FRONT DIFFERENTIAL PROBLEMS
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mitch_2234, Sep 25, 2020.
  1. Sep 25, 2020 at 3:52 PM
    Mitch_2234
    Mitch_2234 [OP] Active Member
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    I got a 2008 4x4 Taco, 6” Fabtech lift kit on it. 35” tires.I just had the front diff and axles replaced on it because I was hearing/feeling a grind of some sort that seemed to be coming from where the diff would sit below the vehicle. Leaking front diff, shards in the fluid. I got new wheel bearings replaced, new control arms, new axles and Front Diff and the grind sound and vibe has come back!! It hasn’t even been 3 weeks since I last got it replaced.
    has anyone had problems with their front diff??
  2. Sep 25, 2020 at 3:58 PM
    Muddinfun
    Muddinfun Well-Known Member
    So, all of the stuff that rotates in 2WD is new. Take it back to the shop and bitch.
    Mitch_2234[OP] likes this.
  3. Sep 25, 2020 at 4:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Does the noise go away in 4wd? Maybe it needs the ecgs bushing
  4. Sep 25, 2020 at 4:06 PM
    Mitch_2234
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    Well it has me thinking it might be a deeper issue with driveline angles? I know that this has been a pretty big issues on these Gen 2 that get lifted. I’m just at a loss, luckily I have a warranty from Firestone but I don’t want to replace it without addressing the bigger issue and just have it go bad on me again
  5. Sep 25, 2020 at 4:21 PM
    Muddinfun
    The driveline doesn’t turn in 2WD.
    whatstcp and Island Cruiser like this.
  6. Sep 25, 2020 at 4:46 PM
    Mitch_2234
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    I meant driveshaft
  7. Sep 25, 2020 at 5:23 PM
    Muddinfun
    The driveshaft doesn't turn in 2WD.
  8. Sep 25, 2020 at 5:42 PM
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    How many miles on vehicle? You replaced all that stuff without first diagnosing what the vibe was ? I'm guessing bad needle bearing. Actually 2nd gen tacoma can be lifted without any problems but an educated process must be used. You can fit 35's or even 37's with a 3 inch lift and some other work.
  9. Sep 25, 2020 at 6:20 PM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I’m guessing needle bearing. Does it go away in 4 hi?
  10. Sep 25, 2020 at 7:04 PM
    Mitch_2234
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    110k Na the front diff was leaking a pretty good amount and was shaking when I started to take off and when I had it looked at there was some shard in the fluid.
  11. Sep 25, 2020 at 7:06 PM
    Mitch_2234
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    It’s really only noticeable at around 40 mph if I keep it there it whines pretty loud from inside the cab
  12. Sep 25, 2020 at 7:13 PM
    Mitch_2234
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    Do you think there’s anyway that the 35” tires are too big for stock Toyota axle and front diff ?
  13. Sep 25, 2020 at 7:15 PM
    Mitch_2234
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    I really only hear it at about 40mph, but I’ll drive it tomorrow in 4H at that speed and see if I hear it.
  14. Sep 25, 2020 at 7:27 PM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
    6” lift. 35s. Leaking front diff. Who knows. I’d sort through the vibe diagnosis @gearcruncher put together to diagnose before replacing more stuff...
  15. Sep 25, 2020 at 7:31 PM
    Mitch_2234
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    Dude I know... I’m pretty stumped. Okay great is that an existing post? Sorry man I’m new on this whole site
  16. Sep 25, 2020 at 7:35 PM
    dk_crew
    Dave
    Austin, TX
    2005 Tacoma 4x4
  17. Sep 25, 2020 at 7:38 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    IMO. No. That is a definate NO.
    Stock 2nd gen tacoma will handle 35"tires no problem.
  18. Sep 25, 2020 at 8:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Where is the front differential leaking from?
    Do you still have the old differential?
    It would have been nice to know why the old Differential failed.
    I’ll also go with the rest, run it in 4WD and see if it changes.
    Hopefully a bushing is all that’s needed to clear this up.
  19. Sep 26, 2020 at 5:01 AM
    Mitch_2234
    Mitch
    2008 4x4 TRD Tacoma
    6” Fabtech lift kit
    The rotating/whirring noise does not go away in 4H
  20. Sep 26, 2020 at 5:07 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    As someone stated before the front diff doesn't turn in 2WD so if it's making noise it isn't inside the diff or front drive shaft.
