    Arin
    Arkansas
    09 TRD 4x4
    I'll ask the mechanic that installed them today or tomorrow.... I wasn't at the garage when the work was done :(
    tie rods are all solid... no play. The only part that had any play was the left axel shaft
  9. Mar 2, 2019 at 5:27 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Don't mention the axle shaft to anyone, that play is normal, it will only confuse the situation.
  10. Mar 2, 2019 at 11:17 PM
    SoraTaco
    Arin
    Arkansas
    09 TRD 4x4
    How much play is too much? It's relatively more than the right side. I'll try and get a video of that once I have it on the lift today to torque the nuts and bolts just to make sure I don't end up wasting more money. Thanks everyone!
  11. Mar 2, 2019 at 11:59 PM
    Grumpy
    Grumpy My 1st Tacoma
    Maurice
    Oahu, Hawaii
    14/DCLB/V6/4x4/SR5
    17" Method Grid Titanium rims w/ Pro Comp Sport A/T 265/70/17 tires, Mobtown Offroad ribbed Tailgate skin, installed LED lights in painted rear bumper black, faux TRD grill, color match grill surround. LEDs in map, license plate, center console, and dome lights. Anytime driving lite mod, debadged, vent visors, AA Maglite mounted under center console armrest. Antitheft hose clamp on tailgate, LED bed lighting kit. LED spot lights in lower front bumper. Weathertech floor mats. Painted various interior parts black, homemade 7 pin relocation bracket, Valet under door LEDS, CMC, SPC UCA, Bilstein 5100, OME 885, Headstrong AAL. Pop&Lock.
    Just a shot in the dark, you sure they torqued the CV shaft outer nut? I think it's supposed to be something like 150ftlbs. It's hidden under the dust cap.
  12. Mar 3, 2019 at 5:16 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    It's different for every truck. Basically if you replace the needle bearing with the ECGS bushing, the play will be minimalized. This is only for the driver side, passenger side doesn't have this issue.
    173ft#'s
  13. Mar 7, 2019 at 9:26 AM
    SoraTaco
    Arin
    Arkansas
    09 TRD 4x4
    Worked like a charm! They were about 15ft#'s off. I took a video of the play of the axel shaft. Compared both sides. I'll post that once I get it uploaded to youtube. Thanks for the info!!
  14. Mar 7, 2019 at 11:42 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Spread the word, it really is that easy.
    Masshole_And_His_Taco likes this.
  15. Mar 7, 2019 at 11:45 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    I get this too. Thought it was the UCAs. Just had an alignment. Thanks all for posting. Will torque.
  16. Aug 14, 2020 at 4:26 AM
    Yoboiiangel25
    Yoboiiangel25 New Member
    Angel
    2015 red Tacoma trd sport
    So what did you torque those alignment cam bolts too because my truck is doing the same thing after immediately getting an alignment after replacing lower control arms
  17. Aug 14, 2020 at 7:10 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Torque them to 130ft#'s
  18. Aug 14, 2020 at 7:16 AM
    Masshole_And_His_Taco RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    One more time for the guys in the back hahaha, Nicely done with the quick and accurate information man!
    Texoma[QUOTED] likes this.
  19. Aug 14, 2020 at 11:57 AM
    Yoboiiangel25
    Angel
    Thank you !
  20. Aug 30, 2020 at 8:24 PM
    CJSwan07
    CJSwan07 Well-Known Member
    Curtis
    Highlands Ranch, CO
    2007 Double Cab TRD Off-Road
    Toytec Boss 2.0 Fronts, Deaver J66, Total Chaos UCA's, Full JL Audio System. RCI skids, underbody plates, and bed rack. TRD Cold Air Intake Second Skin full triple layer insulation, Redline Tuning hood struts, Cali Raised LED ditch, fog, and rear OSRAM lights. Air ride (ride control) airbags with wireless adjustment mod, spyder led/projector headlights.
    Great news finding this post and reply. Headed to Lake Powell in 2 days and this just started on my front end. Just aligned it a month ago. I have the same play in my brand new CVJ half shafts with ECG supply bushing and My wife’s 4Runner has the same play in it as well, so I don’t think there is an issue there at all. I do have a different clunk that I can feel and hear, but I believe after inspecting it today, that my lower control arm bushings are shot again. I will report back if that fixes the other “clunking” that I have had for 4-6 months. Great diagnosis @Texoma!! Thanks.
    Texoma likes this.
