Front Drive Shaft Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjohnso2, Jul 26, 2020.
  1. Jul 26, 2020 at 5:41 AM
    rjohnso2
    rjohnso2 [OP] Member
    Robert
    2008 Tacoma V6 4WD 6 Speed Manual
    I need to change out the front drive shaft on my Tacoma which has rusted away. I'm talking about the smaller front one for the 4WD. I've never changed out a drive shaft before so was just wondering about the difficulty and what I should know to complete the job. I have 2008 SR5 Sport 4WD in a 6SP manual. Appreciate any help. I left a link to the drive shaft I purchased
    https://www.rockauto.com/en/moreinfo.php?pk=8020628&cc=1441488&jsn=443
  2. Jul 26, 2020 at 2:02 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You already bought it huh? I dont trust many things Dorman. Here, I would not trust their choice of u-joints. For a how-to video, I remember coming across one on u-tube.
  3. Jul 26, 2020 at 4:35 PM
    rjohnso2
    Robert
    Yeah thanks I had just watched that video, pretty much covers everything. I figured Dorman would be better than the drive shaft costing $100 less on Rock Auto. I only saw those two options. Probably won't see much use anyway as I don't use the 4WD too often. What would you recommend instead of Dorman?
  4. Jul 26, 2020 at 4:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you are not going to use 4WD much, and you already have it, throw it in.
    Keep it greased and don’t worry too much about it.
    The drive shaft doesn’t turn unless you are in 4WD.
    rjohnso2[OP] likes this.
  5. Jul 26, 2020 at 4:46 PM
    [KD]
    [KD] Used Import
    Dan
    Halifax, NS
    06 DCSB 6MT
    Sure it's not an auto-manual? Auto-manuals have different driveshaft.
  6. Jul 26, 2020 at 4:50 PM
    rjohnso2
    Robert
    Yeah it's a regular 6 speed manual
    [KD] likes this.
  7. Jul 26, 2020 at 4:58 PM
    rjohnso2
    Robert
    I know it's not a big deal, but if Dorman is really that bad for drive shafts I can still cancel the order. Hasn't shipped yet. Any recommendations?
  8. Jul 26, 2020 at 5:04 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    danbow and rjohnso2[OP] like this.
  9. Jul 26, 2020 at 5:12 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    If these had manual locking hubs, then this would be correct, but on Tacomas those CV axles are spinning all the time, just not under load.
    To OP:There is a lot of you tube vids that are helpful out there. I’ve done mine more than once. It’s pretty straight forward. I’d suggest looking up the torque spec guide available on tacomaworld(sorry don’t have the link handy) I’m one or those that torques everything to factory specs.
    jproffer and rjohnso2[OP] like this.
  10. Jul 26, 2020 at 5:17 PM
    rjohnso2
    Robert
    Thanks hoarder I'm going to cancel and get the one from Toyota. Appreciate the link
  11. Jul 26, 2020 at 5:18 PM
    hoarder23
    Shay
    NJ
    Scratches
    For a 12 year old truck with rust issues I'd go with a used one from the southwest. $100 shipped will get you one that will outlive your frame
    rjohnso2[QUOTED][OP] likes this.
  12. Jul 26, 2020 at 8:38 PM
    Chuy
    Lakeside, CA
    Silver Taco
    How rusted is it. Get a quote from a driveline shop. They may be able to clean it, paint it, and install new u-joints for less than a new one.
  13. Jul 27, 2020 at 12:21 AM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Not sure exactly why you're replacing it, but I would have probably just replaced the u-joints. Also confused because you say you have a Pre-Runner (which is a 2WD) but also say it's a 4WD and ordered a front drive shaft. So I assume it's not a Pre-Runner.
    Jeff
  14. Jul 27, 2020 at 1:10 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Used or I would sand and paint and install/get new U joints. Cheap way to go.
  15. Jul 27, 2020 at 6:27 PM
    rjohnso2
    Robert
    Appreciate all the suggestions, I'm going to look for something used and cheap this time. The old drive shaft is just too heavily rusted
    danbow likes this.
