Front end popping noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USAFFire2724, May 10, 2019.
  1. May 10, 2019 at 2:45 PM
    USAFFire2724
    USAFFire2724 [OP] New Member
    2011 Toyota Tacoma V6 Crew Cab Long Bed
    2.5" Bilstein lift front and back, aftermarket stereo stuff... nothing special
    I've noticed a popping noise coming from the front end of my 2011 Tacoma when the follow happens:
    - wheels fully clocked left or right
    -approaching a steep angle ( i.e. steep driveway)
    - or backing out of said steep angle.
    No other conditions other than this seems to produce the noise. I bought this truck used but it was very well taken care of.
    I've recently replaced the suspension (upgraded to Bilstein 5100 front and back with block for leafs)
    During install, all bushings checked out by the installer. I even crawled under to look myself, however I've dealt with the guy before and he has always been honest.
    Any suggestions on what to look at would be great. I had planned on doing some other things to the truck, new wheels, rack, replacing topper with a leitner designs active cargo system... but would like a smooth running vehicle before any of that happens. Sooner I can get this diagnosed, the sooner I can move on to other stuff.
    I am sure there is a thread already out there for this. But I figured this would be quicker than searching through all 3000+ of them. If you k ow of a thread please li k it so I can read through it.
    THANKS!!!
    BassAckwards likes this.
  2. May 10, 2019 at 3:22 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Noises are hard without hearing them. But for starts I recently had a single pop from what I thought was the front turning right not turned hard.
    It was either the 4 bolts on my manual trans crossmember or the u bolts on the rear end.
    I recently added blocks also and I’m not sure which it was because I found both not to torque.
    Cv shafts stabilizer end links bushings wheel bearings tie rods etc.
    Also thank you for your service!
  3. May 10, 2019 at 3:27 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I'd start by making sure everything is torqued down correctly, especially given you just swapped out suspension parts.
  4. May 10, 2019 at 3:28 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I would also start by torqueing down the ubolts with the truck sitting level somewhere. I torqued mine to 75ft lbs.
    Ubolts should be torqued with the weight of the truck sitting on the leaf springs
    whatstcp and b_r_o like this.
  5. May 10, 2019 at 3:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    LCA cam bolts need to be tightened to 100 lb/ft or they will shift around and make noise. The whole weight of the vehicle goes through those bolts.
    I had noise after an alignment and found they were not properly torqued
    BillsSR5, whatstcp and BassAckwards like this.
  6. May 10, 2019 at 4:32 PM
    USAFFire2724
    I should add that this problem was present before the suspension upgrade. I will check everything to ensure proper torque settings tonight. Any more info however is welcome. Thanks to those who have responded so far!
    b_r_o likes this.
  7. May 10, 2019 at 7:51 PM
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    I have the same popping. I’ve been doing a lot of research and I’m starting to think it’s either upper or lower control arm bushings. I have TC uppers and keep them greased but they could also be worn.
    BillsSR5 likes this.
  8. May 11, 2019 at 12:07 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    At full turn either way suspension hits the stops (look under there). Apply a dab of grease to the metal stop areas and see if that solves your noise. And don't hold the steering at full stop doing those turns! May be the noise so worth 2 minutes to see. If not that's ruled out. You never said if in 4 wd when this happens and if so its the CVs hopping/binding up as expected on paved surface.
  9. May 11, 2019 at 3:46 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I suggest you have someone else drive the truck into the driveway that causes the issue. You stand outside and listen. That will tell you the origin of the noise, front end ,rear end left or right or any combination. Then you can zero in on it.
  10. May 17, 2019 at 9:52 AM
    aroma
    aroma Well-Known Member
    Snottsdale AZ
    I have the same issue with my tundra, it was the steering rack bushings.
  11. May 17, 2019 at 9:55 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    mine dies this how actually should I check the torque there 2 bolts(ONE BOLT AND A SLEEVE BOLT) on each cam, just use an open end on one side and torque wrench the other? dosent matter which side the wrenchs go on?
    b_r_o[QUOTED] likes this.
  12. May 17, 2019 at 10:10 AM
    IAMSNAFU
    IAMSNAFU Well-Known Member
    RY
    City of Angels
    Bingo! I had the same issue and after changing out suspension parts, you'd be amazed after 1,000 miles of driving that some of the bolts come out of spec.
    Just go over everything in detail again and torque down to spec if you changed anything recently.
  13. May 17, 2019 at 11:59 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Apply torque on the "nut" side and counter-hold the "bolt" side
    BillsSR5[QUOTED] likes this.
  14. May 17, 2019 at 12:02 PM
    Westside
    Westside Southbound
    JT
    Nor Cal, East Bay
    TRD Sport 4X4
    UCA and LCA pivots. Re-torque and the popping goes away.
    There's a lot of load on those pivots when you're turning and backing up. Sometimes the force created when turning and backing up shifts any slack in the bolts in one direction, with a pop.. Then it shifts back the opposite direction when the force is reversed and it pops again.
    BillsSR5 and b_r_o like this.
  15. May 17, 2019 at 12:52 PM
    BillsSR5
    bill
    2014 SR5
    awesome, thanx for that I think I may have to check them im having that same creaking noise on turning the wheel going over an elevated drive entrances, almost sounds like something needs to be oiled or greased. I had new bilsteins 4600 put on by a dealer and they had a hard time with the alignment cams,and bent the tabs over on the very front ones and im hoping they didn't strip out those threads doing it
  16. May 17, 2019 at 1:02 PM
    omegaman2
    omegaman2 Unknown Member
    2015 4WD DCSB
    Try this....dab of grease on steering stops
