front left tire hard to turn by hand when off the ground
Discussion in '1st Gen. Tacomas (1995-2004)' started by Joe S, May 1, 2009.
  1. May 1, 2009 at 8:01 AM
    Joe S
    Joe S [OP] Member
    01 toyota tacoma SR5
    3 inch lift(coil spacers in front and larger shackels on leafs in rear) 32x11.5x16 mickeythompson baja belted, drilled performance front rotors and performance pads
    I jacked my truck up and turned the tires by hand and noticed that the right tire spun more freely the the left. The left tire was very hard to turn but did. The cv axle looked like it was turning with the tire and wasn't binding up. I lossened the lugs nuts about 1/2 turn each and the tire seemed to turn easier. whats going on?
  2. May 1, 2009 at 8:05 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    1st welcome
    now did you put new wheels on
    is it rubing on the b/caliper
  3. May 1, 2009 at 8:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! What He said ^^^^^^^^^^^^^^^
  4. May 1, 2009 at 8:43 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Welcome to TW :cheers:
    What he said he said.
  5. May 1, 2009 at 9:24 AM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW!
    What he said he said he said.................:goingcrazy:
  6. May 1, 2009 at 10:01 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Welcome to TW.....Wheel bearings going bad???? My guess I guess?
  7. May 1, 2009 at 10:17 AM
    David Tarantino
    N.J.
    08 tacoma
    could be :D ^^^^
  8. May 1, 2009 at 10:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was thinking maybe the pistons in the caliper arent fully retracting.......Given that it freed up a little as the lug nuts were removed.
  9. May 1, 2009 at 10:44 AM
    David Tarantino
    N.J.
    08 tacoma
    ^^^^^^ me too :D
  10. May 1, 2009 at 11:16 AM
    Joe S
    Joe S [OP] Member
    YES, i PUT NEW WHEELS ON BUT LAST YEAR.i PUT ON A SPACER SO IT WOULDN'T RUB AGAINST THE caliper. This is a new problem. i thought maybe the caliper or bearing is going
  11. May 1, 2009 at 11:22 AM
    98tacoma27
    Ben
    Not Beech Creek
    Definitely check your caliper then.
  12. May 1, 2009 at 11:25 AM
    Joe S
    Joe S [OP] Member
    I put new wheels and tires on over a year ago and used a spacer so the rim would not rub on the caliper. This is a new problem. I think the caliper or bearing. Is there even a bearing in there??
  13. May 1, 2009 at 11:26 AM
    Joe S
    Joe S [OP] Member
    How do you check the caliper to see if it is bad. Wouldn't my truck be pulling to one side if it was bad??
  14. May 1, 2009 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The way I check things like that is to use an infrared thermometer. Compare the drive side to the passenger side after a drive. If one brake rotor is hotter, you have a dragging piston/s. If the hub is hotter than the other, then you have bearing issues.
  15. May 1, 2009 at 11:32 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, it should, in theory, pull to one side. If you suspect the bearing, try this.
    Reinstall the tire. Place one hand on the top and one on the bottom. Then shake the shit out of it. If you have any movement then that is an indication it is bad.
  16. May 1, 2009 at 1:31 PM
    David Tarantino
    N.J.
    08 tacoma
    ok this is what iam thinking anyone jump in
    poss caliper starting to go bad maybe the slids
    poss b/hose he can open the bleeder if its the hose
    fluid will shoot out :D
  17. May 1, 2009 at 2:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would like to know if there is a temperature diff between the 2 sides first......
  18. May 1, 2009 at 3:06 PM
    David Tarantino
    N.J.
    08 tacoma
    true but he may not have that tool :D
  19. May 1, 2009 at 3:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :annoyed:
  20. May 1, 2009 at 3:09 PM
    David Tarantino
    N.J.
    08 tacoma
    joe just remove the caliper and see if the wheel is free :D
