Front Hub Assembly the same for both sides?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Dec 27, 2017.
  1. Dec 27, 2017 at 6:07 PM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I have a 2007 Tacoma 4x4 with a bad front left wheel bearing.
    I'm going to replace the whole hub assembly as it seems that's the easiest option.
    My question is: Are the hub assembly the same for the Left and Right side?
    Or are they different?
    Is there anything other than the inner dust seal and o-ring that I will need?
    Is it OK to reuse the axle nut? Or is it a NyLock nut and one time use?
  2. Dec 27, 2017 at 6:32 PM
    badger
    badger Well-Known Member
    07 SR5
    The hubs are the same. Usually the assemblies come with the inner seal and the o-ring, but check with your supplier. You will also need the dust seal on the CV axles. I don't see any reason to not re-use the axle nut. I re-used mine. I got my assemblies from Bamatoy.
    TnShooter[OP] likes this.
  3. Dec 27, 2017 at 7:07 PM
    TnShooter
    Deogee
    STOCK
    Thank you.
    And I too plan to buy from BamaToy.
    But his website doesn't say if any seals are included.
    I will be calling and placing my order tomorrow.
  4. Dec 27, 2017 at 7:31 PM
    badger
    07 SR5
    tell him you want the inner seal and the o-ring, just to make sure. He does not supply the CV dust seal, and I got mine at the dealer. I could not find an aftermarket match.
    TnShooter[QUOTED][OP] likes this.
  5. Dec 27, 2017 at 7:34 PM
    TnShooter
    Deogee
    STOCK
    Will do. Thanks man. :thumbsup:
  6. Dec 28, 2017 at 12:58 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Be advised, the inner seal is going to require more disassembly - the tie rod and sway bar. If the inside area of the knuckle is relatively free of rust, you may not need to replace the inner seal. I'm on my third set of wheel bearings and have only replaced the driver-side seal - and it was not needed. After replacing it I came to the aforementioned conclusion. Do apply silicone on the seals and all rubber to metal contact points.
    TnShooter[OP] and lo2hi like this.
  7. Dec 28, 2017 at 1:22 AM
    lo2hi
    lo2hi Well-Known Member
    Chiro
    Portland, Oregon
    2006 Impulse Red Tacoma 4.0L 6-Speed 4WD
    265/75R16 Falken Wildpeaks AT3W & KMC Enduros AFE air intake Bilstein 5100 & Eibach Springs & Ironman4x4 performance leaf Magnaflow 12866 muffler
    Let us know how this goes! I need to also replace both wheel bearings.
  8. Dec 28, 2017 at 2:51 AM
    TnShooter
    Deogee
    STOCK
    The more I think about it. I really want to keep the work to a minimum.
    If it looks relatively clean inside, I likely just replace the hub and o-ring.
    But this thing has been failing for month. I'm ashamed I waited this far to fix.
    I can't even drown out the noisr with the radio at this point.
  9. Dec 28, 2017 at 2:53 AM
    TnShooter
    Deogee
    STOCK
    Will do. Hopefully it'll go semi-smooth.
    lo2hi[QUOTED] likes this.
