Front end squeaking when turning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD2010SpeedwayBlue, Jul 16, 2022.
  1. Jul 16, 2022 at 6:26 AM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue [OP] Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    My truck just developed a squeak in the front end when turning the wheel.
    It only happens when i turn the wheel to the left and close to full lock.
    Will update this post with a video but was wondering if anyone had any input. I checked the power steering fluid and it seemed fine and clear. Maybe something needs grease? My trucks a 2010 trd offroad Was thinking the ball joints but i have no idea whatsoever.
    Any input is appreciated
  2. Jul 18, 2022 at 11:17 PM
    Big2Customs
    Big2Customs Well-Known Member
    2007 Tacoma TRD Sport. Indigo Ink
    Bilstein 5100 front Bilstein 5100 rear
    Likely one of the upper ball joints. Mine did that at near full lock.
    There's no grease zerk on the stock bj. But I used a grease injector needle. Have to puncture the boot, I chose the inside of on of the folds so it closes up. Pumped some grease in there and the squeak went away. Of course this also means the bj is on its way out. Jack up at the lower control arm to get the weight off the wheel, use a breaker bar or pry bar under the tire to lift the wheel and check for any movement in the ball joints.
    Mark77 likes this.
  3. Jul 19, 2022 at 5:31 AM
    TRD2010SpeedwayBlue
    Brandon
    Thank you. Was trying to upload the video and i can’t get it to upload.
    That’s what my tech i know at toyota told me to put grease in the ball joint/tie rod socket.
    Others are telling me it’s the steering rack/pinion
  4. Jul 19, 2022 at 5:57 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    try one thing at a time, greasing ball joints are easiest, and see if that eliminates it, if not, move on from there
    Mark77 likes this.
  5. Jul 19, 2022 at 5:58 AM
    TRD2010SpeedwayBlue
    Brandon
    Okay i will try that. Sounds stupid but what kind of grease should i use. I have some super lube from my UCA bushings.. can i use that? or should i use a spray?
  6. Jul 19, 2022 at 6:02 AM
    MSgt O
    2013 Tacoma
    grease, not spray lube and get a needle tip for your grease gun, "inject" the grease into the boot, and if youre picky, silicone the poke hole and call it good
  7. Jul 19, 2022 at 6:13 AM
    TRD2010SpeedwayBlue
    Brandon
    okay yep got it. And should be greasing what the lower ball joints by the uca? what about upper near the UCA? (i have aftermarket uca’s)
  8. Jul 19, 2022 at 6:20 AM
    lit_taco4x4
    lit_taco4x4 IG and YT: @2a_crawlcamper
    Louie
    2018 Tacoma TRD Pro
    JD fab LT, Archive and Deavers, King shocks, Dual locked, Dual T case, Tundra steering rack, 39’s
    Check your tie rods too. Had this happen last year only when turning.
  9. Jul 19, 2022 at 12:26 PM
    TRD2010SpeedwayBlue
    Brandon
    What did you do to fix?
  10. Jul 19, 2022 at 12:29 PM
    lit_taco4x4
    Louie
    2018 Tacoma TRD Pro
    I replaced the outer tie rod on passenger side. I also thought it was joints needing greasing but the squeak was ongoing. The tie rods were worn out and bent where it attaches to the knuckles.
  11. Jul 19, 2022 at 1:41 PM
    MSgt O
    2013 Tacoma
    if you can, grease everything!
