Front jack point with OEM skids
Discussion in '3rd Gen. Tacomas (2016-2023)' started by friendlywithbears, Feb 22, 2016.
  1. Feb 22, 2016 at 4:42 PM
    friendlywithbears
    friendlywithbears [OP] a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    This may be a ridiculously stupid question, but first time owning and maintaining a truck. With the TRD OR factory skids on the front, what's the best jack point up there? Or is it best to remove the skid to get access to the jack point on the frame?
    Thanks,
    B.
  2. Feb 22, 2016 at 7:34 PM
    josowski
    josowski Well-Known Member
    Justin
    '16 Tacoma TRD Off Road Crew Cab Long Bed
    Nothing yet... Bought it with TWO miles on it!!!
    I already put mine in the air using the nipple that's protruding through the rear of the main skid plate. Was a little cautious, so I took the plate off to verify. All I saw was a sturdy as hell crossmember.. So up it went.
    Jukeboxx13, ancient11 and mikestaco17 like this.
  3. Feb 22, 2016 at 8:57 PM
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    i don't have a 2016 yet, but typically the manual (not trying to be a d*ck) has appropriate jack points or can give you an idea of where you can jack from. If these do not work (limited space), I would typically jack on a solid part of the frame as close to the point you are trying to lift.
    Example. My 2002 explorer sport says to place factory jack under rear axle as close to wheel as possible when lifting the rear. My 3 ton jack couldn't fit there comfortably with me also needing to put a jack stand under there so I lift from the side frame rail as close to the rear wheel I am lifting as possible and then put a jack stand under the axle on that side. Repeat for other side.
    Front end I would always jack from the cross member.
    Of all the times I have had to get that thing off the ground, it never gave me any problems. Do not jack the rear from the differential unless the manual EXPLICITLY says you can do so (that is my only no-no that you need to watch out for).
  4. Feb 22, 2016 at 9:04 PM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    I just lift the truck via the lower control arm. My ranger's Jack points were the LCAs so it's something I'm familiar with.
  5. Feb 22, 2016 at 9:12 PM
    aero90
    I could never find a good place to put the jack stand while lifting from there. I would always lift from the cross member and let the control arm hang. If I was doing suspension I would let it hang and then use my jack to lift the lower control arm to where I needed it during the install. Otherwise I just let it hang free. But the LCA is where the manual says the jack point is though I believe.
    When you lift from the LCA where do you put your jack stand? Or did you just let it fully compress and then put the jack stand on the frame?
  6. Feb 22, 2016 at 9:15 PM
    AFMurse2014
    Devin
    San Antonio
    Well... I didn't use a jack stand...
    Don't carry them in my truck and as such didn't have one when I jacked the truck up.
  7. Feb 22, 2016 at 11:13 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    Great thanks for the info guys. It completely didn't come to mind that the manual would have any more than using the tire jack that comes with the truck, sorry about that.
  8. Feb 26, 2016 at 6:47 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    The recommended jack points according to the factory service manual are the nipple shown in post #2 and the rear differential.
  9. Feb 26, 2016 at 8:26 AM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    There is a picture on the tool bag under your seat that has the lug wrench in it.
  10. Jan 28, 2017 at 10:04 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    bumping old thread since search instead of new thread right? lol
    So that little nipple is the 'recommended' factory jack point?
    Was trying to figure it out looking in the manual etc, doesn't really specify much for the front only that the read is the axle and has a slight mark for it.
    Was trying to get what the picture showed wasn't sure if it was that nipple or just lift from the frame in that area
  11. Jan 28, 2017 at 10:43 AM
    RichVT
    Rich
    Northern Vermont
    The nipple is the recommended jack point if you are using a floor jack. I wouldn't call it little. If you're using the jack that came with the truck, there are instructions in the owners manual for that.
  12. Jan 28, 2017 at 10:45 AM
    obs ham
    obs ham Well-Known Member
    99 tacoma trd blower
    Owners manual but usually frame or lca
  13. Jan 28, 2017 at 10:52 AM
    Joe23
    bumped the thread because for the front lifting point the manual isn't that clear
    from the picture looks like it could either be the frame or a specific point.
    Doesn't mention anything about that nipple
    tonered and a400ryan like this.
  14. Jan 28, 2017 at 11:02 AM
    RichVT
    Rich
    Northern Vermont
    The nipple (and the rear differential) are shown in the SERVICE manual as points to lift using a floor jack.
    I agree that the owners manual is a little vague. I put the truck jack under the frame in that general location when I had to change a front flat on the side of the road.
    Joe23 likes this.
  15. Jan 28, 2017 at 11:24 AM
    Joe23
    thats basically what I was wondering for, the factory jack for changing a flat.
    wasn't quite sure where to put it.
  16. Jan 28, 2017 at 11:35 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    Owners manual lift points are typically intended for when you're using the supplied jack and aren't typically the sole points you can safely use for lifting. Good to know their location before you need it of course.
    Here is are the lift and support positions indicated in the FSM:
    Tacostastegreat and ancient11 like this.
  17. Jan 28, 2017 at 12:04 PM
    Joe23
    exactly why I'm asking.
    both the jack and the manual aren't very clear on where to be placing the factory jack to lift the front if you need to change a flat road side.
  18. Jan 28, 2017 at 12:12 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    The TRD skid plate has specific jack points built in. I saw a post with a picture somewhere around here awhile ago
    Edit: actually I think it was on the paperwork that came with my TRD skid plate. I'll see if I can find it
  19. Jan 28, 2017 at 12:13 PM
    gpb
    Atlanta
    Seems fairly clear to me, so perhaps I'm missing something. Lift on the frame rail just forward of the crossmember. Unfortunately it means you have to lift a fair bit on a front wheel since you have all the suspension compression to lift past before the wheel's off the ground enough.
  20. Jan 28, 2017 at 12:15 PM
    Joe23
    that's why I'm looking for clarification. Post 2 was referring to some nipple as a jack point where my interpretation of the manual was to lift from the frame just in front of the cross member.
